Narakot
CHR Proxmox 5.3 ZFS Raid-1
Sat Feb 23, 2019 8:41 pm
Trying to install CHR on Proxmox 5.3
Instructions https://wiki.mikrotik.com/wiki/Manual:C ... stallation is not suitable.
For HDD, only local-zfs (ZFS) is available.
ZFS is configured as Raid1: rpool
Code: Select all
root@pve:~# zfs list
NAME USED AVAIL REFER MOUNTPOINT
rpool 2.39G 226G 104K /rpool
rpool/ROOT 1.19G 226G 96K /rpool/ROOT
rpool/ROOT/pve-1 1.19G 226G 1.19G /
rpool/data 1.20G 226G 104K /rpool/data
rpool/data/subvol-100-disk-0 400M 7.61G 400M /rpool/data/subvol-100-disk-0
rpool/data/subvol-101-disk-0 427M 3.58G 427M /rpool/data/subvol-101-disk-0
rpool/data/subvol-102-disk-0 398M 3.61G 398M /rpool/data/subvol-102-disk-0
The qcow2 format can only be used for local (Directory)
I tried to create RAW images in different ways and put rpool folders in different places.
Tell me, how can I install a CHR image on Proxmox 5.3 for ZFS Raid1?
Narakot
Re: CHR Proxmox 5.3 ZFS Raid-1
Fri Mar 01, 2019 2:49 pm
Really? Nobody set CHR on Proxmox with ZFS?
cdemers
Sun Mar 03, 2019 11:14 am
I run a CHR on proxmox kvm, no problem on a ceph cluster for storage. Haven't tried it on just zfs.
Sent from my SM-A520W using Tapatalk
dhoulbrooke
Re: CHR Proxmox 5.3 ZFS Raid-1  [SOLVED]
Mon Mar 04, 2019 10:53 am
The below is how I do it which might give you some ideas. Use at your own risk etc etc.
1. Create a VM in the Proxmox VE web interface. Make a note of the VM ID (in my example 351).
2. SSH in to the VM host.
3. Download the image
wget https://download.mikrotik.com/routeros/6.42.12/chr-6.42.12.img.zip
4. Unzip the image
unzip chr-6.42.12.img.zip
5. dd the image to the zfs zvol
dd if=chr-6.42.12.img of=/dev/zvol/local-zfs/vm-351-disk-0
(where 351 is the ID of your VM and local-zfs is the name of the pool)
6. Start VM in the Proxmox VE web interface.
Narakot
[SOLVED] CHR Proxmox 5.3 ZFS Raid-1
Mon Mar 04, 2019 4:06 pm
Thanks to all!
I did it with the help of the command:
Code: Select all
dd if=chr-6.42.12.img of=/dev/zvol/rpool/data/vm-103-disk-0
Users browsing this forum: MSN [Bot] and 7 guests
