MUM Europe 2020
tonymobile
Re: v6.44 [stable] is released!
Thu Feb 28, 2019 10:34 am
Updated a CCR1009 and RB4011 without any issues. Great work MT!
Now please make us happy with some BGP improvements in 6.45 :-)
Quote!!
is it true that for the BGP sessions, RouterOS use only one core?
nuffrespect
Thu Feb 28, 2019 11:11 am
Didn't understand this topic (how it works):
*) lte - added "firmware-upgrade" command for R11e-LTE international modems (CLI only);
Tried to update WAP-LTE with CLI - it shows that exist new firmware - enter "upgrade"
/ interface lte firmware-upgrade lte1
installed: MikroTik_CP_2.160.000_v008
latest: MikroTik_CP_2.160.000_v010
/ interface lte firmware-upgrade lte1 upgrade=yes
.... lost connection.... reboot.... same version on modem
Did you login via LTE connection? Lost connection is expected then, probably failed upgrade is as well. I use this script for remote upgrade: unattended-lte-firmware-upgrade
Yes, the same connection of course ;) because that's LTE router, it didn't had another one "internet" inside :) only from mobile provider....
Maybe failed - there is no log messages about process, nothing, It is very well, that after the "failed update" the device has recovered connection after reboot.
Thanks for the script, i will test it on "non-production" router, first and after that on installed
nuffrespect
Thu Feb 28, 2019 11:15 am
I have 2 carriers with 2 different SIMs. One works, one seems to block it!
Maybe that's my case too, will try to investigate too...
nuffrespect
Thu Feb 28, 2019 11:26 am
Another "bug" from version to version, form stable to stable release
"Future" time on GRE tunnels in (up\down) status field
May be someone know how it resolve?
Thanks!
Paternot
Long time Member
Long time Member
Thu Feb 28, 2019 11:58 am
Quote!!
Yes, it is.
osc86
Thu Feb 28, 2019 12:02 pm
Thanks!
Check System / Clock
All tunnel interfaces show the correct date and time on my devices.
mrz
Thu Feb 28, 2019 12:06 pm
Incorrect time is cosmetic Winbox bug noticed when there are multiple Winbox instances open. If you check in terminal, time is reported correctly.
hapi
Thu Feb 28, 2019 1:10 pm
command
/interface wireless set wlan1 band=5ghz-onlyac;
on RB711G (no AC wifi) run is ok. No fail, no error but wifi not function.
this automatization script is not function, function only on AC devices because no error if set onlyAC on noAC devices.
 	:do { /interface wireless set wlan1 band="5ghz-n/ac"; :log info "usage 5g-n/ac"; } on-error={
	    :do { /interface wireless set wlan1 band="5ghz-onlyn"; :log info "usage 5g-n"; } on-error={
	        :do { /interface wireless set wlan1 band="5ghz-a"; :log info "usage 5g-a"; } on-error={
mrz
Thu Feb 28, 2019 1:18 pm
Works as expected:
[admin@4p_DUT_DISC Lite5] /interface wireless> set band=5ghz-n/ac
Script Error: action cancelled
[admin@4p_DUT_DISC Lite5] /interface wireless> set  0 band=5ghz-n/ac
failure: bad band or frequency, see 'wireless info' for supported channels
[admin@4p_DUT_DISC Lite5] /interface wireless> :do { set 0 band=5ghz-n/ac } on-err
or={ :put "error"}
error
Not 6.44 version specific, most likely related to wireless card you have, contact support for more details.
hapi
Thu Feb 28, 2019 1:31 pm
RB711G not wifi AC. SXT report error, RB711G no error.
isacalmeida
Thu Feb 28, 2019 1:34 pm
Kampfwurst - What is the error that you get? Does your router have an access to cloud2.mikrotik.com? Test it from CLI (Winbox would use computers DNS in order to resolve this address);
Simono - Please provide an example rule that you use in access list and interface configuration within an e-mail to support@mikrotik.com;
Chupaka - We will update wiki page as soon as possible;
WirelessRudy - Do you have an access to this IP address? Please provide supout file from your router to support@mikrotik.com. Speed Test works just fine for me to/from all accessible IP addresses;
osc86, MDE, geiger - Please provide supout file from your router to support@mikrotik.com;
lenciso - Please provide more information about what kind of crash did you experience on your router;
isacalmeida - Please provide an example. This fix was made in order to fix an issue when, for example, you have PPPoE tunnel which creates default route and then have an L2TP tunnel over it. Then special route towards L2TP server must be created dynamically which uses PPPoE as a gateway, if L2TP adds its own default route. Otherwise L2TP server would be reachable over L2TP tunnel itself which is not correct;
Chaosphere64 - Are these devices discovered by MNDP? If yes, then please provide supout file from your router to support@mikrotik.com;
Pea - This change allows to specify interfaces under "/caps-man manager interface" menu and at the same time allows to use router itself as a CAP and CAPsMAN at the same time. Before you could not forbid all and allow traffic from router itself to CAPsMAN. It affects interface list not the firewall. Firewall accept rule still must be present;
saaremaa - What is the question here actually? Delegated-IPv6-Prefix is already working for DHCP service (RADIUS). Such parameter is not available yet for PPP service. If you make PPPoE server which then distributes addresses by using DHCP service, then this will not work since users are authenticated by using PPP service, not DHCP;
tamagochi - Do you mean that e-mail settings were corrupted? I do not see how this would be possible by this upgrade. If you downgrade router back, then setting re-appears? Please test if when you downgrade device, set TO parameter, upgrade back and the setting is gone again;
Nicky - If details about new IPsec implementation are not clear from the changelog, then please write to support@mikrotik.com. Provide your configuration and an example of configuration which can not seem to get working. We will help you as soon as possible;
Hello strods,
In my scenario, I have a PPPoE connection and a PPTP VPN, both with the default route enabled. After updating the version, the bug remains when the both are with the default route.
ErfanDL
Thu Feb 28, 2019 2:24 pm
there is a bug in RB2011UiAS-2HnD with HUAWEI USB 3G Dongle. the dongle cannot be detecting in RB2011UiAS-2HnD, but with RB951Ui working without problem.
Shalom
Thu Feb 28, 2019 3:43 pm
I got issue on the IKE to Iphone VPN after upgrade to 6.44, the iphone doesn't connect to the IKE VPN and show error message that the router did not respond, previously was working fine. Just to sharing this and i got no solution on it yet.
nuffrespect
Thu Feb 28, 2019 3:59 pm
What terminal command can get time UP|DOWN from gre interface status in terminal???
/interface gre .... ??
I know only for Ethernet
Thanks!
freemannnn
Long time Member
Long time Member
Thu Feb 28, 2019 4:03 pm
this "pwr-line1" interface appeared after upgrade to 6.44 on a haplite.
nuffrespect
Thu Feb 28, 2019 4:05 pm
Thanks!
Checked, ntp-ok, sync- ok, auto-time-zone-off-manual, cloud tyme resync-off, that's on both sides of tunnel
srTeCHNoiD
Thu Feb 28, 2019 4:18 pm
Hello all!
We have the following configuration:
2x CCR-1036, 3x different IPv4 channels between them (L2/L3), eoip tunnels are setupped and working fine over this channels.
All this eoip tunnels are RSTP-bridged and working fine before update to 6.44. After update we have this message in log:
eoip-tunnel1: bridge port received packet with own address as source address ([MAC address of this bridge]), probably loop
Message exists only on non-root bridge, and sometimes we see dropped packets (i suggest at the moment of loop test, 1-2 per minute).
eoip-tunnel1 have the hightest priority in this bridge so its active.
If we degrade firmware to long-term, everything is working ok, no errors or messages or dropped packets.
Why this happening? Maybe this is bug?
Cha0s
Forum Veteran
Forum Veteran
Thu Feb 28, 2019 6:39 pm
When will it be fixed? This has been reported for many releases by now.
Raumaster
Thu Feb 28, 2019 6:46 pm
I've updated all my routerbords including all the APs, SXT SA and RB921GS from 6.42.3 to 6.44 and had problems with clients with kinda low signal, -68, -70, -72dbm... In the versio 6.42.3 Mikrotik had made improvements on the NV2 Protocol and said then that clients with low signals from that version on would not affect the whole sector. After upgrading to 6.44 in three of our sectors, many clients started complaining about slow speed. In these three sectors we have one or two clients with kinda of poor signal, -68 to -73dbm, but they were all working okay, no complaints at all since upgrading to 6.42.3 or 6.42.6. In the version 6.44 it seems the NV2 protocol is not working as it was on version 6.42.3 to 6.42.6 or so. We have sectors with 6.42.3 and .6 and they're all working nicely with NV2, but not if I try with version 6.44. All clients are 6.40.9 <--- could this be the culprit or the NV2 protocol in this version is not working as it used to work in 6.42.3?
WirelessRudy
Thu Feb 28, 2019 7:03 pm
Thanks!
Well, this must be of help to Mikrotik. I also still see the same on my last up- and downtime columns in my wAP60G devices. Future times. Before it could be days ahead, now its the proper day, but some hours ahead..... (and yes, timesettings are properly configured. Log and time on header show correct time.)
Made a suppout report on 6.43.8 I believe but indeed not solved yet.....
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
WirelessRudy
Thu Feb 28, 2019 8:07 pm
Well, would still be nice to see it corrected in a new update since I have it in all my wAP60G's shown in winbox to see when and how many times the links still disconnect.
And "cosmetic"? How is that? We are talking digital here..... "Cosmetic" is when you meet a nice girl in the disco that shows absolutely ugly the next morning when her "cosmetics" are ruined..... :lol: :lol:
Rudy R. Puister
mhugo
Thu Feb 28, 2019 11:56 pm
On CRS317 two SPFs working in previous version is not seen by system anymore.
Yellow bidi is seen for uplink thank god, but blue is not there any more.
/M
WirelessRudy
Fri Mar 01, 2019 12:22 am
NV2 in this release has been improved for mixed networks. But still my Omnitik serves some 14 clients 130% better with 802.11ac rts/cts then NV2.
And this P2MP works in 40Mhz where part of it overlaps other remote AP's. Spectrum is pretty full.
Before the difference between NV2 and 802.11 was almost 200% in favor of the latter.
So improvement for NV2 yes, but still not the same as 802.11.
Rudy R. Puister
Raumaster
Fri Mar 01, 2019 12:49 am
"NV2 in this release has been improved for mixed networks."
Please, explain the definition of "mixed networks". As far as I know I can only use NV2 with mikrotik gear.
And what happend to what Mikrotik stated a few month ago when they've released version 6.42.3 saying that now one bad client don't affect the whole sector? I jumped from 6.42.3 to 6.44 and the experience was terrible! In version 6.42.3 everything was in balance, one or two bad signal clients is not affecting the others at lease not in a way clients can tell. I had to downgrade to 6.42.3...
WirelessRudy
Fri Mar 01, 2019 1:23 am
well, the context was in the sense of mixing "mipsbe" (and "mipsle") devices with "arm" equipped processors where several people seems to have problems with.
Apart from that you are right, in NV2 only mikrotik gear works. But in 802.11 you can also use any other 802.11 brand device.
Another advantage (a bit beside the topic though) is that 802.11 is the only way to ran a frequency band SSID scan (NOT a spectral scan for most devices!) while not breaking the client-AP connection.
That is a real valuable tool in nowadays P2MP networks. (A spectral scan would be preferable though.)
Rudy R. Puister
docmarius
Fri Mar 01, 2019 2:20 am
Hmmm, after about one day, on my CCR1009, all static routes configured for connected PPtP and SSTP clients (I have no other types to check) disappeared, and connectivity to the client's subnets was lost.
Disconnecting the clients and allowing them to reconnect restored the routes...
As if those routes somehow expired.
I will keep an eye on it if it happens again...
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
DummyPLUG
Fri Mar 01, 2019 9:08 am
But it happen for me even with one winbox instance, I had this problem with 3.17/3.18 and no problem with 3.16
fossy55
Fri Mar 01, 2019 12:35 pm
*) gps - increase precision for dd format;
Hi, could it be that the calculation from dms-format to dd-format is incorrect ?
For example: in winbox/system/GPS-GUI I switch between dms and dd format.
In dms I get 49 29' 6.954'
when I switch to dd I get 49.004852
in my calculation it should be 49.485265
Is ist my false or is this a wrong calculation....in firmware 6.43.12 there was no problem.
Regards
eworm
Fri Mar 01, 2019 1:09 pm
Regards
This has been reported for the beta and rc releases as well. Now idea if Mikrotik is aware, write at support@mikrotik.com to make sure.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
macgaiver
Fri Mar 01, 2019 2:17 pm
speedtest - added "/tool speed-test" for ping latency, jitter, loss and TCP and UDP download, upload speed measurements (CLI only)
This feature is nice indeed!
It wouldn't be me not to ask for more though :D :
- Can the time the test run either be adjusted by administrator of just set longer. In many occasions the connection rates between the client and AP have to step up before a longer lasting level is
reached. The test average is kept low due this.
A full 1 minute test would be preferred, 2 would even be better, admin adjustable would be perfect.....
- Is this going to be implemented in Winbox?
<tab> <tab> after address reveals additional options
 /tool speed-test
connection-count  do  duration  file  interval  password  test-duration user  address
specify test-duration you can run it for hours.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
normis
Fri Mar 01, 2019 3:58 pm
Regards
Fix is in 6.45beta3
Paternot
Long time Member
Long time Member
Fri Mar 01, 2019 4:16 pm
Fix is in 6.45beta3
6.45 beta3 already? Wow, You guys are really cranking up the speed!
Chupaka
Fri Mar 01, 2019 4:29 pm
It's like 7.0 beta1 - it's probably here, but you don't see it and cannot upgrade to it xD Sorry...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
raffav
Fri Mar 01, 2019 5:48 pm
Hahaha You are funny but I have to agree with you
vanikcz
Fri Mar 01, 2019 6:02 pm
since 6.44 IPsec tunnels stop working for me, it says: no identity suits proposal, failed to get valid proposal. Maybe my setup is not the best but until 6.43.12 it was working well.
vanikcz
Fri Mar 01, 2019 6:54 pm
I solved that - in IPsec peer identity there was My ID Type set to address, I switched it do auto and use the router's (internal - its behind nat) IP in other end settings (It is Kerio Control)
pe1chl
Fri Mar 01, 2019 8:09 pm
loose-tcp-tracking is no longer working!
after upgrade and reboot all existing TCP connections across the router are stuck, and firewall logs "tcp (ACK, PSH)" packets being dropped.
normally, after a router reboot an outgoing TCP packet on an existing connection (no NAT in use!) will re-establish the tracking entry when loose-tcp-tracking is selected (the default).
now all connections need to be re-connected.
new connections are processed correctly, but existing connections are not.
xds
Fri Mar 01, 2019 9:34 pm
Hello guys, has someone try RADIUS RadSec (RADIUS communication over TLS)?
Because for me this one doesn't work,
I was set all things, that was suggested in wiki, but in .log I see an error when I try to connect to my VPN (IPSec XAuth) and can't connect;
*when I turn off radsec to udp, RADIUS works great!
**in wiki I see just:
***logging (radius, debug)
shows that the 127.0.0.1 try connect to port 2083, then 127.0.0.1 to port 8968
(Mikrotik Support could you be so kind to add 2083 port into WIKI as additional information),
and provide to us info about port 8968, please,
add more info about RadSec, here https://wiki.mikrotik.com/wiki/Manual:RADIUS_Client!
Thank you!
Can anyone suggest something/help?
Thank you in advance!
R1CH
Forum Veteran
Forum Veteran
Sat Mar 02, 2019 3:04 am
https-redirect is not working
You can't redirect HTTPS - the security provided by HTTPS means that unless you control the client devices and can install custom root certs, certificate validation will fail and users will see security errors. Mikrotik of all people should know this... what does this option even try to do?
Raumaster
Sat Mar 02, 2019 3:29 am
So, these fixes made for improving NV2 with mixed devices has made things worse for those running mipsbe only devices? Because for me it is bad now and I only use mipsbe devices. It now means that I can't upgrade my APs anymore? I'm stuck to 6.42.3 or Mikrotik will do something about it?
I myself would prefer using 802.11 instead of NV2, but in my scenario I find NV2 to be more stable then 802.11, not regarding throughput, but quality in general.
pmuch
Sat Mar 02, 2019 9:17 am
I've upgraded my hAP AC2 and my wireless printer stopped working - I can open printer web page from my computer, but nothing gets printed when my computer is connected to the same network. When I'm outside my network and connect witch OpenVPN to my router - everything gets printed.
And also my TV with chromecast isn't discoverable by Chrome, and TV has full access to Internet.
Downgrade to 6.42.12 solves all the issues.
Pawel
Oscarwug
Sat Mar 02, 2019 9:23 am
Bug in ROS 6.44
[admin@MikroTik] > log print
09:00:29 system,info installed system-6.44
09:00:29 system,info installed advanced-tools-6.44
09:00:29 system,info installed multicast-6.44
09:00:29 system,info installed ntp-6.44
09:00:29 system,info installed routing-6.44
09:00:29 system,error can not install security-6.44: dhcp-6.44 is not installed, but is required
Pea
Sat Mar 02, 2019 9:53 am
This is not a bug, it tells you that you must install DHCP package now, read carefully the change list:
*) upgrade - made security package depend on DHCP package
Etz
Sat Mar 02, 2019 10:05 am
What is actual dependency behind this?
andriys
Sat Mar 02, 2019 11:21 am
Security package implements IKEv2 (among other things), which may now require DHCP in some configurations. Check this entry in ChangeLog:
*) ike2 - send split networks over DHCP (option 249) to Windows initiators if DHCP Inform is received;
Infra3600
Sat Mar 02, 2019 11:34 am
This night I have updated my Mikrotik 2011UiAS-2HnD to RouterOS 6.44 [Stable].
Several weeks ago, my router was set up with 2 ISPs by this instruction: http://www.vasilevkirill.com/MikroTik/1/
At this time, my router works fine.
WirelessRudy
Sat Mar 02, 2019 11:41 am
Where are you getting the information that the upgrade make things worse for mipsbe only devices? Nobody said that. I have full mipsbe P2MP networks too and they run fine after the upgrade. I don't know if NV2 has been improved for them, I run them in 802.11 anyway. But nobody reported so far in full mipsbe networks the new version is worse...
You can just update your networks because there are other improvements as well.
Rudy R. Puister
Raumaster
Sat Mar 02, 2019 3:24 pm
In my network things were running smoothly without complaints from clients, the day after going from 6.42.3 to 6.44 we starded receiving many complaints about slow internet speed. In two sectors we have two clients with signal going from -68 to -72 and these clients were using the Internet without any complaint along with the other ones on the same sector, but right after upgrading to 6.44 these "bad" signal clients and others that never complained about something started calling us saying the internet was slow...My conclusion is, something is not as good as it was on 6.42.3 in NV2 for misbe devices. You were the one that said something was done to improve things for mixed networks so I assumed that these improvements have caused something negative for mipsbe only networks or for them all regarding "bad" signal clients on the sector. Mikrotik had made a promise a few months ago that from that time on bad clients would not affect other clients on the same sector, but it seems this is not true for the newer ROS versions.
tarcisionmjr
Sun Mar 03, 2019 12:20 am
the graphical representation stopped working after the update of crs317-1g-16s + was working normal in version 6.43 but then I did the update to 6.44 and stopped working and a message appeared in the log "timeout while waiting from program 20", I need help...
dadoremix
Sun Mar 03, 2019 12:37 am
Check country code in ros
And signals
They kill power in some countrys
rzirzi
Sun Mar 03, 2019 9:30 am
Very stupid dependence! I don't need DHCP at many situations, but need SSH. So i have had installed: advanced-tools, security, system packages only. But now i have to use DHCP?! Nonsense!!!
aviper
Sun Mar 03, 2019 10:53 am
Update from 6.40.8 to 6.44 seems to remove "system note" content.
Resolve: My mistake, I was removing all file, just to make space and be sure, that nothing is left in there. And I've removed the sys-note file.
pe1chl
Sun Mar 03, 2019 12:02 pm
Ideally, the new function of IKEv2 that requires DHCP would just be disabled until DHCP is installed (preferably with a remark in the user interface).
So DHCP only has to be installed when that function is desired.
But realistically it will probably be difficult to maintain such functions separate in the package dependencies and it would be better to merge packages
like dhcp, security, ipv6 and ppp all into system, leaving the packaging system only for real oddities like gps, ups, ntp, hotspot etc.
marlow
Sun Mar 03, 2019 2:11 pm
saaremaa - Sorry about that. I mixed both services together. We do support Delegated-IPv6-Prefix for DHCP service but not for PPP yet. It is in our plans to add support for this in the future;
Why on earth would you implement it for one service and not for another ? PPPoE is actually the one where it would have been more important to get it implemented, because that's more commonly used in broadband distribution than DHCP.
Especially when it comes to FTTH and VDSL.
/M
Communication is the beginning of understanding
-- AT&T
WirelessRudy
Sun Mar 03, 2019 10:27 pm
dadoremix gave you a possible answer..
I did not see signal getting less in software updates. But indeed, the country code I used I has to set to 'no_country' to get my network back to where it was.... ;-)
Rudy R. Puister
Raumaster
Sun Mar 03, 2019 11:09 pm
And signals
We use superchannel.
marit
Sun Mar 03, 2019 11:57 pm
Mikrotik RB4011iGS+ from version 6.43.12 to 6.44.
Devices from VLANs stopped responding.
I have created a bridge that contains a sfp port.
VLAN assigned to the bridge.
From the mikrotik SFP port to the other switch.
The port SFP on the other switch is tagged, unfortunately, it does not respond correctly after the update (ping time out).
Rollback old version and now it works correctly.
What could be the reason?
xPucTu4
Mon Mar 04, 2019 3:19 am
On 4011iGS.... after update the SFP started flapping 1-2 times per second.
It is 1gb SFP.
The port is not in bridge, it have vlans. Updated to the test version but the flapping continued. Then downgraded back to 6.43.12 and it works again.
The SFP module is @irLAN. They are widely used in Bulgaria because of the price. I moved the SFP to a switch and it works there too.
From the SFP properties page in winbox:
Vendor part number: SFP-LH-SM
Serial: H50001116
mducharme
Trainer
Trainer
Mon Mar 04, 2019 5:08 am
MikroTik as remote DHCP server for relay purposes (not connected directly to the network that DHCP is used on) stops giving leases after upgrade, seemingly due to new ARP conflict detection feature. Disabling conflict detection resolves the issue. Shouldn't this feature shut itself off if the router doesn't have an IP on the target subnet (and therefore can't make ARP requests)?
andriys
Mon Mar 04, 2019 9:37 am
The country setting now has priority, so your superchannel won't work unless you have country set to no_country_set. The forum is full of discussions about this change...
kangarie
Mon Mar 04, 2019 10:39 am
i just test https-redirect option
https-redirect=yes
if unlogged user try to open https website, it will be redirected to hostpot login with https. same behavior as previous version
so browser will show cert warning because cert common name is not same with domain
https-redirect=no
if unlogged user try to open https website, it will be rejected/refused so browser will error like there is no internet access
CMIIW
unable08
Mon Mar 04, 2019 11:06 am
*) lte - fixed LTE interface not working properly after reboot on RBSXTLTE3-7;
Hi, my RBSXTLTE3-7 stops working after firmware upgrade. LTE interface is not working with status "Changing band", also there is an error in log "reply timeout for ate0".
tomek242
Mon Mar 04, 2019 11:16 am
Hello Every MikroTik fans.
I upgraded my STX LTE router to 6.44 stable version software. Unfortunatelly when i was rebooted my router i have only half signal value on band 7, when i was try to switch router for band 3 everything crashes and I can't connect to any LTE network.
I was try to install oldest stabled versions of software but every time i had same problem: in first use i had only half signal in band 7 and crash when i was switched to band 3.
I have a LTE broadcasting tower some about 400 maybe 500 meters of my location. This is parameters of LTE transmitter:
Play (26006) ID: SKA3305 This transmitter use band 3 GSM1800 GSM900 LTE1800 LTE2100 LTE800 UMTS2100 UMTS900
Greetings Tom
tomek242
Mon Mar 04, 2019 11:18 am
I have same problem :)
kalsze
Mon Mar 04, 2019 11:26 am
Has anybody else ran into a weird problem where SSH would not connect after upgrading to 6.44? Everything was still working up to and including 6.43.12.
I have a setup that's like this:
[Ubuntu Desktop] <-- Office LAN (172.26.2.0/24) --> [RouterBoard "ovpn-endpoint" running OpenVPN server] <-- OpenVPN --> [RouterBoard "router2" running OpenVPN client] <-- bridge-local --> [Raspberry Pi]
When router2 was running RouterOS 6.43.12, I used to be able to SSH into the Raspberry Pi from my Ubuntu Desktop, by doing:
ssh foo@172.28.2.179
where 172.28.2.179 is the Raspberry Pi's IP from router2's DHCP server, within bridge-local.
I could do this because my Office LAN has a DHCP option telling my Ubuntu Desktop to send packets for 172.28.2.0/24 via the "ovpn-endpoint" RouterBoard.
router2 has an IP route rule so it knows to send back packets destined for 172.26.2.0/24 via the OpenVPN connection.
Now, after upgrading router2 to RouterOS 6.44, I see this when I do `ssh -v foo@172.28.2.179`:
OpenSSH_7.6p1 Ubuntu-4ubuntu0.2, OpenSSL 1.0.2n  7 Dec 2017
debug1: Reading configuration data /home/kal/.ssh/config
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to 172.28.2.179 [172.28.2.179] port 22.
debug1: Connection established.
debug1: identity file /home/kal/.ssh/id_rsa type 0
debug1: key_load_public: No such file or directory
debug1: identity file /home/kal/.ssh/id_rsa-cert type -1
debug1: identity file /home/kal/.ssh/id_dsa type -1
debug1: identity file /home/kal/.ssh/id_dsa-cert type -1
debug1: identity file /home/kal/.ssh/id_ecdsa type -1
debug1: identity file /home/kal/.ssh/id_ecdsa-cert type -1
debug1: identity file /home/kal/.ssh/id_ed25519 type -1
debug1: identity file /home/kal/.ssh/id_ed25519-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.2
And then it gets stuck.
In router2, I see these IP firewall filter rules:
 0    ;;; default configuration
      chain=input action=accept protocol=icmp log=no log-prefix=""
 1    ;;; default configuration
      chain=input action=accept connection-state=established,related log=no log-prefix=""
 2    ;;; default configuration
      chain=input action=drop in-interface=ether1-gateway log=no log-prefix=""
 3    ;;; default configuration
      chain=forward action=accept connection-state=established,related log=no log-prefix=""
 4    ;;; Allow only the registration and scan raspberry pis and the scanner to access the internet.
      chain=forward action=accept src-address-list=with_internet_access out-interface=ether1-gateway log=no log-prefix=""
 5    ;;; Forbid everybody else from accessing the internet.
      chain=forward action=drop out-interface=ether1-gateway log=no log-prefix=""
 6    ;;; Forward related and established connections from the internet to the registration and scan raspberry pis and the scanner.
      chain=forward action=accept connection-state=established,related in-interface=ether1-gateway log=no log-prefix=""
 7    ;;; Drop forwarding from the internet for everybody else.
      chain=forward action=drop in-interface=ether1-gateway log=no log-prefix=""
 8    ;;; default configuration
      chain=forward action=drop connection-state=invalid log=no log-prefix=""
 9    ;;; default configuration
      chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether1-gateway log=no log-prefix=""
Rule 8 is dropping packets during the SSH handshake for some reason.
If I enable logging (`/ip firewall filter set 8 log=yes log-prefix="debug"`), I see that it's dropping packets like these:
16:05:46 firewall,info debug forward: in:bridge-local out:ovpn-out1, src-mac b8:27:eb:53:4c:91, proto TCP (SYN,ACK), 172.28.2.179:22->172.26.2.229:55490, len 60
16:05:48 firewall,info debug forward: in:ovpn-out1 out:bridge-local, proto TCP (ACK,FIN), 172.26.2.229:55490->172.28.2.179:22, len 52
16:05:57 firewall,info debug forward: in:ovpn-out1 out:bridge-local, proto TCP (ACK,PSH), 172.26.2.229:55500->172.28.2.179:22, len 93
16:05:58 firewall,info debug forward: in:bridge-local out:ovpn-out1, src-mac b8:27:eb:53:4c:91, proto TCP (SYN,ACK), 172.28.2.179:22->172.26.2.229:55500, len 60
16:06:04 firewall,info debug forward: in:ovpn-out1 out:bridge-local, proto TCP (ACK,PSH), 172.26.2.229:55500->172.28.2.179:22, len 93
16:06:06 firewall,info debug forward: in:bridge-local out:ovpn-out1, src-mac b8:27:eb:53:4c:91, proto TCP (SYN,ACK), 172.28.2.179:22->172.26.2.229:55500, len 60
16:06:18 firewall,info debug forward: in:ovpn-out1 out:bridge-local, proto TCP (ACK,PSH), 172.26.2.229:55500->172.28.2.179:22, len 93
16:06:22 firewall,info debug forward: in:bridge-local out:ovpn-out1, src-mac b8:27:eb:53:4c:91, proto TCP (SYN,ACK), 172.28.2.179:22->172.26.2.229:55500, len 60
If I disable rule 8 (`/ip firewall filter disable 8`), SSH goes through.
Does anybody have any idea why the packets are being dropped as invalid in RouterOS 6.44?
To be clear, my SSH connections are *not* NAT'ed. All of the RouterBoards involved have `/ip route` rules that just forward the packets through the correct connection without NAT'ing. They're only acting as gateways.
ste
Mon Mar 04, 2019 3:08 pm
i update to 6.44 but when i wana use ip cloud sometimes about half of time i try "Error: request Timed out" what should i do?
Send report to support@mikrotik.com including .rif File.
Redmor
Mon Mar 04, 2019 3:49 pm
PWR-Line port on hAP
rzirzi
Mon Mar 04, 2019 3:59 pm
After upgrade from ROS 6.43.12 to 6.44 - I have lost possibility co connect to my MT with L2TP (with preshared key) VPN. I was changing firewall settings, trying other.... but after downgrade to 6.43.12 - IT WORKS AGAIN. So something is BAD with ROS 6.44 and L2TP VPN ! MikroTik team - please repir that ROS 6.44 BUG.
Halfeez92
Mon Mar 04, 2019 5:00 pm
Exactly my problem.
I remotely upgraded my SXTLTE3-7 from far away. After that I didnt see the VPN connection. Luckily I have other friends that can help me remote to downgrade to the previous version.
spacex
Mon Mar 04, 2019 10:52 pm
I am wondering too
Askey307
Tue Mar 05, 2019 12:52 pm
Hi
Since the last update we have had multiple clients complaining about existing sites where VoIP experiences issues, from de-registration, no audio, one way audio.
Currently we downgrading the clients back to 6.43.8 which works.
I've sent multiple supouts and support tickets to Support with no feedback.
We're a big distributor of Mikrotik, and this is the first we get with VoIP.
DenisPDA
Tue Mar 05, 2019 1:10 pm
Hi
I have a suggestion that the problem is in the firewall (6.44)
Connection-state errors (estabilished, invalid, related)
To be precise
That connection is dropped for reasons that are not understandable.
I found a solution for myself
Create an allow rule above (estabilished, related)
But it's not right
Deantwo
Tue Mar 05, 2019 1:20 pm
Upgrading my RB750 from RouterOS 6.40.8 to 6.44 leaves all IPsec peers with "unknown" profiles.
And it looks like any IPsec peer settings were lost since only "default" profile exist.
Do I have to jump to another version first and then jump to 6.44?
Gonna go test if it also happen if I upgrade to 6.42.12 long-trem.
I wish my FTP was FTL.
Askey307
Tue Mar 05, 2019 1:23 pm
Hi
To be precise
But it's not right
Can you share an example of this established related firewall rule please if you don't mind.
Yeah I agree, this is no right.
Would love some answers from Mikrotik, because I have 6 cases in 3 last week and open cases open since last week.
DenisPDA
Tue Mar 05, 2019 1:53 pm
Hi
To be precise
But it's not right
This is a rough example.
1 action=accept chain=forward dst-address=10.10.10.10 src-address=8.8.8.8
1 rule without specifying connection-state
2 action=accept chain=forward connection-state=established,related
3 action=drop chain=forward connection-state=invalid
pe1chl
Tue Mar 05, 2019 1:57 pm
Hi
To be precise
But it's not right
Maybe it could be related to the bug that I reported above? (loose TCP connection tracking no longer works)
It could be that there were changes in the connection tracking firewall that have side effects like this.
DenisPDA
Tue Mar 05, 2019 2:26 pm
I can say with complete confidence that on average I have 15% fewer connections. (6.44)
buset1974
Tue Mar 05, 2019 6:02 pm
*) bgp - properly update keepalive time after peer restart;
what exactly this fix for?
i still having problem with bgp withdraw on PE - CE
and also i still having bgp stuck on vrf.
thx
pe1chl
Tue Mar 05, 2019 6:59 pm
I have seen issues with BGP when the keepalive time is not set equal at both peers.
According to the protocol spec the lower of the two keepalive times should be used by both peers.
But in practice it sometimes happened that each peer used its own local keepalive time and the route was flapping when one is >3 times the other.
(e.g. default is 180 and I sometimes set this to 15 on wireless links where BFD is not in use)
Maybe this has been fixed now. But you could always work around it by configuring the same keepalive time on both routers.
tarcisionmjr
Wed Mar 06, 2019 2:06 am
2 x CRS326-24G-2S+ - Updated to version 6.44 and working fine ..
1 x CCR1072-1G-8S+ - Updated to version 6.44 and working fine ..
1 x CRS317-1G-16S+ - Upgraded to version 6.44 and running fine for up to 4 hours, the SNMP and Graphics Tool features stop working and, consequently, the interface view no longer looks like winbox ...
buset1974
Wed Mar 06, 2019 2:27 am
i see, yes i have that problem too, after migration, we have all bgp's flapping so i have to set keepalive on both side.
thanks for the info.
kalsze
Wed Mar 06, 2019 3:38 am
Hi
To be precise
But it's not right
Looks like we're all hit by the same problem, manifested over different application protocols. See my post above.
tarcisionmjr
Wed Mar 06, 2019 7:25 am
1 x CRS317-1G-16S+ - Upgraded to version 6.44 and running fine for up to 4 hours, the SNMP and Graphics Tool features stop working and, consequently, the interface view no longer looks like winbox...
CRS317-1G-16S+ - After 4 hours the switch stops responding to the command ... which gets frozen when digit is not returned by the console ...
/interface print
llag
Wed Mar 06, 2019 12:23 pm
I Installed 6.44 on my CRS328-24p and my CRS317 switches.
I now have some real problems logging in to the web interface using Firefox on the CRS317: I type the userid and passwd but login fails with: ERROR: Not Found.
This does not happen all the time, but only 1 in 30 logins or so succeeds.
Login through Chromium works all the time.
I have seen the same on the CRS328 but only sporadically.
Does anybody have a suggestion how to solve this?
pe1chl
Wed Mar 06, 2019 4:05 pm
Indeed there really appears to be some bug. Not only are the existing connections lost after reboot (not working loose-tcp-tracking) but also I see firewall log messages that indicate that tracking of existing connections has been lost at some time even though te connections still exist.
(of course that was less of a problem when loose tracking was still working)
In my case it were TCP TLS connections (port 443) and the loss of those is often not catastrophic, they will be re-established without the user noticing, but in case of VoIP it could be different.
I hope MikroTik will look into this matter. I see no changelog entry that explains what is happening here.
admir
Wed Mar 06, 2019 7:06 pm
BUG – v.6.44 on ARM boxes RB3011 is losing IPSEC configuration
After upgrade of ARM boxes (RB3011) to latest stable version 6.44, IPSEC is not working.
Winbox GUI /ip ipsec section in is empty and no new config parameters can be added;
In console /ip ipsec export gives just info that all subsections can’t be exported.
osc86
Wed Mar 06, 2019 7:22 pm
I had the same problem.
Official response from support:
Yes, this confirms the issue is caused by some old 6.44beta version converting some of the configuration. And when you downgraded and upgraded again, it run into these issues.
I downgraded to 6.43, exported the config (and certificates), removed everything in /ip ipsec from the text file, fresh installed 6.44 and imported the config from the text file.
Making a backup of the router running 6.43 and importing it in 6.44 won't work.
Once 6.44 is installed, you have to redo the ipsec configuration by hand.
CCR1009-7G-1C-1S+ ROS6.45.7
Raumaster
Wed Mar 06, 2019 7:42 pm
All our APs are set to "no_country_set" since forever.
kalsze
Thu Mar 07, 2019 4:36 am
A bit more info: it appears (for me at least) that this problem crops up if the forward and return paths of the connections are somehow not symmetrical.
In my case, somebody disabled DHCP options 121 and 249 in our office router without telling me, so this is what was happening to the packets:
Forward path:
[ My PC ] ==(office LAN)==>
[ Main RouterBoard of my office (RouterOS 6.43.2) ] ==(office LAN)==>
[ OpenVPN endpoint RouterBoard (RouterOS 6.43.12) ] ==(OpenVPN connection)==>
[ Remote RouterBoard (RouterOS 6.44) ] ==(bridge-local)==>
[ Raspberry Pi ]
Return path:
[ Raspberry Pi ] ==(bridge-local)==>
[ Remote RouterBoard ] ==(OpenVPN connection)==>
[ OpenVPN endpoint RouterBoard ] ==(office LAN)==>
[ My PC ]
Note how the "Main RouterBoard of my office" is skipped in the return path. This is because my OpenVPN endpoint RouterBoard and my PC are actually in the same office LAN.
The Main RouterBoard used to serve out DHCP options 121 and 249 that tell PCs on the office LAN to just use the OpenVPN endpoint RouterBoard as gateway for reaching the Remote RouterBoard's bridge-local network.
Instead, with those DHCP options disabled, my PC sent packets to the Main RouterBoard first because its the default route, then, the Main RouterBoard (with its own `/ip route` rule) re-routed the packets to the OpenVPN endpoint RouterBoard. My Raspberry Pi would reply directly to my PC's IP (remember, no NAT'ing), and the packet eventually reaches the OpenVPN endpoint RouterBoard, which sends the reply packet directly to my PC, without going through the Main RouterBoard.
Once I re-enabled those DHCP options, the Main RouterBoard of my office is skipped in the forward path as well, so the forward and return paths are symmetrical again, and SSH is working again without having to allow "invalid" packets through the Remote RouterBoard. Still, I don't understand why the Remote RouterBoard can be sensitive to path symmetry.
tarcisionmjr
Thu Mar 07, 2019 5:48 am
/interface print
unfortunately, I had to go back to version 6.43.12, the CRS317, which turned out to be good again and did not crash or give graphics anymore ...
mikrotik friends check it out on CRS317 that has problems with version 6.44 ...
admir
Thu Mar 07, 2019 11:12 am
The same IPSEC config problem on some RB2011 (mipsBE) device too.
Console output:
/ip ipsec profile> add .....
error - contact MikroTik support and send a supout file
/ip ipsec export
#error exporting /ip ipsec mode-config
#error exporting /ip ipsec peer
#error exporting /ip ipsec policy group
#error exporting /ip ipsec profile
#error exporting /ip ipsec proposal
#error exporting /ip ipsec identity
#error exporting /ip ipsec settings
Upgrade was done from latest stable 6.43.12 to next release stable 6.44.
MikrotikBGSHOP
Thu Mar 07, 2019 6:24 pm
I am wondering too
Not a bug.
Interface for new PWR line adapter comming next months.
hAP mini & hAP lite has it. Basicly power the device and transfer data via microusb port.
Sent from my SM-G950F using Tapatalk
MikrotikBGSHOP
Fri Mar 08, 2019 1:21 pm
I am wondering too
Not a bug.
And the new powerline with microusbImage
nostromog
Fri Mar 08, 2019 2:31 pm
Also the mAP Lite 2nd (at least mine, revision r2. I'm not sure about older ones)
I just bought a few and they came with this surprise. :)
Alastair
Fri Mar 08, 2019 2:50 pm
Will UK users be disappointed again though, with no UK variant plug? :/
Jotne
Fri Mar 08, 2019 2:55 pm
Maybe its time for UK to change to EU plug.
Ahh, I did forget UK goes out of EU :)
I have travel around the world and UK plug is one the ugliest and largest plug out there....
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Kindis
Fri Mar 08, 2019 3:34 pm
I live in Sweden but I must say the UK plug is one of the bulkiest to work work with it is also one if the smartest with fuse in the plug and designed for a large contact surface and also be child friendly.
raffav
Fri Mar 08, 2019 4:47 pm
They say that is the most safety Plug, as you need to insert the earth ping to "unlock" the energizing plug as well with this individually surge protection with fuses another handly about the UK plug is that they have a switch so y can shut down the plug without removing the plug I think this clever move, the only downside of this is that you lose a lot of space, so in a wall outlet can be only 2 plug
WirelessRudy
Fri Mar 08, 2019 5:07 pm
Houses with proper electrical installation like most in (West-?)Europe have fuses and differential to protect the user. An extra protection in the plug is overdone.
Apart from that, the flat pins in fact are worse for surface contact then round. With round pins there is always change for better contact with the clamp then when its flat.
No, the English design is not the best.... we remove them where we can (many English customers in this Western European country I work!)
Rudy R. Puister
eworm
Fri Mar 08, 2019 7:22 pm
This requires the new hardware, old mAP lite can not get this from software.
raffav
Fri Mar 08, 2019 7:24 pm
I still do not get what really is this new power line.
nostromog
Fri Mar 08, 2019 9:58 pm
If you compare this Image (the block diagram of a mAP Lite
with this Image you will see that what they have presented
is a power supply that turns a mAP lite into a PL7411-2nD. I hope it will not be too expensive, because I don't need it
but I would like to play with it, and I have a couple of mAP lites and a hAP ac lite to play with :D
Sorry I can't find a way to resize images
CZFan
Sat Mar 09, 2019 1:02 am
Hi
I have noticed on this forum that many times the problem is not due to updates, but in fact due to incorrect configurations.
Maybe a suggestion will be to engage with one of your registered dealers / re-sellers which are also Mikrotik Certified to look into the issue (I am both).
This way the Mikrotik Certified consultants can also gain financially and the distributor also supports the registered dealers / re-sellers
MTCNA, MTCTCE, MTCRE & MTCINE
DenisPDA
Sat Mar 09, 2019 10:29 pm
Greetings
Can you clarify what the error is?
Borage
Sun Mar 10, 2019 3:47 am
Static host route is very unreliable in this release. I have a web server that I need to reach through another gateway and it works sporadically.
I didn't count but it works approx. 30 seconds and then a timeout for 30 seconds and so on.
DenisPDA
Sun Mar 10, 2019 8:40 am
I confirm
This is a firewall problem.
susoldmitriy
Sun Mar 10, 2019 9:08 pm
hi all. i have a problem with dude 6.44. I will stopped dude and have problem. router CCR1009-7G-1C-1S+
>dude print
enabled: no
data-directory: disk1/dude.db
status: applying settings: disabling: waiting for config changes to
flush (12061435 bytes in queue)
what i can to do?
bitdoctor
Mon Mar 11, 2019 7:02 am
!) ipsec - added new "identity" menu with common peer distinguishers;
!) ipsec - removed "users" menu, XAuth user configuration is now handled by "identity" menu;
Upgrade (via Terminal) from 6.43.12 Stable to 6.44 Stable on CRS125-24G-1S and RB450G.
Upgrade went smooth, but on devices that had IPSec configured, WebFig still shows the old Users menu (now empty) and does not show the new Identity menu. Under Terminal, the "/ip ipsec identity" was created. All previously configured IPSec tunnels and RW logins are working without problem.
On other devices that had no IPSec configured, the WebFig Users menu was removed and the new Identity menu is shown as expected.
Askey307
Mon Mar 11, 2019 8:22 am
Hi
@CZFan
Not sure if you read the thread properly, however, we're also both and all of us are at least up to MTCRE. I also cannot share the config of our clients due to a Non-Disclosure agreement. This is companies that's been using these units quite a lot, we talk few thousands of the routers especially the RB750 and 951G. We don't touch their config which work. When they downgrade with the exact same config everything works. When they use 6.44, it stops working. Even our in house Mikrotik Certified Trainer looked at it and suggested to downgrade.
So config is not a problem.
Currently all our clients are happy with 6.43.8. No issues reported or anything. We'll keep it that way till another update has been released.
Also you're welcome to look at our site to get some input to what we do and what we are:)
www.miro.co.za
Deantwo
Mon Mar 11, 2019 10:08 am
Without knowing even a little bit about your configuration, no one here will be able to help identify the issue. Since we don't even know which router features you are using (bridge, ike1, ike2, IPsec, etc.), it is hard to know what might have changed in the update that can cause you issues.
If you can't share the config here and believe it is a bug in the update, make a supout while the issue is occurring and mail it to support@mikrotik.com. Then they can help you troubleshoot it and find the issue.
Askey307
Mon Mar 11, 2019 10:17 am
@DeanTwo
Wer'e currently awaiting Mikrotik's response for several cases.
I just posted here as some feedback regarding our finds with the firmware. Not looking for a fix:) more also trying to see if others experiencing the same and what the outcome was. Only feedback I got so far is their looking into it. None since then.
cdemers
Mon Mar 11, 2019 7:18 pm
Been experiencing random ethernet link negotiation problems since this version. Have a rb1100x2 and a wireless wire dish refusing to keep a gigabit connection. And on a ccr1036 unable to negotiate 100mbps with a Cisco router, have to set speed and duplex. Everything fine on older version.
Just a couple examples.
Sent from my SM-A520W using Tapatalk
kayander
Mon Mar 11, 2019 7:52 pm
Upgraded hAP ac^2 with an active l2tp/IPsec connection, also some CRS305, CRS326, hEX. Had no issues whatsoever (ipSec input accept rules existed)
Thanks to Mikrotik for the hard work on supporting their great product and pushing such big updates. Keep it up!
Отправлено с моего Mi A1 через Tapatalk
GWerewolf
Mon Mar 11, 2019 9:39 pm
Is it ok that we have < 3 MB of free space on our 16 MB devices after update?
Caci99
Tue Mar 12, 2019 11:30 am
It depends on your files, for example on mine Hap ac lite there is nearly 4MB. On these boards the update package is saved on RAM instead of HDD.
-Toni-
Don't crash the ambulance, whatever you do
rushlife
Tue Mar 12, 2019 12:24 pm
ip neighbor
In most cases I don't see ip address.
All mikrotiks around are on the same version, 6.44 stable.
"Discovery interace" is set for "all" on all my devices.
kadety
Tue Mar 12, 2019 3:29 pm
I had problem with IPSEC VPN connection. This 6.44 created one dynamic peer, and not working my VPN's with dynamic IP.
N0X
Tue Mar 12, 2019 8:13 pm
Hi, i update my SXT SQ lite 5 to this new version, i use in ethernet ARP ¨reply-only¨ and i have problems, random clients lost the acces for long time, is random ... i put ARP to ¨enable¨ and all is ok ... in other versions of routerOS i don´t have this problem ...
jokke
Wed Mar 13, 2019 2:12 pm
No reply to the issues observed in comment #148 and Comment #183?
I see the problems as well.
If SNMP is active, I see "snmp,warning timeout while waiting for program 20" in the logs.
All CLI interaction touching the interfaces in any way hangs.
I.e.
/interface print
Must be Ctrl+C'ed.
/export
# mar/13/2019 13:07:54 by RouterOS 6.44
# software id = QS0J-S1KQ
# model = CRS328-24P-4S+
# serial number = xxxxxxxxx
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
#interrupted
must be Ctrl+C'ed, and prints the #interrupted sequence after Ctrl+C
emils
Thu Mar 14, 2019 1:12 pm
New version 6.44.1 has been released in stable RouterOS channel:
viewtopic.php?f=21&t=146485
Users browsing this forum: Pea, zBear and 8 guests
