jaredharet
How to make TTL=1
Mon Mar 19, 2007 11:55 pm
How to make TTL=1
I want to give internet on my users with TTL=1
yancho
Tue Mar 20, 2007 12:02 am
You can't call this internet. It would be access to next router :lol:
jaredharet
Tue Mar 20, 2007 12:05 am
I want deny access to next router.
janisk
Tue Mar 20, 2007 8:54 am
you can do that in /ip firewall mangle
edit:
erm.. test before implementing if everything works as you intended :roll:
do not cut yourself out
Ghassan
Tue Mar 20, 2007 11:07 pm
does changing TTL affect on the speed of internet !!
because when changing TTL from 64 to 255 at chain=output , i got a good opening websites .
is there any idea !
but it is not recommended to change your TTl to 1 .
normis
Wed Mar 21, 2007 8:56 am
chain output does not affect your customer networks :D it only affects router's communication to outside network.
the only chain that can affect your customers network is FORWARD
janisk
Wed Mar 21, 2007 10:32 am
you can use TTL=1 if you use it carefully - that way you can block all those users that are using some network devices other than switches (bridges). many interesting AP that do not use bridging will fail too.
Users browsing this forum: adimihaix, Bing [Bot], vingjfg and 107 guests
