akarpas
huge amount of TCP DNS queries from outside
Sat Mar 02, 2019 12:25 pm
So we found that router was compromised so we have cleaned it and properly secured, but from this moment router is receiving a huge amount of packets coming form outside to DNS TCP , afcourse as i have said all this is secured and outside DNS queries are dropped. But all this traffic comming to my router is pissing me of how to fight this , can i some how redirect or i have to call ISP and ask to change IP?
By the way cpu is ok but memory is almost used in full
BRMateus2
Re: huge amount of TCP DNS queries from outside
Sat Mar 02, 2019 3:50 pm
Your router might have been used in DNS amplification attacks.
The ISP should provide you an drop hole for the possible spoofed IP.
anav
Sat Mar 02, 2019 3:59 pm
Please define cleaned it and secured it? That response may be inadequate!
cdemers
Sat Mar 02, 2019 4:31 pm
Would suggest export configuration, netinstall with latest firmware. And add back what you need from the old configuration. Default configuration is secure and a good point to start from.
I never trust a router that has been comprised even if it was just a password hack.
And good time to clean up the configuration of anything that is not needed.
Sent from my SM-A520W using Tapatalk
anav
Sat Mar 02, 2019 4:47 pm
I disagree, I would start a new configuration (with latest firmware for netinstall) and not use anything from a compromised configuration.
cdemers
Sun Mar 03, 2019 5:17 am
That's what I just said. I didn't say import the whole old configuration, that would be pointless.
anav
Sun Mar 03, 2019 5:57 am
I see where you stated start with default configuration, the waters were muddied when you started by saying export configuration.
All is good! My apologies.
