inatec
[OS 6.43.12] 4x CRS317-1G-16S: MSTP problems between two (link up / down)
Mon Mar 04, 2019 11:32 am
we have problems between two switches and MSTP. The interfaces between them goes up and down every few seconds and sw-core-lan-04 is isolated for round about 2 seconds. The sw-core-lan-03 shows than: root-bridge: yes
  • Some base infos:
  • 4 x CRS317-1G-16S
  • All with RouterOS firmware 6.43.12
  • We use SFP+ modules from Ubiquity and Allnet
  • Bridge VLAN core-lan
  • Bridge VLAN management
  • sw-core-lan-01
sw-core-lan-01] >  /interface bridge print
 0 R ;;; defconf
     name="core-lan" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto
     mac-address=74:4D:28:3D:38:01 protocol-mode=mstp fast-forward=yes igmp-snooping=no auto-mac=no
     admin-mac=74:4D:28:3D:38:01 ageing-time=5m priority=0x1000 max-message-age=20s forward-delay=15s
     transmit-hold-count=6 region-name="QHA07" region-revision=1 max-hops=20 vlan-filtering=yes ether-type=0x8100
     pvid=1 frame-types=admit-all ingress-filtering=no dhcp-snooping=no
 1 R name="management" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto
     mac-address=74:4D:28:3D:38:01 protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes
     ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no
     dhcp-snooping=no
sw-core-lan-01] > /interface print detail
     14  RS ;;; sw-core-03-lan-p14
       name="sfp-sfpplus14" default-name="sfp-sfpplus14" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1592
       max-l2mtu=10218 mac-address=74:4D:28:3D:37:FE last-link-down-time=feb/28/2019 22:50:19
       last-link-up-time=feb/28/2019 22:50:20 link-downs=1
15  RS ;;;sw-core-lan-04-p16
       name="sfp-sfpplus15" default-name="sfp-sfpplus15" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1592
       max-l2mtu=10218 mac-address=74:4D:28:3D:37:FF last-link-up-time=feb/26/2019 17:18:01 link-downs=0
16  RS ;;;sw-core-lan-02-p15
       name="sfp-sfpplus16" default-name="sfp-sfpplus16" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1592
       max-l2mtu=10218 mac-address=74:4D:28:3D:38:00 last-link-up-time=feb/26/2019 17:17:29 link-downs=0
sw-core-lan-01] >  /interface bridge monitor core-lan
                       ;;; defconf
                    state: enabled
      current-mac-address: 74:4D:28:3D:38:01
              root-bridge: yes
           root-bridge-id: 0x1000.74:4D:28:3D:38:01
  regional-root-bridge-id: 0x1000.74:4D:28:3D:38:01
           root-path-cost: 0
                root-port: none
               port-count: 12
    designated-port-count: 11
  • sw-core-lan-02
sw-core-lan-02] > /interface bridge print
 0 R ;;; defconf
     name="core-lan" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:A3:5B:33
     protocol-mode=mstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=CC:2D:E0:A3:5B:33 ageing-time=5m
     priority=0x2000 max-message-age=20s forward-delay=15s transmit-hold-count=6 region-name="QHA07"
     region-revision=1 max-hops=20 vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-all
 1 R name="management" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:A3:5B:33
     protocol-mode=none fast-forward=no igmp-snooping=no auto-mac=yes ageing-time=5m vlan-filtering=no
     dhcp-snooping=no
sw-core-lan-02] > /interface print detail
     14  RS ;;; sw-core-lan-04-p14
       max-l2mtu=10218 mac-address=CC:2D:E0:A3:5B:30 last-link-up-time=feb/26/2019 17:18:01 link-downs=0
15  RS ;;; sw-core-lan-01-p16
       max-l2mtu=10218 mac-address=CC:2D:E0:A3:5B:31 last-link-up-time=feb/26/2019 17:17:29 link-downs=0
16  RS ;;; sw-core-lan-03-p15
       max-l2mtu=10218 mac-address=CC:2D:E0:A3:5B:32 last-link-down-time=mar/04/2019 08:38:59
       last-link-up-time=mar/04/2019 08:39:00 link-downs=33
sw-core-lan-02] >  /interface bridge monitor core-lan
                       ;;; defconf
                    state: enabled
      current-mac-address: CC:2D:E0:A3:5B:33
              root-bridge: no
           root-path-cost: 0
                root-port: sfp-sfpplus15
               port-count: 12
        mst-config-digest: 36a394ba96d689fdbdc3264fea68bdb6
  • sw-core-lan-03
sw-core-lan-03] >  /interface bridge print
 0 R ;;; defconf
     name="core-lan" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:A3:5A:DE
     protocol-mode=mstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=CC:2D:E0:A3:5A:DE ageing-time=5m
     priority=0x3000 max-message-age=20s forward-delay=15s transmit-hold-count=6 region-name="QHA07"
 1 R name="management" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=CC:2D:E0:A3:5A:DE
     protocol-mode=rstp fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000
     max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
sw-core-lan-03] > /interface print detail
14  RS ;;; qh-a07-sw-core-01-p14
       max-l2mtu=10218 mac-address=CC:2D:E0:A3:5A:DB last-link-down-time=feb/28/2019 23:46:52
       last-link-up-time=feb/28/2019 23:46:53 link-downs=5
15  RS ;;; qh-a07-sw-core-02-p16
       max-l2mtu=10218 mac-address=CC:2D:E0:A3:5A:DC last-link-down-time=mar/04/2019 08:39:10
       last-link-up-time=mar/04/2019 08:39:11 link-downs=27
16  RS ;;; qh-a07-sw-core-04-p15
       max-l2mtu=10218 mac-address=CC:2D:E0:A3:5A:DD last-link-down-time=mar/04/2019 10:21:05
       last-link-up-time=mar/04/2019 10:21:06 link-downs=3164
sw-core-lan-03] > /interface bridge monitor core-lan
                       ;;; defconf
                    state: enabled
      current-mac-address: CC:2D:E0:A3:5A:DE
              root-bridge: no
           root-path-cost: 0
                root-port: sfp-sfpplus14
               port-count: 13
    designated-port-count: 10
  • sw-core-lan-04
sw-core-lan-04] > /interface bridge print
 0 R ;;; defconf
     name="core-lan" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=74:4D:28:39:01:85
     protocol-mode=mstp fast-forward=yes igmp-snooping=no auto-mac=no admin-mac=74:4D:28:39:01:85 ageing-time=5m
     priority=0x4000 max-message-age=20s forward-delay=15s transmit-hold-count=6 region-name="QHA07"
 1 R name="management" mtu=auto actual-mtu=1500 l2mtu=1592 arp=enabled arp-timeout=auto mac-address=74:4D:28:39:01:85
     protocol-mode=none fast-forward=yes igmp-snooping=no auto-mac=yes ageing-time=5m vlan-filtering=no
     dhcp-snooping=no
sw-core-lan-04] > /interface ethernet print  detail
14 RS ;;; qh-a07-sw-core-lan-02-p14
      name="sfp-sfpplus14" default-name="sfp-sfpplus14" mtu=1500 l2mtu=1592 mac-address=74:4D:28:39:01:82 orig-mac-address=74:4D:28:39:01:82 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
      loop-protect-send-interval=5s loop-protect-disable-time=5m auto-negotiation=yes advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full full-duplex=yes tx-flow-control=off rx-flow-control=off speed=10Gbps
      bandwidth=unlimited/unlimited switch=switch1
15 RS ;;; qh-a07-sw-core-lan-03-p16
      name="sfp-sfpplus15" default-name="sfp-sfpplus15" mtu=1500 l2mtu=1592 mac-address=74:4D:28:39:01:83 orig-mac-address=74:4D:28:39:01:83 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
16 RS ;;; qh-a07-sw-core-lan-01-p15
      name="sfp-sfpplus16" default-name="sfp-sfpplus16" mtu=1500 l2mtu=1592 mac-address=74:4D:28:39:01:84 orig-mac-address=74:4D:28:39:01:84 arp=enabled arp-timeout=auto loop-protect=default loop-protect-status=off
sw-core-lan-04] > /interface bridge monitor core-lan
                       ;;; defconf
                    state: enabled
      current-mac-address: 74:4D:28:39:01:85
              root-bridge: no
           root-path-cost: 0
                root-port: sfp-sfpplus16
               port-count: 13
In our log, we have:
Mar  4 10:00:52 sw-core-lan-03 sfp-sfpplus16 link up (speed 10G, full duplex)
Mar  4 10:01:22 sw-core-lan-04 sfp-sfpplus15 link down
Mar  4 10:01:23 sw-core-lan-04 sfp-sfpplus15 link up (speed 10G, full duplex)
Mar  4 10:01:26 sw-core-lan-03 sfp-sfpplus16 link down
Mar  4 10:01:27 sw-core-lan-03 sfp-sfpplus16 link up (speed 10G, full duplex)
Mar  4 10:01:42 sw-core-lan-04 sfp-sfpplus15 link down
Mar  4 10:01:43 sw-core-lan-04 sfp-sfpplus15 link up (speed 10G, full duplex)
Mar  4 10:01:48 sw-core-lan-03 sfp-sfpplus16 link down
Mar  4 10:01:49 sw-core-lan-03 sfp-sfpplus16 link up (speed 10G, full duplex)
Mar  4 10:01:53 sw-core-lan-03 sfp-sfpplus16 link down
Mar  4 10:01:54 sw-core-lan-03 sfp-sfpplus16 link up (speed 10G, full duplex)
Mar  4 10:02:20 sw-core-lan-03 sfp-sfpplus16 link down
Mar  4 10:02:21 sw-core-lan-03 sfp-sfpplus16 link up (speed 10G, full duplex)
Mar  4 10:02:24 sw-core-lan-04 sfp-sfpplus15 link down
Mar  4 10:02:26 sw-core-lan-04 sfp-sfpplus15 link up (speed 10G, full duplex)
Maybe, we have a configuration error, or one of the SFTPs are bad.
Any suggestions ?
AVA
Re: [OS 6.43.12] 4x CRS317-1G-16S: MSTP problems between two (link up / down)
Tue Mar 19, 2019 4:43 pm
looks like a link problem, not an mstp error. We've observed on 10gbe links between 2 CRS317, that you have to use autonegotiation for stable links. With static settings 10gbe fullduplex we had link flappings like you.
omega-00
Sat Mar 23, 2019 3:31 am
I've just observed the exact same issue going from v6.42.10 -> v6.43.13 on a CCR1036
SFP+2 interface with a DAC cable connected to a CRS317 saw the link showing up and down according to the remote side while on the CCR it showed up the whole time.
Ended up downgrading to v6.42.12 and the issue went away.
brightwifi.com | mikrotik-routeros.com | MTCNA,MTCWE.MTCTCE | Give karma where due
Users browsing this forum: MSN [Bot] and 84 guests
