DanielJB
RB4011 WiFi showing only 3 chains [SOLVED]
Sat Mar 09, 2019 4:08 pm
Does anyone else with a RB4011 WiFi variant on RouterOS 6.44 find stats shows only strength from only 3 out of 4 chains for the 5GHz radio, ie no signal-strength-ch3, despite rx-chains and tx-chains being set to 0,1,2,3?
/interface wireless registration-table print stats
0 ... signal-strength-ch0=-70dBm signal-strength-ch1=-62dBm signal-strength-ch2=-64dBm ...
1 ... signal-strength-ch0=-93dBm signal-strength-ch1=-91dBm signal-strength-ch2=-87dBm ...
chechito
Re: RB4011 WiFi showing only 3 chains
Sun Mar 10, 2019 11:51 am
are you using routeros 6.44 ?
DanielJB
Sun Mar 10, 2019 1:44 pm
Yes, using RouterOS 6.44.
lipo
Tue Mar 19, 2019 11:12 pm
ROS 6.44beta61
all 4 chains..
signal-strength-ch0=-81dBm
signal-strength-ch1=-80dBm
signal-strength-ch3=-82dBm
DanielJB
Wed Mar 20, 2019 12:57 pm
Thanks lipo. Can you check on RouterOS 6.44.1?
It may be that Mikrotik removed the updated WiFi driver as on 6.44.1, I still see:
 0 interface=wlan1 mac-address=B0:23:43:F0:CA:09 ap=no wds=no bridge=no rx-rate="526.5Mbps-80MHz/2S" tx-rate="36Mbps"
   packets=262,309 bytes=108304,56296 frames=221,278 frame-bytes=109546,55611 hw-frames=222,550 hw-frame-bytes=115004,73379
   tx-frames-timed-out=0 uptime=22m17s last-activity=34s730ms signal-strength=-60dBm@6Mbps signal-to-noise=45dB
   signal-strength-ch0=-68dBm signal-strength-ch1=-63dBm signal-strength-ch2=-68dBm
   strength-at-rates=-60dBm@6Mbps 18m10s980ms,-56dBm@12Mbps 34s730ms tx-ccq=76% p-throughput=22738 last-ip=10.39.0.197
   802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm management-protection=no
   wmm-enabled=yes tx-rate-set="OFDM:12-54 BW:1x-4x SGI:1x-4x HT:1-15 VHTMCS:SS1=0-9,SS2=0-9"
 1 interface=wlan1 mac-address=98:3B:8F:9F:A1:C0 ap=no wds=no bridge=no rx-rate="468Mbps-80MHz/2S" tx-rate="702Mbps-80MHz/2S"
   packets=15049,8715 bytes=14975465,2202145 frames=10307,8602 frame-bytes=15100438,2153541 hw-frames=21425,8672
   hw-frame-bytes=28815663,2500637 tx-frames-timed-out=0 uptime=16m2s last-activity=0ms signal-strength=-57dBm@6Mbps
   signal-to-noise=48dB signal-strength-ch0=-68dBm signal-strength-ch1=-60dBm signal-strength-ch2=-61dBm
   strength-at-rates=-57dBm@6Mbps 1m850ms,-55dBm@12Mbps 1m890ms,-55dBm@18Mbps 1m770ms,-54dBm@24Mbps 48s880ms,-54dBm@36Mbps 40s70ms,-
                  57dBm@48Mbps 32s900ms,-57dBm@54Mbps 32s390ms
   tx-ccq=89% p-throughput=483056 last-ip=10.39.0.186 802.1x-port-enabled=yes authentication-type=wpa2-psk encryption=aes-ccm
   group-encryption=aes-ccm management-protection=no wmm-enabled=yes
   tx-rate-set="OFDM:12-54 BW:1x-8x SGI:1x-8x HT:1-15 VHTMCS:SS1=0-9,SS2=0-9 VHTMCS160:SS1=0-9,SS2=0-9"
DanielJB
Wed Mar 27, 2019 1:47 pm
The issue is resolved in 6.45beta20.
Users browsing this forum: No registered users and 4 guests
