dadach
Help with connecting 2 Mikrotik routers
Tue Mar 12, 2019 8:20 am
My setup is as follows:
Mikrotik1, DMZ from the cable router. 192.168.88.0/24 network there
Mikrotik2, behind NAT at work/housing campus, also 192.168.88.0/24
What would be the best way to get the machine from the Mikrotik1 to show up as local behind the Mikrotik2 network?
Do I have to change the network at one of the places to 89 or something else from 88?
Thanks!
vilpalu
Re: Help with connecting 2 Mikrotik routers
Tue Mar 12, 2019 10:26 am
yes, if you want to use two routers as routers you need change one of them network to 192.168.X.0/24 where X is any number from 0-255 except 88. also you can make one network using two mikrotiks - second mikrotik must be changed to bridge mode.
dadach
Tue Mar 12, 2019 10:41 am
Thank you. I forgot to mention that the mikrotik routers are about 1000 miles away from one anohter :) one is at my house, other is in the country i work in. thanks!
