cmdorexe
macros bug
Fri Mar 22, 2019 1:34 am
as example if+else not work
global test yes
/log info [:typeof $test]
/log info [:typeof yes]
/log info ( yes = yes )
/log info ( $test = yes )
global print do={
  if ( $test = yes) do={/log info yes} else={/log info no}
$print
global test no
$print
I'm not understand why? Anybody have some sojestion with it.
I know nothing except the fact of my ignorance. (Socrates)
Van9018
Long time Member
Long time Member
Re: macros bug
Fri Mar 22, 2019 5:03 am
This page: https://wiki.mikrotik.com/wiki/Manual:S ... _statement
says the syntax of the if statement should be prefixed with a colon
:local myBool true;
:if ($myBool = false) do={ :put "value is false" } else={ :put "value is true" }
cmdorexe
Re: macros bug
Fri Mar 29, 2019 5:10 pm
It's not working in scripts with log. if i did it in terminal it's work perfect.
Chupaka
Re: macros bug
Fri Mar 29, 2019 11:02 pm
Any details? Because my "details" work fine...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
BlackVS
Re: macros bug
Wed Apr 03, 2019 2:50 pm
Works in my case (the same result as in Chupaka) - CCR1009, the last firmware. Just copied your code in script called test_if and called it from terminal.
Chupakabra303
Re: macros bug  [SOLVED]
Thu Apr 18, 2019 11:42 am
Declare a global variable before use in function!
global print do={
:global test
Jotne
Re: macros bug
Thu Apr 18, 2019 11:56 am
Will not work, you need to double quote yes like this:
if ( $test = "yes") do={/log info "yes"} else={/log info "no"}
To test things out:
:global test "yes"
:global test
if ( $test = "yes") do={:put "true"} else={:put "false"}
prints true to screen
and
:global test "no"
:global test
prints false to screen
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
cmdorexe
Re: macros bug
Thu Jun 27, 2019 3:13 pm
it's string not bool! I'm write about bool's in scripts!
Jotne
Re: macros bug
Thu Jun 27, 2019 7:46 pm
Then I do not understand what you try to do.
MikroTik->Splunk
Chupaka
Re: macros bug
Sat Jun 29, 2019 7:58 am
So what's exactly not working?
cmdorexe
Re: macros bug
Wed Jul 17, 2019 8:04 pm
Jotne
Re: macros bug
Wed Jul 17, 2019 9:13 pm
@cmdorexe
You do just show some code and does not respond to the question. What does not work?
If you try to run a script from cli, you need to wrap it in {}
Example
:local test "more"
:put $test
Needs to be
:local test "more"
:put $test
This do work also
:local test "more"
:put $test
MikroTik->Splunk
Chupaka
Re: macros bug
Thu Jul 18, 2019 7:33 pm
Oh, I see. That will do the trick:
:global test yes
:global print do={
  :global test
$print
:global test no
$print
By ":global test" you're saying you need to use 'test' global var in current visibility scope (function body).
Chupaka
Re: macros bug
Thu Jul 18, 2019 7:35 pm
Or you can pass the var into function explicitly:
:global test yes
:global print do={
$print test=$test
:global test no
$print test=$test
cmdorexe
Re: macros bug
Fri Jul 19, 2019 8:45 am
wow n1ce trick. I never known.
Users browsing this forum: Baidu [Spider] and 9 guests
