hhoeth
ovpn-client and "IP packet with unknown IP version=0 seen"
Fri Mar 29, 2019 11:36 am
Hi!
I'm using /interface ovpn-client to connect to an openvpn server running on a Debian box. After upgrading from 6.43.7 to 6.44 my server logs are flooded with messages like this:
The server is running openvpn-2.4.0-6+deb9u3. The client config is:
add certificate=client.crt_0 cipher=aes256 connect-to=XXXXXXXXXXXXXXXXXXXXXXX.com mac-address=FE:DA:87:73:D7:6D name=v-0001 port=1195 user=nobody
The server config of one server is
mode server
tls-server
keepalive 10 60
status server.log
dev tun
proto tcp-server
local XXX.XXX.XXX.XXX
port 1195
cipher AES-256-CBC
user openvpn
group openvpn
persist-key
persist-tun
ca /path/to/ca.crt
cert /path/to/server.crt
key /path/to/server.key
dh /path/to/dh.pem
topology subnet
server 192.168.32.0 255.255.224.0
ccd-exclusive
client-config-dir /path/to/ips/
client-to-client
script-security 2
learn-address "/usr/bin/sudo /path/to/learn-address.sh"
I've got another server with the same problem and the following config:
mode server
tls-server
keepalive 30 240
status /var/log/openvpn/tcp.log
dev tun
proto tcp-server
port 1194
cipher AES-256-CBC
user openvpn
group openvpn
chroot /etc/openvpn/server/ips
persist-key
persist-tun
pkcs12 /etc/openvpn/server/server/XXXX.p12
dh     /etc/openvpn/server/server/dh4096.pem
ifconfig 10.1.0.1 10.1.0.254
route 10.1.0.0 255.255.0.0
push "route 10.0.0.0 255.255.0.0"
push "route 10.1.0.0 255.255.0.0"
ccd-exclusive
client-config-dir ./tcp/ # this is relative to the chroot
I haven't touched the configuration of either the servers or the clients. The only change was upgrading RouterOS. And I haven't seen any openvpn related entries in the changelogs. Any idea what's going on here?
Cheers,
Hendrik
hhoeth
Re: ovpn-client and "IP packet with unknown IP version=0 seen"
Tue Apr 02, 2019 11:45 am
I downgraded to 6.43.13 now, and the log messages are gone. I hope this gets fixed in stable.
dibatech
Thu May 30, 2019 11:02 am
Seeing the same.
CCR1009
6.44.3
hhoeth
Sun Aug 18, 2019 12:44 am
This fixed it for me:
/ip neighbor discovery-settings set discover-interface-list=none
Becache
Wed Sep 11, 2019 4:31 pm
Thank you. It is worked.
Users browsing this forum: MSN [Bot] and 78 guests
