andrewjoy
Unable to update firmware CSS 326-24G-2S+RM
Tue Apr 02, 2019 10:37 pm
Hi i am unable to software update this switch.
I have previously used the reset button to wipe the config.
The current firmware is 2.7p , i am trying to update to the latest that is 2.9.
No matter if i use the auto update feature or use the manual the switch will try the update fail and reboot to default settings.
I have tried from 2 machines.
k6ccc
Re: Unable to update firmware CSS 326-24G-2S+RM
Tue Apr 02, 2019 10:46 pm
Does the switch have internet connectivity ?
Sent from a $&@#% iPhone using Tapatalk
RB750Gr3, RB750r2, CRS326-24G-2S (in SwitchOS), CSS326-24G-2S, CSS106-5G-1S, RB260GS
Not sure if I beat them in submission, or they beat me into submission
Jim
andrewjoy
Tue Apr 02, 2019 10:50 pm
As far as i can tell it does yes , it can see the update , it downloads it , reboots and then is back to 2.7p with all settings reset.
timamplex
Sat Apr 20, 2019 12:39 am
Anyone found a solution to this? I've also had same issue. Even if I manually install and download the latest posted 2.9 build or a 2.8 build clicking "download and upgrade" reverts the switch back to 2.7p
Tim
andrewjoy
Thu May 16, 2019 5:05 pm
On mine the reset switch was stuck in. Took the board out and had a fiddle with it and confirmed it was no longer stuck in with a multimeter and it was fine then.
Users browsing this forum: No registered users and 2 guests
