Jotne
DHCP automatic dynamic to static
Wed Apr 03, 2019 3:41 pm
DHCP dynamic to static lease
I did search for a script that did convert dynamic lease to static lease, but did not find any good solution.
So I made a new script that is placed in the DHCP server settings and convert the dynamic IP to static IP.
Cut and past to:
IP->DHCP-Server->Select your dhcp server->Lease Script
PS this makes all IP static, no expedition.
# Created Jotne 2019 v1.2
# This scripts converts all DHCP release to static automatically
# It should run on all routerOS version
# Test if this is a Bound session and the lease is a dynamic one. Do not change older reservation
:if (($leaseBound=1) && ([/ip dhcp-server lease find where dynamic mac-address=$leaseActMAC]!="")) do {
# Get the lease number
	:local Lease [/ip dhcp-server lease find mac-address=$leaseActMAC]
# Get date and time
	:local date [/system clock get date]
	:local time [/system clock get time]
# Make the lease static
	/ip dhcp-server lease make-static $Lease
# Add date and time as a comment to show when it was seen first time
	/ip dhcp-server lease comment comment="$date $time" $Lease
# Send a message to the log
	:log info message="script=dhcp_static server=$leaseServerName IP=$leaseActIP MAC=$leaseActMAC"
If you like to start with converting all current dynamic IP to static in one go, run this from command line.
:foreach Lease in=[/ip dhcp-server lease find dynamic] do={
	:local Name [/ip dhcp-server lease get $Lease host-name]
	/ip dhcp-server lease comment comment="$date $time $Name" $Lease
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
bigmayo
Re: DHCP automatic dynamic to static
Sun Jan 12, 2020 12:58 pm
Nice script so far, but at:
I just get this in log:
script=dhcp_static server= IP= MAC=
any idea why the server ip and mac keeps empty?
sopyan0807
Sat Jan 25, 2020 8:19 am
Thank you this script is useful
Joni
Sat Jan 25, 2020 6:30 pm
How about just extending the DHCP lease time to one month, so unless your device is offline for a month it will retain its IP address (and if you have lots of guests then setup a bigger subnet).
arielf
Sat Apr 25, 2020 7:24 pm
excellent script, works great
Could you add in comment, the host name that appears from the lease?
Jotne
Sat Apr 25, 2020 10:35 pm
Host name will stay in the lease as host-name field.
But if you like to add it in the comment field as well, this should do:
# Created Jotne 2020 v1.3
# Get date and time
# Get host name
	:local Name [/ip dhcp-server lease get $Lease host-name ]
	:log info message="script=dhcp_static server=$leaseServerName IP=$leaseActIP MAC=$leaseActMAC name=$Name"
MikroTik->Splunk
Users browsing this forum: Vahur and 26 guests
