ian404
Help with hAP AC Lite basic config
Sat Apr 06, 2019 11:52 am
I wan't to disable management on all but port 5, connect ports 2,3 and 4 to port 1 via the switch chip so it acts as an unmanaged switch and connect the 2 wireless radios to a vswitch with port 1 - this is so anything connected physically to port 2,3,4 or anything connected to the SSIDs will pickup a DHCP lease from my router (a pfSense box on the the other side of the house which will be connected to port 1)
Hopefully that makes sense. I basically want to use the hAP ac lite as a wireless extender with a few wired connections on top. I've actually set up the above before but have spent ages struggling to do it a second time - I don't know if the way you would do the above has changed after updates. If anyone could give me some basic steps I'd be grateful - but I use Linux rather than Windows so I need to do this via the web config or the command line.
solar77
Long time Member
Long time Member
Re: Help with hAP AC Lite basic config
Sat Apr 06, 2019 12:18 pm
connect to the router from port 5,
remove port 2 to port 4 from local bridge (default name would be "bridge")
create a bridge. say "uplink", then add port 1 to port 4 to it
disable default DHCP client on port 1
done
ian404
Sun Apr 07, 2019 4:05 pm
Hi, thanks for your reply.
I'm a bit confused as that's quite different from my old device - but I'm also confused as my old device is configured in a way that doesn't seem familiar! So I'm not sure if I'm mis-remembering how I configured it or a firmware upgrade changed either how it is configured or how it is displayed to me.
Can anyone say if the way my old device is configured makes sense? Is this the best way to achieve my goals?
Bridge1:
ether1, ether2, ether3, ether4, wlan1, wlan2
Switch1:
ether1, ether2, ether3, ether4, ether5, switch1cpu
Firewall rule 1:
Allow management via ether5
Accept input ether5
Firewall rule 2:
Block management via Bridge1
Drop input Bridge1
DHCP Server:
dhcp1 ether5
