facubertran
Fail-Over
Fri Apr 12, 2019 3:52 am
Hello!
I share failover script for Mikrotik. Please if you find any bad report me.
https://guias.crenein.com/wp/?p=279
vecernik87
Long time Member
Long time Member
Re: Fail-Over
Fri Apr 12, 2019 4:01 am
ahahahahaha:
/tool fetch mode=https url="https://#####.com/Crenein-Install-FaOv.rsc"
/import file="Crenein-Install-FaOv.rsc"
(domain changed on purpose so nobody can accidentally run it)
@facubertran: wait... seriously? Do you expect anyone to download and run ambiguous script on their device? Why don't you just ask for ip, username and password straight away? :lol: (I know why - there might be firewall preventing access from WAN)
@everyone: If you are not aware,
/tool fetch
can be easily detected on the server thanks to "HTTP_USER_AGENT", therefore your router may be served different script, than the one which you see in the browser. Never ever run scripts without prior manual inspection.
facubertran
Re: Fail-Over
Fri Apr 12, 2019 6:33 pm
Sorry. Also you can download RSC file and you can inspect it. :wink: :wink:
facubertran
Re: Fail-Over
Fri Apr 12, 2019 6:58 pm
ahahahahaha:
/tool fetch
https://bitbucket.org/facubertran/crene ... rc/master/
Lupin
Re: Fail-Over
Mon Apr 22, 2019 10:43 pm
Can you explain, how it works?
facubertran
Re: Fail-Over
Tue Apr 23, 2019 4:02 am
It's very difficult. But the rule is. Probe - Fail action - Notification.
The probes are interface running status, gateway status, traffic in the interface, ICMP and HTTP. If all are fail, the script runn other script for notification and execute an action, for example, disable gateways in the route table.
plisken
Re: Fail-Over
Tue Apr 23, 2019 5:32 pm
Hello!
Copy the script into the window. Use not a link to another website please
facubertran
Re: Fail-Over
Thu Apr 25, 2019 11:37 pm
Hello!
There are several extensive files.
NetWorker
Re: Fail-Over
Fri Apr 26, 2019 1:41 am
:lol: :lol: :lol: :lol: :lol: :lol:
What he said!!
Besides, any script that doesn't fit in three or four posts is either a resource hog or poorly written. ;)
Users browsing this forum: No registered users and 6 guests
