ltsui
Mikrotik RB4011iGS+5HacQ2HnD 10G SFP+ port flapping
Fri Apr 12, 2019 11:45 am
I am using S+AO0005 active DAC and connected to Mellanox MCX-312A-XCBT.
When i logined in to WIN10, the 10G port is keeping up and down. I need manually disable and enable the 10G few times, then the port will come up.
Also i tired to connect this active DAC SFP+ from Mellanox 10G card Port1 to Port2, it is no any flapping.
ether11-sfpplus link up (speed 10G, full duplex)
ether11-sfpplus link down
Version is v6.44.2 and already hard code 10G Full duplex.
Is anyone else seeing port flapping on SFP+ port? Thanks.
nescafe2002
Long time Member
Long time Member
Re: Mikrotik RB4011iGS+5HacQ2HnD 10G SFP+ port flapping
Fri Apr 12, 2019 12:23 pm
S+AO0005 is supported, please generate supout.rif while device is malfunctioning and send to support with problem description.
jerry311
Tue Jun 04, 2019 7:19 pm
I am experiencing similar problem with 10G SFPs (Cisco, HP, Mellanox) and fiber.
Was there any solution to this one?
Thx!
jerr311
jerry311
Wed Jul 10, 2019 11:15 am
New release of RouterOS has some fixes related to SFP+ port:
6.45.1
*) rb4011 - fixed MAC address duplication between sfp-sfpplus1 and wlan1 interfaces (wlan1 configuration reset required);
*) sfp - fixed S-35LC20D transceiver DDMI readouts after reboot;
*) tile - improved link fault detection on SFP+ ports;
I am not sure which one fixed the flap problem but my connection on 10G is stable now, no magic needed to stop flapping.
(There were no other changes to the network.)
Users browsing this forum: minks and 152 guests
