MUM Europe 2020
MauiB
VPN
Fri Apr 12, 2019 12:20 pm
Good day,
Here is another issue. I have setup a VPN for the offices outside the main subnet. It was working fine for a couple of months and now it is giving a error message,see attached.
Thanks in advance
Bruntee3
Re: VPN
Sat Apr 13, 2019 4:55 pm
Sorry to hear about that. Which VPN are you using right now? Is this one free or paid? If paid how much do you spend per month? I think you should contact to the customer support asap for getting the instant solution you are facing right now. I also set up [REMOVED]. Overall, not bad. Reliable with good customer support.
Reason: You shall not advertise!
sindy
Re: VPN
Sat Apr 13, 2019 7:32 pm
It looks to me like a consequence of the "Windows is a service" approach, actually meaning "what worked yesterday won't work today without warning because we know better". So I'd first change the settings on Windows so that it would use only the particular VPN type you have configured on the server rather than trying all methods in sequence, and then I'd use the firewall rules on the VPN server (which I assume is Mikrotik since you post the question on this forum) to log whether the connection attempts actually reach the server. If they do, I'd start logging the particular VPN protocol on the Mikrotik and read the log created during the failed connection attempt. If they don't, I'd start investigating why.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
MauiB
Re: VPN  [SOLVED]
Mon Apr 15, 2019 5:09 pm
Good day,
Thank you everyone that tried to help. I have figured out my problem. It was a firewall rule config that was not correct.
neutronlaser
Re: VPN
Mon Apr 15, 2019 9:59 pm
Did you try restarting your computer? I find Windows sometimes just stops working with VPN but will work when rebooted.
Bruntee3
Re: VPN
Fri Aug 30, 2019 1:13 pm
Yeah, I also agree with you mate. This might happen but at that time if you restart your computer one time would be okey. VPN will start working again.
Users browsing this forum: No registered users and 124 guests
