MUM Europe 2020
reks2004
Port isolation VLAN overwritten
Sat Apr 13, 2019 5:51 am
hello guys ;)
I have little problem with port isolation in CRS226 and v6.43.12
When i making port isolation by changing the master port in interface settings.. then it automatic/dynamic add the vlan with this port to vlan section. This sounds good but it overwritten vlan(that is already there) id 4090 (changing ports membership of existing Vlan ID 4090 to port what i want to isolate).
How change ID which is chosen when i change master port in interface settings?
Change it after it's not possible because it is dynamic record..
Best regards,
reks2004
Re: Port isolation VLAN overwritten
Tue Aug 13, 2019 7:36 pm
up, anyone?
sindy
Tue Aug 13, 2019 9:10 pm
6.43.12 and master port in one sentence? I am confused. Post the export, I didn't get what are you trying to achieve and what doesn't work.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Users browsing this forum: No registered users and 60 guests
