MUM Europe 2020
neutronlaser
Backup doesn't restore - Just goes back to previous settings
Sun Apr 14, 2019 5:33 pm
I have a backup that was made with
/system backup save encryption=aes-sha256 password=password name="mybackup.backup"
I factory reset my router (the same router the backup was made from), dragged the file in with Winbox, and restored it.
However all that happens is the router reboots with the same default settings.
Any ideas?
neutronlaser
Re: Backup doesn't restore - Just goes back to previous settings
Mon Apr 15, 2019 12:19 am
:( sad
krisjanisj
Mon Apr 15, 2019 9:21 am
As stated in wiki it doesn't just end with uploading backup file to router, but You need to also load said backup with command:
/system backup load name=mybackup.backup
* Wager of "The Holy War" against users who don't paste their config/export/print into [code][/code] blocks
* Avid coffee consumer
* Provider of stupid solutions for simple problems
neutronlaser
Mon Apr 15, 2019 2:36 pm
I uploaded the file with Winbox, then right clicked it, selected Restore and chose my password, and pressed OK. It restarted but it did not restore my backup.
krisjanisj
Mon Apr 15, 2019 2:39 pm
Please send a supout.rif file from your router to support@mikrotik.com
neutronlaser
Mon Apr 15, 2019 3:09 pm
Thanks but there is no supout.rif file.
neutronlaser
Mon Apr 15, 2019 6:19 pm
Is it worth sending them my backup file?
nescafe2002
Long time Member
Long time Member
Mon Apr 15, 2019 9:26 pm
Generate supout.rif and then e-mail it to them. Include backup if you want. Support is offering to look at your case for free. Please supply anything you can to explain your case:
- what you are doing (apps, buttons, screen)
- what you are seeing
- what you expected to happen
- what happens instead
neutronlaser
Mon Apr 15, 2019 9:32 pm
Will do, thanks.
Users browsing this forum: Google [Bot], MSN [Bot] and 81 guests
