900mhzdude
who can I hire to get a export to work as an import an a clone
Mon Apr 15, 2019 9:24 pm
I exported the config file out of our core router
we have a backup same make and model
the issue is the main core router is running 6.34.4
the back up is running 6.40.8
I can't seem to downgrade it to 6.34.4 Mikrotik seems to have deleted the firmware from there website
Not the owner just work here so go easy on me but this is taking up too much of my time
anyone on here I can that knows what they're doing I can hire to help me clean up the export so I can import into the backup router in case something bad happens?
seems you hang on the firewall rules I tried removing the firewall part but still not importing all settings
Thanks,
jprietove
Trainer
Trainer
Re: who can I hire to get a export to work as an import an a clone
Mon Apr 15, 2019 10:43 pm
Sure a lot of people will be interested. You can also look here for someone near you:
https://mikrotik.com/consultants
Enviado desde mi Mi A2 mediante Tapatalk
CZFan
Mon Apr 15, 2019 11:50 pm
https://mikrotik.com/download/archive
MTCNA, MTCTCE, MTCRE & MTCINE
900mhzdude
Mon Apr 15, 2019 11:52 pm
yes I checked there if you click on 6.34.4 I get a 404 error
CZFan
Tue Apr 16, 2019 1:14 am
joegoldman
Long time Member
Long time Member
Tue Apr 16, 2019 3:10 am
the all-packages .zip files seem to work so you could download your architecture that way and then just upload the relevant packages that you have installed, bit of a round-a-bout way to do it though.
900mhzdude
Tue Apr 16, 2019 5:18 pm
none of the files in that zip are working for me
what file would you use for a CCR-1009-8G-15-15+
Thanks for the help btw
900mhzdude
Re: who can I hire to get a export to work as an import an a clone  [SOLVED]
Tue Apr 16, 2019 7:54 pm
I ended up fixing this issue by finding the old firmware on a driver site
then importing the config and then I upgraded 1 version at a time all the way to the latest version
Thanks for everyone's help
Users browsing this forum: andreasub, Bing [Bot], Google Feedfetcher, karlisi, krzysztofciupala, nostromog, qadir52786, wadaxafa and 186 guests
