So recently my cable modem ( Arris SB8200 ) gained LAG..
I created a bonding interface and set it for 802.3AD with 2 ports.. Im using a CCR-1009..
Everythign works. I see the data spread out across both boths..
BUT... My speeds went way down.. I have gigabit service and I speedtest.net at 950Mbps down.. With both links ( wires ) hooked up I only get 250Mbps... If I unhook one wire I get 950Mbps again.. So with one link I get 950Mbps with both links I get 250...
This seems like a really odd result. A LAG 802-3AD interface on a CCR-1009 can do 950Mpbs to one computer right ? Its not limited in some way like no fast track if I use a bonded interface right ?
I should be able to get 950Mbps on a speed test thru a LAG 802.3AD right ?
