MUM Europe 2020
mpixel
Unknown device in ARP list with IP and without MAC
Tue Apr 30, 2019 10:39 am
I have unknown device in ARP list.
With IP address but without MAC address.
Only Flag "dynamic"
How do I find out what this device is ?
I thought every device must have a mac address.
Jotne
Re: Unknown device in ARP list with IP and without MAC
Tue Apr 30, 2019 11:11 am
Does it show up in your DHCP-server?
/ip dhcp-server lease print
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
mpixel
Tue Apr 30, 2019 12:58 pm
I can´t see it in DHCP Leases.
You can see in attached pictures.
IP 10.10.110.31
Exiver
Tue Apr 30, 2019 1:17 pm
That happens when your router tries to reach that address but no device is answering (ARP)
You can easily try this out:
* Check /ip arp
* Try to ping an address which is not in use
* Check /ip arp again
mpixel
Tue Apr 30, 2019 6:11 pm
Why does my router try to reach that address?
I don´t have such ip address in DHCP.
ping 10.10.110.31
timeout
Exiver
Tue Apr 30, 2019 6:24 pm
It doesnt mean that only your router tried to reach that address. Could be some device in another subnet for example. The timeout is expected since that device is not reachable. It was just to show you that the entry appears in dhcp-server leases with only "D"-Flag and without mac-address...
mpixel
Tue Apr 30, 2019 6:37 pm
But how do I know which device is it in our network when I don't even know its MAC address?
Exiver
Thu May 02, 2019 2:35 am
The device is not in your network... Some other device has tested whether this ip is active or not. It seems to be not active. If you want to know which device asked for that ip you need to log arp messages on your L2 network and search them when somthing similar happens again..
mpixel
Fri May 03, 2019 3:25 pm
It happens continuously. Apparently some device is looped.
Will you advise me how to do this?
I don't know what to log. I want to know MAC address of this device -then I will be able to find a vendor and thereby reduce the list of possible devices narrowed down, for example, to printers or mobile phones
Users browsing this forum: No registered users and 19 guests
