In the Wiki link I can not find the explanation (https://wiki.mikrotik.com/wiki/Manual:C ... Management)
To be honest i have never tried this. But the caps mode should just have the advantage that the router is directly searching for a capsman server. Which firewall rules are applied needs to be tested tho. Do you need the caps mode or did you just ask because you have seen that option?
