Pericles
MK RB960PGS sfp Does Not Work with Fast Ethernet
Thu May 09, 2019 8:40 pm
I can not get my Mikrotik RB960PGS to work on the SFP port connected to a fast Ethernet port, I can get a link but I do not have internet access. Can you help me?
sindy
Re: MK RB960PGS sfp Does Not Work with Fast Ethernet
Mon May 13, 2019 7:34 pm
Is the SFP itself a FastEthernet one? hEX PoE is not mentioned at all in Mikrotik's SFP compatibility table, so hard to say whether it does or does not support FastEthernet speed on SFP at all. But if it does, it definitely needs the SFP to declare itself as an FE one.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Pericles
Thu May 16, 2019 6:32 pm
tks for hel
Users browsing this forum: AUsquirrel, Baidu [Spider], biomesh, eguun and 75 guests
