nickjail
Black list for failed login to IPSec VPN
Sat May 11, 2019 12:40 am
Hello!
Got a VPN Server on my router. Of course periodically someone tries to knock on it and I get tons of email messages before I add IP to block list.
I don't want to close ports. I want to make script that adds failed IPs to block list.
This command shows negotiation failed IPs
/log print where message~"negotiation"
This is what it shows (I've removed some digits from IP for not showing real IP):
apr/15 03:50:37 ipsec,error 216.xx.206.6 phase1 negotiation failed.
apr/16 03:31:44 ipsec,error 216.xx.206.118 phase1 negotiation failed.
apr/17 05:33:29 ipsec,error 216.xx.206.102 phase1 negotiation failed.
may/08 14:30:13 ipsec,error 122.xx.64.43 phase1 negotiation failed.
Does anyone knows how to make script based on command above that parse log and adds IP to IP list?
Any information how alternatively secure IPSec would be useful.
Thanks.
Jotne
Re: Black list for failed login to IPSec VPN
Sat May 11, 2019 11:29 am
Edit updated here: viewtopic.php?p=905420#p905420
Here you go
Create a script with name Find_IPSEC that is used to find all lines with negotiation failed last 5m, extract the IP and add it to a access list.
Find_IPSEC
# Created Jotne 2019 v1.1
# This script add ip of user who failed IPSEC negotiation to a block list for 30 day
# Schedule the script to run every 5 min
# It should run on all routerOS version
# Find all "negotiation failed" error last 5 min
:local loglist [:toarray [/log find  time>([/system clock get time] - 5m) message~"negotiation failed"]]
# for all error do
:foreach i in=$loglist do={
# find message
	:local logMessage [/log get $i message]
# find ip
	:local ip [:pick $logMessage 0 [:find $logMessage " "]]
# Add ip to accesslist
	/ip firewall address-list add address=$ip list=IPSEC timeout=30d
# Send a message to the log
	:log info message="script=IPSEC_failed src_ip=$ip"
Create a scheduler that do run the script Find_IPSEC every 5 min:
/system scheduler add interval=5m name="Find IPSEC" on-event=Find_IPSEC
Then add an access list high in your filter rules like this (change ether1 with your outside IP):
/ip firewall filter add action=drop chain=forward comment="Block wrong IPSEC" in-interface=ether1 src-address-list=IPSEC
You can change the timeout=24h to set it how long you will block all IP, or remove it to permanently block all IP
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
plisken
Sun Jul 28, 2019 7:58 pm
Very interesting application. I will definitely use this script. Thanks
Jotne
Thu Aug 08, 2019 8:03 pm
Edit: Updated see this post viewtopic.php?p=905420#p905420
Updated
Now also block user with these type of message:
SPI e14750001eda995ec not registred for 89.50.40.10[4500]
# Created Jotne 2019 v1.3
# This script add ip of user who with "IPSEC negotiation failed" and "SPI* not registered" to a block list for 24hour
# 1.3 added "Invalid exchange"
:local loglistN [:toarray [/log find  time>([/system clock get time] - 5m) message~"negotiation failed"]]
# for all error do
:foreach i in=$loglistN do={
# find message
	:local logMessageN [/log get $i message]
# find ip
	:local ipN [:pick $logMessageN 0 [:find $logMessageN " "]]
	/ip firewall address-list add address=$ipN list=IPSEC timeout=30d
	:log info message="script=IPSEC_failed src_ip=$ipN why=negotiation_failed"
# Find all "SPI* not registered"" error last 5 min
:local loglistS [:toarray [/log find  time>([/system clock get time] - 5m) message~"SPI.*not regist"]]
# for all error do
:foreach j in=$loglistS do={
# find message
	:local logMessageS [/log get $j message]
# find ip
	:local ipS [:pick $logMessageS ([:find $logMessageS "for "]+4) [:find $logMessageS "["]]
	/ip firewall address-list add address=$ipS list=IPSEC timeout=30d
	:log info message="script=IPSEC_failed src_ip=$ipS why=SPI_not_registered"
# Find all "Invalid exchange" error last 5 min
:local loglistS [:toarray [/log find  time>([/system clock get time] - 5m) message~"Invalid exchange"]]
# for all error do
# find message
# find ip
	/ip firewall address-list add address=$ipS list=IPSEC timeout=7d
MikroTik->Splunk
iamdc
Mon Aug 19, 2019 7:39 am
181.209.165.10 parsing packet failed, possible cause: wrong password
phase1 negotiation failed due to time up xx.xx.xx.xx[4500]<=>181.209.165.10[4500]
run script is
script=IPSEC_failed src_ip=phase1 why=negotiation failed
can
# Find all "negotiation failed due to time up" error last 60 min
:local loglistTimeout [:toarray [/log find  time>([/system clock get time] - 60m) message~"phase1 negotiation failed due to time up"]]
# for all error do
:foreach i in=$loglistTimeout do={
# find message
	:local logMessageTimeout [/log get $i message]
# find ip
                :local ip1 [:pick $logMessageTimeout [:find $logMessageTimeout ">"] [:len $logMessageTimeout]]
                :local ipTimeout [:pick $ip1 1 [:find $ip1 "["] ]
	/ip firewall address-list add address=$ipTimeout list=IPSEC_failed timeout=245d
	:log info message="script=IPSEC_failed src_ip=$ipTimeout why=negotiation_failed due to time up"
Jotne
Mon Aug 19, 2019 10:09 am
I see that you have used 60 minutes.
The you also have to schedule the script to run 60 min , not 5 min as I have used as standard.
If not you will get double logging and IP will be added multiple times.
MikroTik->Splunk
brg3466
Tue May 18, 2021 9:10 pm
@Jotne,
I would like to use your script. But may I know how to set up the system clock so that [/log find time>([/system clock get time] - 60m) message~"xxx"] works. I found it only works with GMT 0 time. My setup is below, and script doesn't work since afternoon local time ( in GMT 0 , it is tomorrow) because the log pr will produce "mmm/dd/yyyy" in front of time:
[brg3466@MikroTik] > /system clock pr
                  time: 11:03:45
                  date: may/18/2021
  time-zone-autodetect: yes
        time-zone-name: America/Los_Angeles
            gmt-offset: -07:00
            dst-active: yes
rextended
Tue May 18, 2021 10:00 pm
Methods like [/system clock get time] - 5m (I see often on forum...) is wrong at any timezone,
for example 00:01:00 - 5 min do -23:56:00 and no log have negative time
previous year:
may/17/2020 10:47:30 system,info,account user admin logged out from 100.80.8.1 via winbox
may/17/2020 10:49:30 system,info,account user admin logged out from 100.80.8.1 via winbox
yesterday:
may/17 10:49:43 system,info,account user admin logged in from 100.80.8.1 via winbox
may/17 13:05:12 system,info,account user admin logged out from 100.80.8.1 via winbox
may/17 13:05:25 system,info,account user admin logged in from 100.80.8.1 via winbox
today:
08:18:40 system,info,account user admin logged out from 100.80.8.1 via winbox
08:18:51 system,info,account user admin logged in from 100.80.8.1 via winbox
08:18:54 system,info,account user admin logged out from 100.80.8.1 via winbox
Also on another thread of sometime ago, differencies between three time format used in LOG are coming out.
MikroTik have done the wrong choice to use "friendly" time format... MUST BE ful date & time in log, everytime.
And MUST use international date and time format as ISO standard: 2021-05-18 21:08:00
✂ Rextended Fragments of Snippets
Vld4UmVHUkdhelJUTTJzOQ==
rextended
Tue May 18, 2021 10:10 pm
>>> If not you will get double logging and IP will be added multiple times. <<<
It's impossible to add same identical IP adress to same address-list
the script on that case throw an error and exit if the IP are finded twice
also on right interval, without add subsequent IP on logs
Before add, must be check if already are present.
brg3466
Tue May 18, 2021 10:28 pm
I agree. With 3 formats of time, it is very confusing. Better to have just one uniform format.
Back to the topic, how to get the past, say, 10minutes log if we don't use Jotne's script ?
rextended
Tue May 18, 2021 10:43 pm
Do not worry to use any time interval, parse all logs, the script prevent double-set IP on address list than cause interruption for error on duplicate entry.
This script do not prevent the lock of your own remote IP if some error happen meantime.
Remember to create the whitelist of yours IPs and add permit rule before the blocking rule!
Revised script:
# Revised from Rextended v1.2.rex
# Created Jotne 2019 v1.2
# This script add ip of user who with "phase1 negotiation failed" and "SPI .* not registered for" to a block list for 7 days
# It should run on all routerOS version - Rex test it on 6.47.9
# example:
# 1.2.3.4 phase1 negotiation failed.
# SPI 4f23346ef367ea12 not registered for 1.2.3.4[4500]
:local logMessage ""
:local logIp 10.6.6.6
/log
:foreach i in=[find where message~"phase1 negotiation failed" or message~"SPI .* not registered for"] do={
    :set logMessage [get $i message]
    :if ($logMessage~"phase1 negotiation failed") do={
        :set logIp [:toip [:pick $logMessage -1 [:find $logMessage " "]]]
        :if ([:len [/ip fire addr find where address=$logIp]] < 1) do={
            /ip fire addr add address=$logIp list=IPSEC timeout=7d
            :log info message="IPSEC_failed add $logIp because negotiation failed"
    :if ($logMessage~"SPI .* not registered for") do={
        :set logIp [:toip [:pick $logMessage ([:find $logMessage "for "]+4) [:find $logMessage "["]]]
            :log info message="IPSEC_failed add $logIp because SPI not registered"
Jotne
Tue May 18, 2021 11:41 pm
Mikrotik write this about time log format:
You can store the logs remotely in a Syslog server, and there choose format that you like most.
I do use Syslog and Splunk
There has been several request to MT to use propper time log format like ISO8601
MikroTik->Splunk
diamuxin
Mon Jan 03, 2022 10:44 pm
Updated
Hello!
How to find the IP in this message? (second IP 27.115...)
phase1 negotiation failed due to time up 89.131.7.88[500]<=>27.115.124.74[30992] 0011223344556677:b59120571b9a18c2
:local ipS [:pick $logMessageS ([:find $logMessageS ">"]+1) ([:find $logMessageS "["]-1)]   ==> it does not work
Thanks!
own3r1138
Long time Member
Long time Member
Mon Jan 03, 2022 11:38 pm
I'm wondering if I can use the same concept for web fig logs.
After lets encrypt certificate enabled I get a few web fig login per day:(
login failure for user MikroTikSystem from 45.130.99.94 via web
You are right, I am wrong
You are wise, I am dumb
You are wrong, you are dumb
Don't worry, it's all right to be dumb
Jotne
Tue Jan 04, 2022 7:42 am
You are close. Problem is the second find, it does find the first [ (before 500), not the second [ (before 30992) that you need.
This works:
:local test "phase1 negotiation failed due to time up 89.131.7.88[500]<=>27.115.124.74[30992] 0011223344556677:b59120571b9a18c2"
:local temp [:pick $test ([:find $test ">"]+1) 999]
:put [:pick $temp 0 [:find $temp "["]]
It gets the IP and the rest of the line in the first pick. Then second pick gets all until [.
All in one ugly long line (better to split it up)
:local ipS [:pick [:pick $logMessageS ([:find $logMessageS ">"]+1) [:len $logMessageS]] 0 [:find [:pick $logMessageS ([:find $logMessageS ">"]+1) [:len $logMessageS]] "["]]
MikroTik->Splunk
diamuxin
Tue Jan 04, 2022 11:42 am
This works:
Thank you very much for the help!
BR.
inteq
Thu Jan 13, 2022 1:38 pm
Revised script:
# example:
/log
Was looking for such a script for a long time.
Trying to implement it on a router getting lots of "negotiation failed" but I have an issue.
The offending IP is added to IPSEC list, but it also adds 0.0.0.0 to the same list for some reason.
Any clue as to why? Nothing in log showing 0.0.0.0
Thank you.
Jotne
Thu Jan 13, 2022 2:32 pm
There is an 1.3 in this thread as well. Test it out. (Do not remember what was changed from 1.2 to 1.3)
MikroTik->Splunk
diamuxin
Thu Jan 13, 2022 2:55 pm
Revised script:
# example:
/log
Thank you.
The same thing happened to me doing tests. I think that when it cannot get the IP correctly it adds an IP of type 0.0.0.0.
It is important that the error messages in the log are correctly filtered to obtain an IP. Use ": toip"
This is my script that I run every hour, for now it works great for me.
:local logIp ""
:local message1 " phase1 negotiation failed."
:local message2 "phase1 negotiation failed due to time up "
:local message3 "first L2TP UDP "
/log
:foreach i in=[find where message~$message1 or message~$message2 or message~$message3 ] do={
    :if ($logMessage~$message1) do={
        :set logIp [:toip [:pick $logMessage 0 [:find $logMessage " "]]]
            :log info message="IPSEC failed: add $logIp because negotiation failed"
    :if ($logMessage~$message2) do={
        :set logIp [:toip [:pick [:pick $logMessage ([:find $logMessage ">"]+1) [:len $logMessage]] 0 [:find [:pick $logMessage ([:find $logMessage ">"]+1) [:len $logMessage]] "["]]]
            :log info message="IPSEC failed: add $logIp because negotiation failed due to time up"
    :if ($logMessage~$message3) do={
        :set logIp [:toip [:pick $logMessage ([:find $logMessage "from"]+5) [:len $logMessage]]]
            :log info message="L2TP failed: first UDP packet received from $logIp. Added to blacklist"
Luck!
BR.
inteq
Thu Jan 13, 2022 3:19 pm
Thank you.
:local logIp ""
/log
Luck!
BR.
Thank you for the code.
The problem is:
first L2TP UDP packet received from
is a valid and normal message on a successful connection.
Your script adds valid IPs to the list.
inteq
Thu Jan 13, 2022 3:24 pm
Missed the 1.3 one. Will test now.
Thank you.
diamuxin
Thu Jan 13, 2022 4:14 pm
In my case, I have this message that goes to nothing. For me it works.
first L2TP UDP packet received from 154.88.26.233
the script is very configurable.
BR.
inteq
Fri Jan 14, 2022 5:01 am
Tested the 1.3 version a bit and found some problems.
I guess the script was not supposed to add phase1 to the list, right?
Jotne
Fri Jan 14, 2022 7:36 am
Error found.
Here is some data from the log:
64.62.197.52 phase1 negotiation failed.
64.62.197.217 phase1 negotiation failed.
65.49.20.109 phase1 negotiation failed.
phase1 negotiation failed due to time up 92.200.200.100[500]<=>27.115.124.10[48536] 0011223344556677:5c5c77ed781bf459
phase1 negotiation failed due to time up 92.200.200.100[500]<=>27.115.124.9[64696] 0011223344556677:53c620c089b6028e
65.49.20.124 phase1 negotiation failed.
94.206.221.159 phase1 negotiation failed.
Lines with "phase1 negotiation failed" is not equal and some lines do not contain IP at start.
So solution is to add a dot at the end of search term to ignore those lines
negotiation failed.
Script updated and based on rextendeds version. Simpler with just one loop.
Also added test for access list name to see if IP is in IPSEC access list. (it may be in multiple lists)
# Created Jotne && rextended 2022 v1.4
# This script add ip of user who with "IPSEC negotiation failed", "SPI* not registered" and "Invalid exchange" to a block list for 7 days
# 1.4 added dot behind "negotiation failed" to get only lines with IP
# 1.4 made all inn to one loop, based on idea by rextended
:local logIp ""
/log
:foreach i in=[find where message~"phase1 negotiation failed\\." or message~"SPI.*not regist" or message~"Invalid exchange"] do={
    :if ($logMessage~"phase1 negotiation failed\\.") do={
        :if ([:len [/ip fire addr find where list=IPSEC address=$logIp]] < 1) do={
            :log info message="script=IPSEC_failed src_ip=$logIp why=negotiation_failed"
			:log info message="script=IPSEC_failed src_ip=$logIp why=SPI_not_registered"
    :if ($logMessage~"Invalid exchange") do={
			:log info message="script=IPSEC_failed src_ip=$logIp why=Invalid_exchange"
MikroTik->Splunk
own3r1138
Long time Member
Long time Member
Fri Jan 14, 2022 10:23 am
Thank you for the 1.4 <3
inteq
Fri Jan 14, 2022 10:28 am
Thank you Jotne
diamuxin
Fri Jan 14, 2022 11:31 am
Thanks for the new version of the script!
What does the double backslash before the point mean?
BR.
Jotne
Fri Jan 14, 2022 11:43 am
Its to make dot a dot and not just any character. (see regex info)
I RouterOS you need to double escape.
MikroTik->Splunk
mmee
Wed Jan 19, 2022 11:31 am
Thanks Jotne for this script.
"Invalid exchange " section does not work for me, it adds 0.0.0.0 to the address-list instead of the IP in the message.
I would like to parse this kind of message:
10:59:24 ipsec Invalid exchange type 243 from 185.xxx.142.172[500].
Maybe word "for" should be changed to "from" in line 33 ?
Jotne
Wed Jan 19, 2022 1:44 pm
You are 100% correct. Here is a fixed version.
# Created Jotne && rextended 2022 v1.5
# 1.5 Fixed typo
:local logIp ""
/log
        :set logIp [:toip [:pick $logMessage ([:find $logMessage "from "]+5) [:find $logMessage "["]]]
MikroTik->Splunk
own3r1138
Long time Member
Long time Member
Wed Jan 19, 2022 1:52 pm
Is this 1.5? so it is :d
Thank you for the update.
@Jotne
What should be the policy for this script? read and write?
I see 2 times in the script +4 and +5. Both should be +5 or the +4 left out by mistake from 1.4v.
Jotne
Wed Jan 19, 2022 3:25 pm
Updated to 1.5 so its easy to see what is the latest :)
+4 and +5 is correct. If you look at how the pick works, you will see it gives the position on the first found letter.
from 8.8.8.8
x1234567890
for 8.8.8.8
x1234567890
So for the "from", you need to add 5 to get the first part of 8.8.8.8
and in the "for", it 4 characters to 8.8.8.8
SIP uses "for" in log message and
Invalid exchange uses "from".
MikroTik->Splunk
own3r1138
Long time Member
Long time Member
Wed Jan 19, 2022 3:31 pm
Thank you for the A,
Honestly even you clearly explained this to me I still can't understand it as I don't know shit about coding. I wanted to set scheduler and I read that it must be the same as the script I just wanted to check this with you.
diamuxin
Sat Jan 22, 2022 2:56 pm
Hi @Jotne!
Is it possible for your script to export the IP addresses to the IPSEC list in cidr format?
That is to say:
64.128.34.17 --> 64.128.34.0/24
So that it blocks the entire subnet.
Thanks & BR.
Jotne
Sat Jan 22, 2022 9:55 pm
Here is how you can convert the IP. Since there are no easy way to find last dot, I need to find all and count.
It may be a faster way
:local ip "64.128.34.17"
:local A1 [:find $ip "."]
:local A2 [:find $ip ($A1+1)]
:local A3 [:find $ip "." ($A2+1)]
:local new ([:pick $ip 0 $A3].".0/24")
:put $new
64.128.34.0/24
Or all in one ugly line:
:local new ([:pick $ip 0 [:find $ip "." ([:find $ip ([:find $ip "."]+1)]+1)]].".0/24")
:put $new
MikroTik->Splunk
rushlife
Thu Jun 23, 2022 2:25 pm
Hi guys, some edit for L2TP and login with wrong password ?
BrateloSlava
Mon Aug 08, 2022 4:35 pm
Is it possible to modify the script by adding a check, that the blocked IP address is not in the exclusion list?
There are several trusted routers, that are interconnected via IPIP(EOIP)+IpSec. Periodically, a situation arises, when the connections between these routers are interrupted and the process of reconnection begins. Sometimes the connection is not restored the first time and an error appears in the log. The script finds this error and blocks the IP address for 7 days. If the script is not run, then such "problem" connections are normally restored after a certain period of time.
BrateloSlava
Thu Aug 25, 2022 6:50 pm
I will answer myself. It is enough to slightly change this line:
To this:
:if ([:len [/ip fire addr find where list=IPSEC address=$logIp]] < 1 and [:len [/ip fire addr find where list=Allow_ALL address=$logIp]] < 1) do={
rextended
Thu Aug 25, 2022 7:14 pm
Yes...
Various examples:
:local stip 64.128.34.17
:put "$([:toip $stip] & 255.255.255.240)/28"
:put "$([:toip $stip] & 255.255.255.0)/24"
:put "$([:toip $stip] & 255.255.0.0)/16"
:put "$([:toip $stip] & 255.0.0.0)/8"
output
terminal code
[rex@tended] > {
{... :local stip 64.128.34.17
{... :put "$([:toip $stip] & 255.255.255.240)/28"
{... :put "$([:toip $stip] & 255.255.255.0)/24"
{... :put "$([:toip $stip] & 255.255.0.0)/16"
{... :put "$([:toip $stip] & 255.0.0.0)/8"
64.128.34.16/28
64.128.34.0/24
64.128.0.0/16
64.0.0.0/8
This is the simpliest way:
:put "$(($stip >>8)<<8)/24"
Jotne
Thu Aug 25, 2022 9:41 pm
@rextended My script knowledge are not at the same level as you. I guess it never will be :D
MikroTik->Splunk
rextended
Fri Aug 26, 2022 10:38 am
For sure, for one thing I know more than you, you certainly know another thing more than me... :o
diamuxin
Fri Aug 26, 2022 2:06 pm
Duel of titans :D
Thank you both for teaching us so many useful things.
BR.
rextended
Fri Aug 26, 2022 4:04 pm
Added some functions here, can be useful:
viewtopic.php?p=953746#p953746
own3r1138
Long time Member
Long time Member
Mon Sep 05, 2022 9:52 pm
Could you guys include OVPN failed login into this Script, please? I tried to replicate it from your Script. However, I was not able to. Added IP is 0.0.0.0 at the created address list.
Thank you :d.
TLS Error: unknown opcode received (1)
<64.62.197.21>: disconnected <bad packet received>
Users browsing this forum: No registered users and 4 guests
