MUM Europe 2020
MarHazK
DMZ local ip to another without dstnat/port-forward the ports
Sat May 11, 2019 6:09 pm
I have 1 PC (192.168.0.100) connected to 1 mikrotik device (192.168.0.1/24) at ether2.
Then 2 servers which:
- Web Server A (192.168.1.10) connected to same mikrotik device (192.168.1.1/24) at ether3.
- Web Server B (192.168.1.11) connected to same mikrotik device (192.168.1.1/24) at ether3.
So, what I planned to do this is, I create another:
- ip address (192.168.0.10 under ether2) and it that will DMZ/dsnat to 192.168.1.10 (ether3) (Web server A)
- ip address (192.168.0.11 under ether2) and it that will DMZ/dsnat to 192.168.1.11 (ether3) (Web server A)
My objective are:
- the PC can access to the web server A via 192.168.0.10 without using other port (no dstnat/port-forward 81->80, just listening 192.168.0.10:80 (ether2) > 192.168.1.10:80 (ether3))
- the PC can access to the web server B via 192.168.0.11 without using other port (no dstnat/port-forward 82->80, just listening 192.168.0.11:80 (ether2) > 192.168.1.11:80 (ether3))
Should I use IPTunnel or dstnat? or any idea how/other solution how?
anav
Re: DMZ local ip to another without dstnat/port-forward the ports
Sat May 11, 2019 6:17 pm
Draw a diagram so what you have setup is clearer.
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Sob
Re: DMZ local ip to another without dstnat/port-forward the ports  [SOLVED]
Sat May 11, 2019 8:33 pm
It sound like all you need are two new addresses and simple NAT:
add address=192.168.0.10/24 interface=ether2
add address=192.168.0.11/24 interface=ether2
add action=netmap chain=dstnat dst-address=192.168.0.10 in-interface=ether2 to-addresses=192.168.1.10
add action=netmap chain=dstnat dst-address=192.168.0.11 in-interface=ether2 to-addresses=192.168.1.11
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
sebastia
Sat May 11, 2019 10:55 pm
why not just route: just connect to .1.10/11 address?
gateway of 0.100 is 0.1 = Tik right?
and Tik knows how to get to 1.1x...
Sob
Sun May 12, 2019 12:18 am
That sure does sound like the most simple and obvious solution. :)
MarHazK
Sun May 12, 2019 12:00 pm
never tried route both gateways/afraid both will have conflicts due differences of ISPs for both gateway, in other word, 192.168.0.1/24 route to public ip A (ISP A), 192.168.1.1/24 route to public ip B (ISP B). Probably I don't know how to route both gateways I pressume.
sebastia
Sun May 12, 2019 3:38 pm
So you have two wans and two lans. How do you isolate them? VRF?
instead of natting, routing info needs to be update. List your config (/export hide-sensitive compact)
Users browsing this forum: klaus007, vortex and 62 guests
