PCaddict69
VRRP Hyper-V Master Master Problem
Sat May 11, 2019 9:56 pm
hi , i create two clean chr instance with one internal link to test vrrp and i only manage to get MASTER on both side... i can ping between the two interface when vrrp is disabled.
the only config on them is this. Is a clean install i just try to figure out why is not working... no filter rules nothing...
chr1
add address=192.168.7.3/29 interface=ether3 network=192.168.7.0
add address=192.168.7.2 interface=vrrp1 network=192.168.7.2
/interface vrrp
add interface=ether2 name=vrrp1 priority=250 vrid=10
chr2
# ADDRESS NETWORK INTERFACE
0 192.168.7.1/29 192.168.7.0 ether2
1 192.168.7.2/29 192.168.7.0 vrrp1
2 D 10.0.1.244/24 10.0.1.0 ether1
1 192.168.7.3/29 192.168.7.0 ether3
2 192.168.7.2/29 192.168.7.0 vrrp1
3 D 10.0.1.245/24 10.0.1.0 ether1
ping test without vrrp
[admin@MikroTik] /ip address> /tool ping 192.168.7.1
current: 350.5Mbps
average: 381.8Mbps
Sob
Re: VRRP Hyper-V Master Master Problem
Sat May 11, 2019 10:14 pm
How does:
turn into:
with /29 mask? It should be /32.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
PCaddict69
Sat May 11, 2019 10:15 pm
hi i just change the vrrp address both side for /32 same results...
Sob
Sat May 11, 2019 10:28 pm
Check if VRRP traffic from one router reaches the other, maybe something blocks that. Look for protocol 112 and 224.0.0.18.
PCaddict69
Sat May 11, 2019 10:51 pm
finally find it in hyper-v on the nic you have to apply spoofing mac address....
Users browsing this forum: No registered users and 4 guests
