emils
v6.43.15 [long-term] is released!
Mon May 13, 2019 1:11 pm
RouterOS version 6.43.15 has been released in public "long-term" channel!
Before an upgrade:
1) Remember to make backup/export files before an upgrade and save them on another storage device;
2) Make sure the device will not lose power during upgrade process;
3) Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 6.43.15 (2019-May-10 12:44):
Changes in this release:
*) dhcpv4-server - fixed commenting option for alerts;
*) dhcpv6-server - fixed binding setting update from RADIUS;
*) ike1 - improved stability for transport mode policies on initiator side;
*) ipv6 - adjusted IPv6 route cache max size;
*) ipv6 - adjust IPv6 route cache max size based on total RAM memory;
*) ipv6 - improved IPv6 neighbor table updating process;
*) lte - reset LTE modem only when SIM slot is changed on dual SIM slot devices;
*) lte - use default APN name "internet" when not provided;
*) rb2011 - removed "sfp-led" from "System/LEDs" menu;
*) rb4011 - fixed SFP+ interface full duplex and speed parameter behaviour;
*) rb4011 - improved SFP+ interface linking to 1Gbps;
*) smb - fixed possible buffer overflow;
*) snmp - added "radio-name" (mtxrWlRtabRadioName) OID support;
*) ssh - do not generate host key on configuration export;
*) switch - fixed possible crash when interface state changes and DHCP Snooping is enabled;
*) system - accept only valid path for "log-file" parameter in "port" menu;
*) userman - updated authorize.net gateway DNS name;
*) webfig - improved file handling;
*) winbox - improved file handling;
*) winbox - show "R" flag under "IPv6/DHCP Server/Bindings" tab;
*) wireless - added support for US FCC UNII-2 and Canada country profiles for LHG-5HPnD-US, RBLHG-5HPnD-XL-US and SXTsq5HPnD-US devices;
*) wireless - improved wireless country settings for EU countries, outdoor models will use outdoor frequency range by default;
*) wireless - improved system stability for all devices with 802.11ac wireless;
*) wireless - improved wireless country settings for EU countries;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this specific RouterOS release.
Chupaka
Re: v6.43.15 [long-term] is released!
Mon May 13, 2019 1:50 pm
Is it something new that will be in 6.44 soon?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
emils
Mon May 13, 2019 1:57 pm
No, as usual, it is already in stable build.
petern
Mon May 13, 2019 2:02 pm
Hmm, weren't the IPv6 route cache size fixes already in 6.43.14?
emils
Mon May 13, 2019 2:03 pm
Yes, they were already in 6.43.14. These are additional small improvements.
Chupaka
Mon May 13, 2019 2:30 pm
Don't see it in Changelog, that's why I asked...
UPD: Ah-h-h, "Expand" button, sorry, my fault :)
vecernik87
Long time Member
Long time Member
Mon May 13, 2019 4:40 pm
Which CVE is it this time? :lol: Did it at least require authorised user?
(before you start hating me, remember that I don't mind about vulnerabilities. They are everywhere. I mind, when vulnerability is silently fixed without proper disclosure)
nmt1900
Mon May 13, 2019 4:48 pm
This "improved stability on 802.11ac wireless devices" reminds me of one problem with 6.43.14. One site has quite a few wAP ac devices (QCA9550) and repeating scenario: CPU usage rises some time at weekend when no users are present and stays there (at about 5...10%). This rises temperature reading to about 70°C (from 60). When users start connecting to it on monday, CPU usage rises slightly more (but not significantly) and temperature rises quickly to >80 degrees (last maximum was 86°C) and device reboots ("device was rebooted by watchdog timer" message in log and no auto-supout file). This reboot returns everything to normal until this vicious cycle repeats itself (even CPU usage decreases to 0% after that reboot). Interestingly - if device will not reboot at this condition (sometimes watchdog does not trigger itself), then all returns "miraculously" to normal after this temperature peak at monday morning...
Deployment of new release will take some time but it will be interesting to see if this release can have any effect on this behaviour...
105547111
Tue May 14, 2019 2:34 am
WAp60G reboots itself every few hours, only TX end. Fine on all previous long term just this version 6.43.15. Sent supout to support but doesn't generate an autosupout.
Downgrading back to 6.43.14 solves the issue.
However I see a LOT of memory in use suspect memory leak. Normally see about 200MB free, after a reboot you watch the memory drop about 1MB/sec
Both ends see the memory constantly dropping, gets to about 30MB after a hour. Old version okay, back to just over 200MB free and its been up 20 minutes.
Definitely a memory use bug on WAp60's
Ticket [Ticket#2019051422000737]
Cheers!
notToNew
Tue May 14, 2019 11:15 am
Tested on RBD52G-5HacD2HnD and some others: cannot see this on these devices.
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
Deantwo
Tue May 14, 2019 12:08 pm
I feel a little horrible for thinking the exact same thing when I saw a new long-term release.
Is that really where we have gotten with long-term releases?
Other than that, more stability fixes without having to deal with the major changes in the "stable" branch is always welcome.
I wish my FTP was FTL.
mkx
Tue May 14, 2019 12:58 pm
I say that this is exactly the reason for long-term branches. There are no other changes requiring releases in long-term branches where functionality of installed ROS is adequate.
BR,
Metod
105547111
Tue May 14, 2019 3:40 pm
Cheers!
Support got back really fast.
Thank you for the report. This will be fixed in the upcoming RouterOS 6.43.16 long term version.
Keep watching 6.43.16 is coming soon.
Cheers
vecernik87
Long time Member
Long time Member
Wed May 15, 2019 8:00 am
No wonder. Memory leak in "long-term" (previously "bug-fix") branch is ridiculous failure of their QA team.
I find it sad if we can't rely even on the most stable branch. Maybe its time to offer money for better support? If the fee is reasonable, I wouldn't have problem with it.
Caci99
Wed May 15, 2019 1:21 pm
It is not a happy event, but no need to panic. Things like this have happened to bigger organizations, like the famous Tuesday Patch of Microsoft which used to cause more worry than security.
-Toni-
Don't crash the ambulance, whatever you do
normis
Wed May 15, 2019 1:29 pm
This change was not supposed to go into this build, it was a mistake, so we will release a version without that change ASAP.
That release will be the long-term that this one was supposed to be, long term testing and all.
vecernik87
Long time Member
Long time Member
Wed May 15, 2019 2:07 pm
I am not panicking :) I have really great time on older version while waiting for others to take the beat for me. It just feels inappropriate and sad. I realise there is way more progress recently in comparison to few years ago, but I think quantity is not a substitute for quality. Especially in long-term, update should not be released unless it is tested for a longer period of time on real devices in real conditions while closely observed by QA team. I understand when bugs happen. But that's where testers should slap developers.
Sorry for this OT.
re: patch tuesday - that was going to happen since MS fired most of their testers and started testing on insiders and normal users. Exactly for this purpose, computers on all domains which I maintain have long delay (if its win10) or simple manual updates (previous versions). I always laugh when I read article about people randomly unable to boot because of new patch :D
emils
Wed May 15, 2019 2:43 pm
New version 6.43.16 has been released in long-term RouterOS channel:
viewtopic.php?f=21&t=148519
Users browsing this forum: llubik, sutrus, Werlock and 8 guests
