What do you think?
Yes
8 (80%)
No
1 (10%)
Instead, I would like to see...
1 (10%)
Total votes: 10
anuser
[idea] cAP ax
Tue May 14, 2019 10:57 pm
Well, the first IEEE 802.11ax first generation ASICs (Wave 1) are available. It´s time to tell what I would like to have when we see "Wave 2" ASICs:
- cAP ac design
- low power version
- PoE In and PoE Out => I would like to daisy chain 3 cAP ax devices. For now I can daisy chain 2 cAP ac devices. Would it be possible to increase the PoE capabilities to get 3 cAP ax devices all together?
- 1x 2.4 GHz: 2x2:2
- 2x 1GbE ports (802.3at PoE In, 802.3af PoE Out), no 2.5GbE
- (1x 5.0 GHz: 2x2:2) -- or -- (2x 5.0 GHz 2x2:2 plus keep the PoE capabilities as cAP ac, i.e. daisy chain 2 cAP ax devices)
Update: Just fooling around with 802.3bt
nz_monkey
Re: [idea] cAP ax
Wed May 15, 2019 5:37 am
The 802.11ax (Wifi6) SoC's are not available in quantity from Qualcomm yet.. They are sampling, and shipping in low quantity but that is it.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
anuser
Re: [idea] cAP ax
Wed May 15, 2019 10:11 pm
Well, I don´t expect MikroTik to sell 802.11ax access points in 2019. We´re talking about 202x
The only (Wave 1) SOC I can find is Broadcom´s BCM6752 https://wikidevi.com/wiki/Broadcom#ax_2:
ARM Tri-core CPU
2x2 11ax dual-band Wi-Fi
2 ports of Gigabit Ethernet
PCIe Interface
R1CH
Forum Veteran
Forum Veteran
Re: [idea] cAP ax
Fri May 17, 2019 1:40 pm
There's plenty of chipsets available, the problem is likely software. Since Mikrotik write their own wifi driver, it will take a long time before a stable 802.11ax driver is available. Even the 802.11ac support still isn't up to the competition after all these years.
If you need 802.11ax there's other options that are shipping today: https://wikidevi.com/w/index.php?title= ... =500&eq=no
mada3k
Re: [idea] cAP ax
Tue May 21, 2019 9:45 pm
What is the current market penetration for clients with 802.11ax? Example of phones/laptops?
Manages some CCR's, RB750Gr3, RB922 and wAP's
chechito
Re: [idea] cAP ax
Wed May 22, 2019 7:28 am
i expect 802.11ax to be a premium technology for a couple of years or until there is a ax second wave of chipsets
and i am not talking only about ap, talking about client devices too
im pretty sure mikrotik is fully aware of ax tech but the decisions taken to bring a product to the market involve not only technical reasons but commercial and strategic ones
from our perspective as customers and / or users of the products it seems simpler than it really is
there is a lot of hype and marketing around ax that's why it will be a recurring theme
but will take time to see an ax AP under 100 USD for example
chechito
Re: [idea] cAP ax
Wed May 22, 2019 7:31 am
good point
is practically 0 (posted today, may of 2019)
Pranja
Re: [idea] cAP ax
Wed May 22, 2019 12:06 pm
good point
Samsung Galaxy S10?
avacha
Re: [idea] cAP ax
Sun May 26, 2019 6:15 am
I think today there are no difference in everyday use between 802.11ac and ac speed, latency & radius for smartphone usage. What task do you have for your s10 for about 1Gbps?
muetzekoeln
Re: [idea] cAP ax
Sun May 26, 2019 9:12 am
ax is not only about higher peak thruput. It will give you improved coverage and less interference in crowded environments. And there is more, e.g. lower latency.
Users browsing this forum: No registered users and 1 guest
