j2sw
Dude up alerts make it but down don't
Fri May 17, 2019 4:30 pm
We have a situation where the Dude notifications on a device being up will make it through, but the down notifications do not. Some info.
1. Mail server does not show any logs for the down alerts. It's like it is never hitting it.
2. Up alerts come through just fine.
Both are going to the exact same e-mails of course. Nothing different except down vs up.
Ideas?
Sob
Re: Dude up alerts make it but down don't
Fri May 17, 2019 5:21 pm
Are you sure that Dude is sending any? Make you have notifications enabled for "unstable -> down".
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
j2sw
Sat May 18, 2019 5:15 pm
So is it not enough to have the up->down status checked? down->up is also checked.
Sob
Sat May 18, 2019 5:41 pm
Try it and you'll see. Maybe there is a case when it goes from up directly to down, but it's always from up to unstable and then to down for my Dude.
Users browsing this forum: No registered users and 2 guests
