JohnTRIVOLTA
Block public proxy servers - HOW
Fri May 17, 2019 9:34 pm
Hi guys,
I have not found a way to effectively block traffic to public proxies so as not to bypass the rules in the firewall !
If anyone has such a solution, please share their experience !
P.S. I want to ask, if i can add a firewall rule in filter section on forward chain with conten=https and one with http , can i block the redirected traffic to proxies only ?
Sob
Re: Block public proxy servers - HOW  [SOLVED]
Sat May 18, 2019 4:12 pm
I don't think you can. You can block some with L7 like this:
/ip firewall layer7-protocol
add name=proxy regexp="^(CONNECT\\ .*|GET\\ https\?:\\/\\/.*)\\ HTTP\\/1\\."
But it's far from perfect.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
JohnTRIVOLTA
Sat May 18, 2019 4:32 pm
Тhank you very much Sob !
I will try it ... I hope I will not block with it another traffic? :D
mkx
Sat May 18, 2019 5:04 pm
I don't think you can. ....
Indeed it is far from perfect. Probably it'll successfully block proxy requests, but will most probably block usual http requests as well (it probably won't interfere with direct https connections though). It's quite usual to see full
GET http://www.somedomain.com/path/to/document.html HTTP/1.x
on direct connections to source server as well ... it's the only way for server to distinguish between all those named virtual http servers sharing the same public IP address. (x in HTTP protocol nowadays is zsually 1 but with older web browsers it can be 0 as well).
BR,
Metod
Sob
Sat May 18, 2019 5:36 pm
I've never seen "GET http://..." in regular requests. The way to distinguish between virtual hosts is Host header. And quick test with nginx (as regular webserver, not proxy) shows that "GET http://www.domain.tld/ HTTP/1.0" without Host header returns default virtual host (i.e. ignores hostname from request) and the same with HTTP/1.1 (still without Host header) returns "400 Bad Request".
JohnTRIVOLTA
Sat May 18, 2019 7:24 pm
For now, this stops traffic to proxies that do not use https / SSL /. Unfortunately, most of the public are over https ! Тhe only solution for now is that I have to collect their ip addresses in lists .
Sob
Sat May 18, 2019 7:52 pm
I don't follow what happens in public proxy world, but what I got from Google was all without https, just http. But if you have different sources with https, then it's bad for you, because you can't see what's inside https connection, it's the whole point of https. And collecting address, good luck. Maybe if there already is some source of proxy addresses, you could use that. But doing it yourself will be never ending story.
JohnTRIVOLTA
Sat May 18, 2019 8:24 pm
Yes, i know - about https web proxies i mean !I will look for more information in the internet. For now, I will collect the names and addresses of most well-known ones!
Thanks again for your help Sob !
Sob
Sat May 18, 2019 10:24 pm
It really depends on what exactly you need it for and how persistent users you have. Maybe if you block the most obvious servers, they will give up. The major thing against you is that all they need is just one working server.
JohnTRIVOLTA
Sat May 18, 2019 11:09 pm
Behind a ccr I have a very sensitive network with about 150 clients.
There are several different servers on this network, with important information.
All this is done to prevent any type of virus, worm ... etc. in the network .
I already use the Joshaven Potter script to update the Spamhaus, dshield, and malc0de lists.
I also have a lot of rules based on ports in the forward chain. I use AdGuard DNS and redirect all queries to my router.
By blocking proxies, I will try to reduce the risk of any attempts to circumvent the rules!
Sob
Sat May 18, 2019 11:18 pm
Blocking access to proxies doesn't sound like something that would help much. Unless you have some very strict filtering of all outgoing traffic, any worm will just use either custom ports, or if you block those, then regular https. And you pretty much have to allow that, if those 150 clients should be able to use internet in the most basic sense, which today means access to http(s).
JohnTRIVOLTA
Sat May 18, 2019 11:26 pm
I added the last post with the missed info !
Sob
Sun May 19, 2019 12:11 am
I guess you already have that, but if not, I'd start with segmenting the network, make sensitive servers isolated from users as much as possible. Other than that, it's mostly non-technical, you need "long whip", "iron fist", or whatever is the fitting English idiom, users must know what they can and can not do, and don't dare to break the rules. :)
Users browsing this forum: Google [Bot], MSN [Bot], xvo and 73 guests
