dongtuuyenblackpeony
Problem with performance hAP ac
Mon May 20, 2019 7:13 am
Hi, My ISP provides 200Mbps
Directly connected by cable to the gateway I get 200+Mbps speedtest
Wired through the Mikrotik hAP ac I can't get that speed, max about 100Mbps (Gbps LAN card)
What should I do to get max speeds?
mkx
Re: Problem with performance hAP ac
Mon May 20, 2019 9:07 am
According to test results hAP ac may be capable of reaching 200 Mbps or not. More likely not, my experience is that the most "real life" relevant test results are the lower right figures from the table (routing with 25 ip filter rules and 64 or 512 byte packets).
What does Tool->Profile show while under maximum load? I expect CPU being fully loaded with firewall service using most CPU cycles ...
You can post output of /export hide-sensitive (run from terminal window) so we can check if there's some room for improvement ...
BR,
Metod
Users browsing this forum: No registered users and 8 guests
