marko_bg
Radius , PPPoE and user with "-"
Mon Apr 02, 2007 11:08 pm
When I try discconect user with "-" in username ,
etc. <pppoe-username-1> ,
... I recived this in log "Error-Cause = 406" ,
... 406 Unsupported Extension ... by who , mikrotik or radius ?
virtualmystic
Tue Apr 03, 2007 8:06 pm
it must be a mikrotik error...radius wont stop you from disconnecting a user.
regards,
Asad
marko_bg
Tue Apr 03, 2007 8:26 pm
now I see this...
.. if user have "-" , etc. <pppoe-user-name> disconnect work fine,
but , if I try disconnect user with "-1" , etc. <pppoe-username-1>, (ghost or second login with same username), I recived error 406
my script find username with "-" over snmp, and send disconnect request for that user,
I try with this to resolve problems with ghost user
savage
Wed Apr 04, 2007 8:13 am
The pppoe and 1 part are added by Mikrotik, it's not the username.
How exactly are you trying to 'disconnect' this user?
Regards,
Chris
marko_bg
Wed Apr 04, 2007 9:28 am
script read OID (simplequeue), and recived <pppoe-username-1>
then used username-1 , put in disconnect request and send to radius ...
radius send request to mikrotik ...
but mikrotik have error 406 and put request in Naks.
mikrotik have username with -1, but this "-1" make mikrotik and probably this is problem ?
savage
Wed Apr 04, 2007 9:55 am
Strip the pppoe and -1 parts. Mikrotik adds them internally.
Best would be to use the Radius Accounting data, you need far more than just a username to send a radius disconnect message...
Regards,
Chris
Users browsing this forum: mehdi1980, Semrush [Bot], ultratoto14 and 31 guests
