SolarClint
6.44.3 not installing
Thu May 30, 2019 7:34 pm
I have 6.29 currently on the RB450G and I am trying to upgrade it to 6.44.3. I have gone to systems > packages and hit the check for updates and hit the download and install buttons. the routeros-mipsbe-6.44.3.npk file is in the files window. i have rebooted the router but it doesn't install update. Is there anything else I am supposed to do?
Under systems > routerboard it says current firmware is 3.22. is this different firmware than the 6.29?
Dude2048
Re: 6.44.3 not installing
Thu May 30, 2019 7:45 pm
The firmware could be correct. They started the renumbering around that time, if I remember correctly.
There should be an entry in the log why it is not installing.
ashpri
Sat Jun 01, 2019 1:03 am
I had a HAPACLITE with this same issue. I had to do a netinstall. A note with netinstall, I had to disable all other ethernet interfaces on my PC (including eth interfaces for virtual machine software), except the one connected to the mtik.
Users browsing this forum: No registered users and 20 guests
