Argih
CHR on Google cloud Bandwidth test server doesn't work
Sat Jun 01, 2019 3:43 am
I'm mounting a CHR image in the google cloud platform to use it mainly as a Bandwidth test server (i still have the free credits) but when i try to run a test using the public IP it doesn't get connected.
I don't know if is because is a nated IP (i'm yet to discover if is possible to set the public IP directly on the ether-1 interface) or is something with my configuration.
I opened udp ports from 2000 to 10000 (on the VPC network) because it says the test uses port 2000 or higher but it doesn't work either.
When i use the test client pointing to a physic router i have it does work, and when i do the test using another VM in the same LAN (VPC network subnet) it works too.
What i'm doing wrong, or is even posible to do what i want?
Users browsing this forum: No registered users and 3 guests
