Chiara
mAPlite as wifi to ethernet adapter
Tue Jun 04, 2019 4:32 pm
I want to allow the DHCP client PC (A) connected to ETH1 port of the mAPlite (B) to an existing DHCP server (C)in accessible by the LAN where the WLAN interface of the mAPlite is connected.
But I cannot get the IP from the DHCP server, with Torch I see the requests but no response.
If I enable the DHCP on the mAPlite the PC get an address from it but not from external DHCP server.
DHCP CLIENT A >>>> eth1 of B
wlan1 of B >>>> C DHCP SERVER
Ideally A should get address from C.
I've bridged ETH1 and WLAN, no rules on firewall or NAT.
With Torch on the bridge I can see the DHCP client requests coming from A.
Can someone please say me what's missing?
mkx
Re: mAPlite as wifi to ethernet adapter
Tue Jun 04, 2019 7:37 pm
Wifi is not made for bridging wired parts of LAN transparent in L2 sense. Vendors introduced incompatible solutions and later came WDS (which itself is a small mess).
So it is important to know how both wireless devices are configured - you mentioned mAP lite, but not the other end of wireless connection.
BR,
Metod
Chiara
Wed Jun 05, 2019 9:52 am
Thank you for answering, both are MIKROTIK routerboard. I don't know if this is correct but this seems to work:
# jan/02/1970 00:15:28 by RouterOS 6.44.3
# software id = Y6VQ-AHV4
# model = RouterBOARD mAP L-2nD
add comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys \
    name=ssidtoconnect supplicant-identity="" wpa-pre-shared-key=pass \
    wpa2-pre-shared-key=pass
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-b/g/n channel-width=\
    20/40mhz-Ce country=italy disabled=no distance=indoors frequency=auto \
    frequency-mode=regulatory-domain mode=station-bridge security-profile=\
    ssidtoconnect ssid=ssidtoconnect station-roaming=disabled wireless-protocol=802.11 \
    wps-mode=disabled
/ip hotspot profile
add address-pool=default-dhcp interface=bridge name=defconf
add bridge=bridge interface=ether1 trusted=yes
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
    bridge
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set sip disabled=yes
set pptp disabled=yes
set udplite disabled=yes
set dccp disabled=yes
set sctp disabled=yes
/tool mac-server
/tool mac-server mac-winbox
ervcese
Wed Jun 05, 2019 10:19 am
You don't need dhcp client or server on station bridge device, just assign ip address from your first router LAN network to the Bridge on the second router. First router wlan must be in ap-bridge mode and if dhcp-server is on bridge, then wlan interface must be in the same bridge. Everything must work and the PC must receive IP address from first routers dhcp network.
Pea
Wed Jun 05, 2019 7:55 pm
Try this, works perfectly:
On your main Mikrotik router (C DHCP SERVER)
/interface wireless
set mode=ap-bridge ssid=YOUR-SSID wds-default-bridge=bridge-local wds-mode=static-mesh
/interface wireless wds
add disabled=no master-interface=wlan1 wds-address=xx.xx.xx.xx.xx.xx (wifi MAC of remote Mikrotik = DHCP CLIENT A)
On your remote Mikrotik (DHCP CLIENT A)
clean/remove setup (especially disable DHCP, NAT, edit/remove firewall) and put all interfaces to bridge, set DHCP client on bridge and add your security profile and change wifi mode:
/ip dhcp-client
add interface=bridge-local
set [ find default=yes ] authentication-types=wpa2-psk wpa2-pre-shared-key=YOUR-PASSWORD
/interface wireless
set frequency=auto mode=station-wds ssid=YOUR-SSID
All LAN ports on remote Mikrotik are now wireless connected to your LAN.
Users browsing this forum: No registered users and 27 guests
