plisken
switch on and off wifi radio script don't work anymore
Thu Jun 13, 2019 9:37 pm
Hello, I have a WiFi radio from Mikrotik that I switch on and off at certain hours. This with a script.
If there is a power failure, this script no longer works because the start time has been exceeded.
Can a script be created that reactivates the script?
sebastia
Re: switch on and off wifi radio script don't work anymore
Thu Jun 13, 2019 10:02 pm
why don't you schedule a repeatable task and put the logic to trigger or not in the script?
plisken
Thu Jun 13, 2019 10:06 pm
I'm a noob in writing scripts.
Can you help me to turn on the WiFi every day from 7:00 am to 10:00 pm.
sebastia
Thu Jun 13, 2019 10:28 pm
Looking at other posts, ex viewtopic.php?t=149298 is a good start
:local time [/system clock get time];
:if ($time >= "07:00:00" && $time < "21:59:00") do={
	:if (<is_wifi_off>) do={
		:log warning "Switching wifi on"
# add code here
} else {
	:if (<is_wifi_on>) do={
		:log warning "Switching wifi off"
# add code here
trigger that every minute from 1970 midnight...
Edit: simplified script a bit
plisken
Thu Jun 13, 2019 11:43 pm
Ok, i try this and thanks for your reply.
krafg
Fri Jun 14, 2019 12:19 am
Also you can create two scripts (one to turn on and the other to turn off) your WiFi, and create two tasks on scheduler to turn on and turn off the interface on the hours that you need.
Assuming that your clock is correct and your interface is "wlan1" you can try:
Script to turn on:
Script: interface wireless set wlan1 disabled=no
Script to turn off:
Name Disabled man
Script: interface wireless set wlan1 disabled=yes
Scheduler1:
Start time: 07:00:00
Interval: 1d 00:00:00
Event: EnableWlan
Scheduler2:
Start time: 22:00:00
Enent: DisableWlan
Regards.
plisken
Fri Jun 14, 2019 5:32 am
@krafg I did this, but if the power goes out, this entire script is disrupted. This is because the start time of the first time it has started has passed.
I'm looking for a solution (a script) to correct the start time.
A kind of reset of this script so that it works again.
sebastia
Fri Jun 14, 2019 11:00 am
Hence why you need a script that will be triggered often and can determine what to do ...
krafg
Fri Jun 14, 2019 6:13 pm
It's weird. On scheduler, try to put on both the start date as 01 Jan 2019. Also try to use a NTP server to synchronize the time like pool.ntp.org or time.windows.com.
Regards.
Users browsing this forum: No registered users and 8 guests
