baptisteba
EoIP over Internet
Fri Jun 28, 2019 6:44 pm
Hello everone,
I'm asking for help because i tried EoIP tunnel over my personnal LAN and it worked perfectly, but, I don't know why it doesn't work over public internet, this is the config i tried to do :
Computer (10.200.153.10) > Mikrotik HAP AC (10.200.0.1) > 4G router (with DMZ for the Mikrotik) > Public Internet < 4G router (with DMZ for the Mikrotik) < Mikrotik HAP AC (10.200.0.2) < Computer (10.200.153.20)
What I want to do :
- The ability to transfer data through the EoIP tunnel, establishing a connection, ping each machine on the same network
Actually i tried and i can't even establish a connexion
Hope someone can help,
Regards
idlemind
Re: EoIP over Internet
Wed Jul 10, 2019 3:23 pm
Do you have global unicast IPs on the 4G interfaces or are they carrier grade NAT addresses? You'll need a public IP on at least 1 side of the equation and even then you'll have to use something capable of traversing NAT first.
mkx
Wed Jul 10, 2019 3:29 pm
Quite a few (if not all) MNOs firewall subscribers against incoming connections even if subscribers are using proper (read: globally routable) IP addresses ... You might need a "fixed anchor" to establish wanted tunnel ... with a hop on the "anchor".
BR,
Metod
Users browsing this forum: Mraknet and 92 guests
