alexsec
Logging issue
Wed Jul 03, 2019 9:46 am
Good Day,
I have a problem when I login to Mikrotik via Winbox it seems that it remembered all opened terminals in a past. I tried to reboot router but issue remains. Please assist
sch
Re: Logging issue
Wed Jul 03, 2019 10:06 am
Please send supout file from your router to support@mikrotik.com.
File must be generated while router is not working as suspected or after some problem has appeared on device.
kristsd
Re: Logging issue
Wed Jul 03, 2019 10:14 am
Does this happen only in logs every time you connect to the device? Does it also open as many terminals?
To me this looks like a logging issue, could you check your logging settings?
If you can't find anything that could be the cause of it, contact support@mikrotik.com with supout.rif file.
alexsec
Re: Logging issue  [SOLVED]
Wed Dec 16, 2020 4:29 pm
I found what caused problem, remember my last session as soon I disabled that didn't had problems
