giegs
VB6 SOURCE CODE FOR MIKROTIC
Wed Jul 03, 2019 12:21 pm
HI.
Please help me on how to get/generate password with validity using vb6?
Thanks in advance :D
RogerWilco
Re: VB6 SOURCE CODE FOR MIKROTIC
Fri Jul 05, 2019 6:55 am
I don't think you'll get many takers. VB has been dead for well over a decade... if you want to use Visual Basic, switch to VB.NET. You can port samples easily from C# if you can find any.
pompe
Sat Aug 10, 2019 4:42 am
el archivo adjunto es un ejemplo funcional de acceso a API desde vb6 compatible con ruteros 6.45.1
The attached file is a functional example of API access from vb6 compatible with routers 6.45.1
Saludos
welovechonburi
Wed Oct 16, 2019 12:39 pm
Thank you very much......
Users browsing this forum: No registered users and 21 guests
