DotTest37
OSPF Force path for specific subnet
Wed Jul 03, 2019 10:30 pm
I have OSPF running between two Mikrotik Routers, each of them with 2 WANs configured on failover.
I have few private subnets behind each router.
Right now my OSPF Interfaces are configured like this:
ISP-A Cost : 10
ISP-B Cost: 30
Thats how I got OSPF to use ISP-A by default for all the intra-office traffic using the private subnets, and is working great.
If any of the two routers loose the ISP-A , then OSPF converge to ISP-B, and back when is again available.
Now, I just added two new private subnets on each side, for VoIP, but Id like to use by default ISP-B only for those subnets, since is the stand-by and not in use.
(I would add QoS later, etc, but I still want to use the unused link)
How can I force OSPF to add routes for the new subnets that use ISP-B without affecting all other routes that are going over ISP-A ?
savage
Re: OSPF Force path for specific subnet
Thu Jul 04, 2019 9:02 am
Static routes. Pretty much all that comes to mind.
OSPF can't manipulate cost per route, only per interface.
Regards,
Chris
DotTest37
Sat Jul 06, 2019 4:51 pm
Static Routes wont failover when the main ISP goes down.
I would have to create a script for that.
That would defeat the purpose of the OSPF.
Any other option? Another routing protocol? multiple OSPF instances perhaps?
mducharme
Trainer
Trainer
Sun Jul 07, 2019 3:27 am
You might be able to do this with BGP, depending on your topology.
DotTest37
Sun Jul 07, 2019 6:26 pm
:-) I wouldn't even know how to start with that.
Can you run two instances of OSPF between the same two routers (with multiple loopback addresses, etc) and make this work?
mducharme
Trainer
Trainer
Mon Jul 08, 2019 12:41 am
Possibly, but that would be a really strange setup. It is very unusual to establish OSPF neighbor with another ISP. You would typically use BGP in this role.
joegoldman
Long time Member
Long time Member
Mon Jul 08, 2019 12:53 am
Static routes, with check-gateway = ping.
So if Link A is your defailt and you want a specific subnet to go via Link B, then static route with check gateway on Link B (or a netwatch script, which is just as simple), so if Link B dies that traffic goes back via Link A
Users browsing this forum: No registered users and 7 guests
