paulkmoore
CRS328-24P-4S+RM installation of fan3 and fan4
Thu Jul 04, 2019 12:39 pm
Hi all,
First post here, so please feel free to redirect if required :)
I've just received my CRS328-24P-4S+RM which looks excellent; however, as others have noted here the "typical" fan noise is not "house" friendly. I'm therefore planning to replace the existing two fans with Noctua NF-A4x20 PWMs.
The installed fans are Sunford AD4028V12BLBGF's. I've not been able to find the exact specs for this fan, but from what I can deduce from the Sunford AD4028GF series specs the closest match is the AD4028V12_LWGF with 11.61 CFM airflow and 12.15 mmH2O static pressure. By comparison, the Noctua NF-A4x20 PWMs have 5.5 CFM airflow and (only) 2.26 mmH2O static pressure.
The static pressure is my main concern here, as my PoE usage will be limited and with low wattage requirements. Accordingly, I'm planning to replace the existing Sunfords and install two further fans (4 in total) in the fan3 and fan4 slot.
My question regards the direction (push or pull) that I should install fan3 and fan4. fan1 and fan2 as currently configured are operated in pull mode (air pulled from inside the case to outside). My inclination is therefore to install fan3 and fan4 in push mode, so that they draw cool air into the case, and in general the airflow is maintained right to left across the unit.
Does anybody know in which direction fan3 and fan4 are intended to operate?
Thanks, Paul
mkx
Re: CRS328-24P-4S+RM installation of fan3 and fan4
Thu Jul 04, 2019 2:29 pm
If you do that, you could create a 'circling' path for the air: fan3 and fan4 suck air in, it passes from right ot left, fan1 and fan2 push it outside, where (part of it) passes from left to right and fan3 and fan4 suck it in (again) ...
The problem can become serious if space behind the RB is not really open (e.g. inside some smaller equipment rack or if router is mounted between longer servers) which makes harder for hot air to move away from the back side.
Most of gear I've seen maintains single direction of air across the device and usually that's front-to-back (most of rack installations assume cold zone in front and hot zone at the back). So if you find additional fans necessary, I'd go for the same air flow direction (front to back).
BR,
Metod
paulkmoore
Thu Jul 11, 2019 6:44 pm
Hi Metod,
Thanks for the reply. The fans in the CRS328-24P-4S+RM are located on each side of the unit, so the airflow is right to left (when looking at the front of the switch). There are no rear fans or vents, so no "circling" I think.
I had a response from Mikrotik support which corroborates my intent;
"you should put them in "reverse" mode. Since 1&2 push air from the case, 3&4 fans should push air into the case."
Images of the before and after here:
Before
After
And all seems to be well - note the switch is running slightly warm as it's in a cupboard :?
> /system health print
     cpu-temperature: 49C
   power-consumption: 10.5W
  board-temperature1: 35C
        psu1-voltage: 26.4V
        psu2-voltage: 52.7V
        psu1-current: 0A
        psu2-current: 0.2A
          fan1-speed: 1590RPM
          fan2-speed: 1605RPM
          fan3-speed: 1530RPM
          fan4-speed: 1545RPM
Thetmar
Sun Oct 06, 2019 8:57 pm
Hello Paul,
Can you tell me if it worked? Is it better?
I have to peaces in house but one of them made a lot of noise. So i will replaced the fans but my question is wich fan did you use? And where did you get it?
Kind regards,
Thetmar Wiegers
elbob2002
Sun Oct 06, 2019 10:20 pm
To be honest if you're running RouterOS then make sure you're running the latest version and you won't have to swap out any fans.
Whatever changes they made means mine is practically silent with fans running at 270RPM instead of 4000RPM.
Of course this is at the expense of temperature which is now 58 degrees instead of somewhere in the 40s.
Elans
Fri Oct 11, 2019 8:09 am
Hello Paul,
Kind regards,
Thetmar Wiegers
What version are you using and can you post screenshots of /system health?
As @elbob2002 have said - in latest versions there were improvements which affects fan speed based on temperature.
paulkmoore
Fri Oct 11, 2019 2:01 pm
Hi Thetmar,
It certainly operates well and is quiet. By placing my hand next to the fan there is good air flow through the unit, but I haven't carried out an exhaustive flow/temperature survey within the unit :)
The fans I used were Noctua NF-A4x20 PWMs. I used four in total as set out above; also see the attached pics for orientation of the fans to keep the wiring tidy(ish). I purchased the fans through Amazon, here https://www.amazon.co.uk/gp/product/B07DXRNYNX. Frankly they're not cheap, but they are quiet.
I'm currently running 6.45.6 (stable) and the system health is:
     cpu-temperature: 57C
   power-consumption: 9.8W
  board-temperature1: 33C
        psu1-voltage: 26.4V
        psu2-voltage: 52.7V
        psu1-current: 0A
        psu2-current: 0.1A
          fan1-speed: 1635RPM
          fan2-speed: 1740RPM
          fan3-speed: 1530RPM
          fan4-speed: 1515RPM
Hope that helps
Best
Paul
Users browsing this forum: jebz and 17 guests
