Bdfy
low wifi speed after upgrade firwmare on RBD52G-5HacD2HnD
Fri Jul 05, 2019 1:43 am
Hi, I have Mikrotik Hap2 router. On routerOS 6.43.16 wifi worked fine ( max speed more than 10Mbytes ), but after upgrade to 6.45.1 wifi speed very low, max speed 2-3Mbytes ( I tried several clients, 2.4/5 Ghz. ). Config default ( only wifi + pppoe settings ) .
jul/05/2019 01:27:34 by RouterOS 6.43.16
# model = RBD52G-5HacD2HnD
# serial number = XXXXXXXXXX
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 password=XXXX service-name=test use-peer-dns=yes user=XXX
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=russia disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Bdfy wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=russia disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=Bdfy5 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=key wpa2-pre-shared-key=key
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/system clock
set time-zone-name=Europe/Moscow
/system package update
set channel=long-term
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] >
Users browsing this forum: dad2312, fcucco, Google [Bot], JustDobby, VulgarisMagistralis and 71 guests
