dakotabcn
load balancing with fail over, added backup line 4G
Fri Jul 05, 2019 11:57 am
Hello
I have an RB1100AHx4 with a load balancing with 2 FTTH of 300 Mb symmetrical. The client has asked us if it is possible to mount a backup 4G in case of failure that the Backup is activated for only an RDP connection to a cloud
currently the load balancing has an automatic fail over that notifies us by mail in case of a fall of a line, I'm looking at how to make if the two lines fall activate the backup, but I'm looking at examples and I do not know how to apply them, someone has experience in this?
summarizing: activate 4G backup in case of failure of the two FTTH lines and that ONLY allows RDP to the cloud
sebastia
Re: load balancing with fail over, added backup line 4G
Sun Jul 07, 2019 12:42 am
Hey
You're mangling now for connection / routing mark, and you've setup separate routing tables for each mark. Right?
Then just have all three routes in the tables
T1
Wan1 distance 1
Wan2 distance 2
4G distance 3
T2
Wan2 distance 1
Wan1 distance 2
4G distance 3
In filter:forward you would want to filter traffic over out-interface=4G to be RDP only (+technical traffic: ping, dns, ...).
dakotabcn
Tue Jul 09, 2019 11:58 am
Hey Sebastian
This mi actual config, the 4G not is installed:
(i have deleted/modified no essential info for security reason)
# model = RB1100x4
add name=DMZ
add name=LAN
set [ find default-name=ether1 ] name=ISP1 speed=100Mbps
set [ find default-name=ether2 ] name=ISP2 speed=100Mbps
add name=WAN
add bridge=LAN interface=ether12
add interface=ISP1 list=WAN
add interface=ISP2 list=WAN
/ip firewall address-list
add address=192.168.xx.xxx disabled=yes list=ExclusionBalanceoISP1
add address=192.168.xx.xxx disabled=yes list=ExclusionBalanceoISP2
add address=192.168.xxx.0/24 list=RedLocal
/ip firewall mangle
add action=mark-routing chain=prerouting comment=\
"EXCLUSION DEL BALANCEO SALIENDO POR ISP1" new-routing-mark=to_ISP1 \
passthrough=no src-address-list=ExclusionBalanceoISP1
"EXCLUSION DEL BALANCEO SALIENDO POR ISP2" new-routing-mark=to_ISP2 \
passthrough=no src-address-list=ExclusionBalanceoISP2
add action=mark-connection chain=prerouting comment="REGLAS BALANCEO " \
connection-mark=no-mark in-interface=ISP1 new-connection-mark=ISP1_conn \
passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark \
in-interface=ISP2 new-connection-mark=ISP2_conn
dst-address-type=!local in-interface=LAN new-connection-mark=ISP1_conn \
passthrough=yes per-connection-classifier=both-addresses:2/0
dst-address-type=!local in-interface=LAN new-connection-mark=ISP2_conn \
passthrough=yes per-connection-classifier=both-addresses:2/1
add action=mark-routing chain=prerouting connection-mark=ISP1_conn \
in-interface=LAN new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2_conn \
in-interface=LAN new-routing-mark=to_ISP2
add action=mark-routing chain=output connection-mark=ISP1_conn \
add action=mark-routing chain=output connection-mark=ISP2_conn \
add action=masquerade chain=srcnat out-interface=ISP1
add action=masquerade chain=srcnat out-interface=ISP2
add check-gateway=ping distance=1 gateway=1.1.1.1 routing-mark=to_ISP1
add check-gateway=ping comment="Recursiva - WAN1" distance=1 gateway=1.1.1.1 \
add check-gateway=ping distance=2 gateway=8.8.8.8 routing-mark=to_ISP1
add check-gateway=ping comment="Recursive - WAN2" distance=1 gateway=8.8.8.8 \
add check-gateway=ping distance=1 gateway=1.1.1.1 routing-mark=to_ISP2
add check-gateway=ping distance=2 gateway=8.8.8.8 routing-mark=to_ISP2
add check-gateway=ping comment="Recursive - Default" distance=1 gateway=\
1.1.1.1
add check-gateway=ping comment="Recursive - Default" distance=2 gateway=\
8.8.8.8
add comment="Recursive - to_WAN1" distance=1 dst-address=1.1.1.1/32 gateway=\
192.168.6.1 scope=10
add distance=1 dst-address=1.1.1.1/32 gateway=192.168.16.1 scope=10
add comment="Recursive - to_WAN2" distance=1 dst-address=8.8.8.8/32 gateway=\
192.168.19.1 scope=10
add distance=1 dst-address=8.8.8.8/32 gateway=192.168.19.1 scope=10
/system scheduler
add comment="This will run after 4 mins" interval=5m name=ISP1 on-event="/syst\
em scheduler set [find name=checker] disabled=yes\r\
\n:local pinged [/ping address=8.8.8.8 count=5 interface=ISP1 size=50]\r\
\n:if ((\$pinged=0)) do={\r\
\n#send email\r\
\n/tool e-mail send subject=(\"alerta: Fibra ISP1 caida\") \\\r\
\nbody=(\"LA LINEA ISP1 ESTA CAIDA DESDE \" . [/system clock get time]) \\\
\r\
\nto=(\"XXXXXXX@XXXX.ES\")\r\
\n/system scheduler set [find name=backupwan] disabled=no\r\
\n}\r\
\n" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=jun/21/2019 start-time=17:31:44
add comment="This will run after 4 mins" interval=5m name=ISP2 on-event="/syst\
\n:local pinged [/ping address=8.8.8.8 count=5 interface=ISP2 size=50]\r\
\n#send email\r\
\r\
\n}\r\
\n" policy=\
start-date=jun/21/2019 start-time=20:21:53
My work approach is the following:
- Create the BKPG4 interface in ETH3
- monitor via script or other process that the ping responds in ISP1 or ISP2 (interface list WAN could be useful?)
- If the ping does not respond in ISP1 and ISP2 automatically activate BKPG4 and activate a rule that only allows traffic to the external citrix IP (I have to determine if it is an IP or range of IP) and the DNS keeps working, mail, web and other services by not allowing anything more than citrix IPs and DNS should not work, we should also send the MKT an email notifying of this to take the necessary measures
- when ISP1 or ISP2 go back to work, disable the blocking rule so that normal Internet will work again
I have the idea of using netwatch, I have seen some script and it seems the best solution, although I do not know how to apply the first part, the monitoring, if I saw some examples that were similar I would look to mount a system for what they ask me
regards
sebastia
Thu Jul 11, 2019 2:14 pm
Regarding config (didn't review it all, just relevant part for this topic)
# you probably don't want "passthrough" here
passthrough=yes
Scripting is one possibility, another is this https://wiki.mikrotik.com/wiki/Advanced ... _Scripting. -> already implemented for isp1 & 2, just add route for 4G to both to_isp1 & to_isp2 tables.
That filter rule for traffic over LTE can be always active: in filter:forward, out-interface=<4G> ...
You have duplicate + typo? routings -> best to remove them
add check-gateway=ping comment="Recursiva - WAN1" distance=1 gateway=1.1.1.1 routing-mark=to_ISP1
add check-gateway=ping comment="Recursive - WAN2" distance=1 gateway=8.8.8.8 routing-mark=to_ISP2
add check-gateway=ping comment="Recursive - Default" distance=1 gateway=1.1.1.1
add check-gateway=ping comment="Recursive - Default" distance=2 gateway=8.8.8.8
add comment="Recursive - to_WAN1" distance=1 dst-address=1.1.1.1/32 gateway=192.168.6.1 scope=10
add comment="Recursive - to_WAN2" distance=1 dst-address=8.8.8.8/32 gateway=192.168.19.1 scope=10
Users browsing this forum: stefan6900 and 31 guests
