bda
Dude db vacuuming
Fri Jul 05, 2019 7:31 pm
ROS 6.44.3 on CHR
How to do vacuuming right?
Does DB will reduce in it size after vacuuming?
God bless UNIX!
jarda
Re: Dude db vacuuming
Mon Jul 08, 2019 8:45 am
There is only one vacuum command available so you cannot make a mistake. But it might not help at all. You have to try...
bda
Tue Jul 09, 2019 11:54 pm
I did it. But it have to "eat" up to 1GB of system partition. Not Dude disk.
And finishes without any status info.
Database sill >3.5GB
Maybe I need to transfer db-file to x86 pc and do some other actions on it?
God bless UNIX!
jarda
Wed Jul 10, 2019 12:40 am
bda
Wed Jul 10, 2019 11:15 am
Does it applicable for >6.41 dude installations?
God bless UNIX!
jarda
Wed Jul 10, 2019 11:17 am
Sure. There is no change in dude for ages because mikrotik doesn't have available capacities. So the difference between the versions is just the number.
Users browsing this forum: MSN [Bot] and 8 guests
