I usually use queue trees to prioritize VoIP traffic, and it works well.
But I have an issue with a rb2011 : there is absolutely no traffic going through queue trees attached to my lan interfaces.
I had this issue in the past because there was a "fast path" default rule, but on this router, I deleted it, so no fast path.
I don't understand why it doesn't work, could you help me please ?
Here is the configuration of the router :
Code: Select all
# jul/11/2019 17:44:10 by RouterOS 6.44.3
# software id = BMAI-PUWW
# model = 2011UiAS-2HnD
# serial number = B9070A29E2A5
add admin-mac=74:4D:28:87:88:9B auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether7 ] advertise=\
set [ find default-name=ether8 ] advertise=\
set [ find default-name=ether9 ] advertise=\
set [ find default-name=ether10 ] advertise=\
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip,aes-ccm \
management-protection=allowed mode=dynamic-keys name=wifi \
supplicant-identity=MikroTik unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
disabled=no distance=indoors frequency=auto mode=ap-bridge \
security-profile=wifi ssid=Livebox-00bd wireless-protocol=802.11
add comment=LAN_DATA name=lan_data_pool ranges=192.168.1.10-192.168.1.150
add comment=LAN_VOIP name=lan_voip_pool ranges=192.168.250.10-192.168.250.20
add address-pool=lan_data_pool disabled=no interface=bridge name=\
lan_data_dhcp
add address-pool=lan_voip_pool disabled=no interface=ether3 name=\
lan_voip_dhcp
/ppp profile
add change-tcp-mss=yes name=ADSL use-compression=no use-encryption=no \
use-mpls=no use-upnp=yes
/interface pppoe-client
add allow=pap,chap disabled=no interface=ether1 name=adsl-ether1 profile=ADSL \
user=ip19051354538@srvc
/queue tree
add max-limit=900k name=upload-adsl parent=adsl-ether1 priority=1 queue=\
default
add max-limit=1M name=upload-sdsl parent=ether2 priority=1 queue=default
add max-limit=8500k name=download-landata parent=bridge priority=1 queue=\
default
add max-limit=8500k name=download-lanvoip parent=ether3 priority=1 queue=\
default
add limit-at=500k max-limit=900k name=upload-voip-adsl packet-mark=VOIP-PKT \
parent=upload-adsl priority=1 queue=default
add limit-at=500k max-limit=1M name=upload-voip-sdsl packet-mark=VOIP-PKT \
parent=upload-sdsl priority=1 queue=default
add limit-at=500k max-limit=8500k name=download-voip-lanvoip packet-mark=\
VOIP-PKT parent=download-lanvoip priority=1 queue=default
add max-limit=8500k name=donwload-std-lanvoip packet-mark=STD-PKT parent=\
download-lanvoip queue=default
add max-limit=8500k name=download-std-landata packet-mark=STD-PKT parent=\
download-landata queue=default
add max-limit=900k name=upload-std-adsl packet-mark=STD-PKT parent=\
upload-adsl queue=default
add max-limit=1M name=upload-std-sdsl packet-mark=STD-PKT parent=upload-sdsl \
queue=default
/snmp community
set [ find default=yes ] name=serveurcom write-access=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
add comment=LAN_DATA interface=bridge list=LAN
add comment=LAN_VOIP interface=ether3 list=LAN
add comment=WAN_ADSL interface=adsl-ether1 list=WAN
add comment=WAN_SDSL interface=ether2 list=WAN
add address=192.168.250.254/24 comment=LAN_VOIP interface=ether3 network=\
192.168.250.0
add address=192.168.1.1/24 comment=LAN_DATA interface=bridge network=\
192.168.1.0
add address=88.218.15.218/30 comment=WAN_SDSL interface=ether2 network=\
88.218.15.216
/ip dhcp-server lease
add address=192.168.250.250 mac-address=D8:DF:0D:00:64:D6 server=\
lan_voip_dhcp
add address=192.168.1.0/24 comment=LAN_DATA dns-server=192.168.1.1 gateway=\
192.168.1.1
add address=192.168.250.0/24 comment=LAN_VOIP dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.250.254
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1,8.8.4.4
/ip dns static
add address=192.168.88.1 name=router.lan
established,related,untracked
invalid
add action=accept chain=input comment="accept 8080" dst-port=8080 \
in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="Accept SNMP from Serveurcom" dst-port=\
161,162 in-interface-list=WAN protocol=udp src-address=85.14.167.193
add action=accept chain=input dst-port=161,162 in-interface-list=WAN \
protocol=udp src-address=85.14.167.234
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting comment="Mark SIP connections" \
dst-port=5060 in-interface=ether3 new-connection-mark=VOIP-CONN \
passthrough=yes protocol=tcp
add action=mark-connection chain=prerouting comment="Mark RTP connections" \
in-interface=ether3 new-connection-mark=VOIP-CONN passthrough=yes \
protocol=udp src-port=6000-7000
add action=mark-packet chain=prerouting comment="Mark VOIP packets" \
connection-mark=VOIP-CONN in-interface=ether3 new-packet-mark=VOIP-PKT \
passthrough=yes
add action=change-dscp chain=prerouting comment=\
"Change DSCP to 46 for VOIP connections" connection-mark=VOIP-CONN \
in-interface=ether3 new-dscp=46 passthrough=yes
add action=mark-connection chain=prerouting comment=\
"Mark standard connections" connection-mark=no-mark in-interface-list=LAN \
new-connection-mark=STD-CONN passthrough=yes
add action=mark-packet chain=prerouting comment="Mark standard packets" \
connection-mark=STD-CONN in-interface-list=LAN new-packet-mark=STD-PKT \
passthrough=yes
add action=mark-routing chain=prerouting comment=\
"Route standard connections to ADSL" connection-mark=STD-CONN \
in-interface-list=LAN new-routing-mark=to_ADSL passthrough=yes
"Route VOIP connections to SDSL" connection-mark=VOIP-CONN \
in-interface-list=LAN new-routing-mark=to_SDSL passthrough=yes
"Route connections initiated from ADSL to ADSL" connection-mark=no-mark \
in-interface=adsl-ether1 new-connection-mark=STD-CONN-ADSL passthrough=\
yes
add action=mark-routing chain=prerouting connection-mark=STD-CONN-ADSL \
add action=mark-connection chain=input connection-mark=no-mark in-interface=\
adsl-ether1 new-connection-mark=STD-CONN-ADSL passthrough=yes
add action=mark-routing chain=output connection-mark=STD-CONN-ADSL \
"Route connections initiated from SDSL to SDSL" connection-mark=no-mark \
in-interface=ether2 new-connection-mark=STD-CONN-SDSL passthrough=yes
add action=mark-routing chain=prerouting connection-mark=STD-CONN-SDSL \
add action=mark-routing chain=output connection-mark=STD-CONN-SDSL \
add action=dst-nat chain=dstnat comment=BERONET dst-port=8181 \
in-interface-list=WAN protocol=tcp to-addresses=192.168.250.250 to-ports=\
80
/ip firewall service-port
set sip disabled=yes
add check-gateway=ping distance=1 gateway=adsl-ether1 routing-mark=to_ADSL
add check-gateway=ping distance=1 gateway=88.218.15.217 routing-mark=to_SDSL
add check-gateway=ping distance=2 gateway=adsl-ether1 routing-mark=to_SDSL
/ip service
set www port=8080
/lcd interface pages
set 0 interfaces=wlan1
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Paris
/system ntp client
set enabled=yes server-dns-names=fr.pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
Joris
