ryufrvr
Re: v6.45.2 [stable] is released!
Wed Jul 24, 2019 12:04 am
hap lite, update with netinstall and backup config. because no free space with default packages(
LeftyTs
Wed Jul 24, 2019 12:42 am
My CCR1009-7G-1C after upgraded to 6.45.x, it rebooted every night.
The logs says
"router was rebooted without proper shutdown, probaly kernel failure.
Kernel failure in previous boot."
Any solutions?
Checked any hardware/power issues? A few CCRs are working perfectly OK here
sid5632
Wed Jul 24, 2019 1:46 am
On 16M flash devices upgrade happens in RAM, so that should be fine.
Should be, but it isn't.
But you may occasionally need to reboot your device right before the upgrade to free some RAM.
Occasionally? It's every time and even then it doesn't work.
Also switching from bundle to individual packages should not be required
But it is. That's the only way to upgrade things.
Why do you not just unbundle all those packages on these basic spec. devices? It's the only way they are going to work for the vast majority.
Sticking your collective heads in the sand isn't going to help. People repeatedly tell you on here that it's broken, but you don't seem to be listening.
icosasupport
Wed Jul 24, 2019 6:22 am
The logs says
Any solutions?
Welcome to the club! No fix afaik.
pe1chl
Wed Jul 24, 2019 10:11 am
Indeed! I think that whole combined package thing should be dropped, and at some time all installations are converted to separate packages during the upgrade to a new version.
And then the package manager should be extended with an option that allows installation of a package (from the upgrade server) with a simple mouseclick.
Some menu that shows you all the existing packages on the upgrade server, you can tick some of them, and then download them and reboot.
Just like it already happens during a regular upgrade once you have converted your device to separate packages. The mechanism is already in place, just make it accessible in the UI.
osc86
Wed Jul 24, 2019 12:00 pm
+1
CCR1009-7G-1C-1S+ ROS6.45.2
xlarge74
Wed Jul 24, 2019 12:14 pm
Hello, i just bought 2 hap ac^2 on one the wifi 5ghz was working on the other one, the network sometimes didnt show up . if it was visible to my laptop i couldnt connect.
I saw, that one was runing with 6.45.1 (this one was ok) and the other one with 6.45.2 had this problems.
will there be a fix?
kr
xlarge74
DenisPDA
Wed Jul 24, 2019 12:18 pm
kr
xlarge74
Use long-term
viewtopic.php?f=21&t=150045
srTeCHNoiD
Wed Jul 24, 2019 12:26 pm
The logs says
Any solutions?
Youre lucky. I have CCR-1072, it not rebooting, just freezes and looking dead every 1-3 nights after upgrade to 6.45.x. Only hard reboot fix it. So, i wake up from bed and going to office to reboot. Every night.
Just downgrade to 6.44 (Long term) fix this problem to me.
Question to Mikroitk - what happening?! Why unstable firmware are going to stable release tree?!
xlarge74
Wed Jul 24, 2019 12:45 pm
kr
xlarge74
Use long-term
i will .. thanks
OverMark
Wed Jul 24, 2019 12:51 pm
Hi all!
Another 4011 with an useless SFP+ port here! :shock:
I've installed the LTS firmware and it everything has returned to normal. The point is that I haven't been able to restore the factory firmware (6.43) doing a factory reset (pressing button before turning on the power). It always started with that buggy 6.45.2 firmware until I force it to install the npk (downgrade).
mkx
Wed Jul 24, 2019 2:03 pm
Routerboards don't have dual firmware installed [*]. Factory reset only returns configuration to factory default [**], not the software version. Information about factory default ROS version is there only to prevent administrator from installing ROS version older than that (and possibly doesn't have support for all hardware).
[*] it is possible to have two (or more) ROS versions installed in unit has flash storage with size of 64MB or more. In this case, one can partition flash to two halves and run different version of ROS in both partitions. If ROS crashes or fails to boot from one partition, it'll automatically try to boot from the other partition. If ROS is running normally, one can manually select partition for next boot.
[**] factory default configuration is not the configuration which was set up when unit was manufactured, but rather default configuration of ROS being installed. Default configuration can change slightly from time to time (and new defaults get added for new features). The most notable example of changing default setup is default list of firewall rules, they slowly evolve with time.
BR,
Metod
plankanater
Wed Jul 24, 2019 2:25 pm
SFP+ on 4011 broken. Please pull the update. I have had two switches go offline due to this update.
honzam
Wed Jul 24, 2019 7:20 pm
I wrote 19 Jul: Now that you know, it would be a good idea to put a line in the changelog:
Known bug: SFP problem with 4011. We do not recommend upgrading
Many people will upgrade over the weekend and save a lot of trouble... :) Thanks
Nobody from Mikrotik hear it. Probably a big problem to add one line to the changelog :( :(
LAN, FTTx, Wireless. ISP operator
calpenetworks
Wed Jul 24, 2019 8:37 pm
We have about 400-500 Hap Lite routers automatically updating with the latest release version, most of them are having the same issue - not enough storage to update. The big problem is the device saves a chunk of the update file in the file list, meaning it wont automatically update due to a shortage in storage when Mikrotik does push an update to fix this.
I can only think about going one by one and deleting the file and updating the 'long term' package.
Edit: When it attempts to update again it clears the file from the file list.
Jotne
Wed Jul 24, 2019 9:22 pm
You should hold off and wait for 6.46.
MT is aware of the problem and seems to work on solution for the small space devices.
From 6.46Beta16
*) smips - reduced RouterOS main package size (disabled LTE modem, dot1x and SwOS support);
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
aizhihuxiao
Thu Jul 25, 2019 2:31 am
The logs says
Any solutions?
I run many services on this router, such as OSPF, OpenVPN and etc.
Downgraded to 6.44.5 yesterday, the uptime is 10h until now without any issues.
aizhihuxiao
Thu Jul 25, 2019 2:33 am
The logs says
Any solutions?
Probaly you need watchdog on 6.45.x
I just downgraded to 6.44.5 yesterday, it works fine!
jriera
Thu Jul 25, 2019 3:42 am
The logs says
Any solutions?
Same problem here, there are already several crashes with routers only with OSPF, others with OSPF + BGP and all with 6.45.1. I have to force a restart to recover, it is accessible only by mac-telnet. OSPF and BGP are lost.
The failure they report is:
01:46:02 script, error script error: action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
There is no script implemented on the router ...
What is happening?
bda
Thu Jul 25, 2019 9:45 am
Dear Mikrotik Dev Team,
What about GRE (wrong mark first packet as invalid) problem?
God bless UNIX!
kalamaja
Thu Jul 25, 2019 9:55 am
Best solution so far for hAP lite: download and extract all_packages-smips-6.45.2.zip, upload only those packages that are enabled in your router, reboot -> router is upgraded and disabled packages are gone in one simple step.
LeftyTs
Thu Jul 25, 2019 10:14 am
I run DHCP BGP Firewall NAT VLANs SFP+ L2TP (server and clients) UPnP SNMP Scripts Schedulers in most of them and so far not a single issue. Maybe the problem is service specific? Have you tried enabling logging to an external server to catch those logs before rebooting?
radio303
Thu Jul 25, 2019 10:27 am
From 6.46Beta16
Does it mean that my LTE modem will stop working when 6.46 is released and installed on my hAP lite? /edit: sorry, not lite but just hAP, my mistake/
Since installing 6.45.1 I've been experiencing occasional disconnections from my wi-fi network when I'm using remote desktop connection, and so I tried to update. That failed, initially because of 'free space' issue, then I switched to 'longterm' 6.44.5, after that 6.45.2 gets downloaded but after reboot I still have 6.44.5.
Disappointing, I thought Mikrotik were the most stable, bought 3 of these one by one for various locations, but it seems that I need to consider previous options again.
mszru
Thu Jul 25, 2019 11:03 am
From 6.46Beta16
How do you connect LTE modem to hAP lite?
radio303
Thu Jul 25, 2019 11:27 am
From 6.46Beta16
Through USB... oh sorry it's hAP - not lite
petern
Thu Jul 25, 2019 11:37 am
Is this supported on all devices with enough flash?
https://wiki.mikrotik.com/wiki/Manual:Partitions says only MIPS, TILE and PowerPC, but my ARM-based RB1100AHx4s do have the /partition menu.
mkx
Thu Jul 25, 2019 12:28 pm
I haven't tried it myself (the only ARM device I have has only 16MB flash), but some forum users reported that partitioning on RB4011 (IIRC) went fine.
BR,
Metod
pe1chl
Thu Jul 25, 2019 12:41 pm
That is the disadvantage of putting things like that in a manual page that isn't automatically maintained. That page was likely made when those were the only
available platforms for their own equipment. Things like X86 and CHR are not in the list and intentionally so, but ARM just was never added.
marisspringis
Thu Jul 25, 2019 12:42 pm
after update all my export and backup files disapeared from files.
i'm using Hap AC2
is this beeing made by update so the devices with 16Mb memory could update normally?
mkx
Thu Jul 25, 2019 12:46 pm
On hAP ac2 (and other devices witch tiny flash disks), root of what you see in /files print is in RAM disk and gets wiped after every restart. The non-volatile file storage is under /flash ...
BR,
Metod
LeftyTs
Thu Jul 25, 2019 1:14 pm
Perhaps packages like mpls, ipv6 and hostspot should be dropped from the base RoS distribution. Would be even better if from the main RoS distribution individual packages could be uninstallable instead of just disabled.
Chupaka
Thu Jul 25, 2019 1:33 pm
What happens when some of downloaded packages are broken during download? If you have bundle package - then you have error on bundle installation, and everything is rolled back. AFAIR, when system is already installed and some additional package is broken, it simply does not get installed, so... can't you bring your RouterOS into some "clipped" state without necessary functionality when installing separate packages?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
pe1chl
Thu Jul 25, 2019 1:51 pm
When you click on "download&install" and it cannot finsh the download, it does not reboot so it does not get installed.
On newer devices that is the final state becuase a powercycle deletes those downloaded packages.
On older devices with 64M or more flash, the older packages will remain but a powercycle still does not install them, only a requested reboot does.
Re-doing the download&install will probably fix it.
Furthermore, this situation already was present when you installed extra packages beyond the combined package.
OKNET
Thu Jul 25, 2019 2:15 pm
hAP lite has 32MB ram 16MB flash
No way to update after deleting all files and rebooted more than once (had to try netinstall yet).
The winbox method system->packages>CheckForUpdates, finds new version but "download and install button" refuses to appear (likely because of space issue).
Previously helped solve the problem
What actually that fix_space.npk does ???
mkx
Thu Jul 25, 2019 2:19 pm
Somewhere around ROS 6.41 the upgrade process could sometimes break and leave some files un-acounted for. Those could be removed only by net-installing the device. This npk tries to find such orphaned files and removes them. Newer versions are supposedly not breaking the same way and this npk won't fix anything.
BR,
Metod
OKNET
Thu Jul 25, 2019 3:19 pm
Not any direct method to access to flash neither ?
DanchoDimitrov
Thu Jul 25, 2019 3:25 pm
i'm using Hap AC2
Hello, I got a small 16gb flash drive for this. Format it as ext3 amd mount it. I keep packages, logs and backups on it. Be sure to copy them over to your PC from time to time as flash drives dont last very long.
On another note, can you check if your 5GHz AC wifi gets stuck at detecting radar if its set to 80MHz channel?
hAP AC^2
mkx
Thu Jul 25, 2019 3:31 pm
Nope. Not the system part of it.
BR,
Metod
pe1chl
Thu Jul 25, 2019 3:33 pm
i'm using Hap AC2
No, it is made by reboot. The files directory on a device with 16M flash is a RAMDISK.
It will vanish whenever you powercycle or reboot the device. This is not the place to keep exports and backups, only to generate them. After that you have to download them to your PC to save them.
marisspringis
Thu Jul 25, 2019 3:35 pm
yes it got stuck on detecting radar
r00t
Thu Jul 25, 2019 4:09 pm
Is it that hard to just add a warning to a changelog about not working SFP on 4011? If you don't want to pull the release, at least do the absolute minimum?
It will be week old soon and people are still installing it on their devices, breaking the functionality.
These are your customers, that bought your 200e product and you are doing everything for them to hate you and never buy another.
(and let's not even talk about the SNAFU with 5GHz wifi that still doesn't work properly year after a product launch)
Doing the absolute minimum (adding a warning to release notes) can't take more than 5 minutes... yet you just don't care.
DanchoDimitrov
Thu Jul 25, 2019 4:16 pm
just use long term, eks dee. But seriously, use long term. Imo stable just means it boots most of the time.
Stable builds are not to be deployed to customers and offsite. If you do that then u just asking for trouble.
hAP AC^2
rb9999
Thu Jul 25, 2019 4:25 pm
I’m one of those couple of 200e+ customers... just pull the damn release as you’re probably doing a lot more harm for mikrotik’s name letting it as is. I crashed two rb4011 and it’s a good thing I had a backup ethernet link to that couple of switches... or it would cost me time and money to physically get to both sites in couple of hours.
honzam
Thu Jul 25, 2019 5:40 pm
@normis and @mikrotik It is too hard answer this question? You rather let the user install a "defective" RouterOS for rb4011?
MtHoodlum
Thu Jul 25, 2019 7:02 pm
RouterBOARD 952Ui-5ac2nD "hAP AC Lite" Upgraded to Stable v6.45.2, From WInbox I opened "New Terminal" and got a blank window. Upgraded packages to Long-Term 6.44.5, opened "New Terminal" wInfow and got the terminal as expected.
TheMac
Fri Jul 26, 2019 1:25 am
hAP AC2 at AC 80MHZ XXXX stuck at detecting radar, 40 seems to work.
Issue not present on older 6.44.5 long term.
Issue from the previous stable build with high ping over 5g wifi is fixed.
Tell me if u need more info.
Can we just copy and paste whatever is in 6.44.5 for the wifi and dump it in 6.45.3?
Similar issue here. Was able to solve it by switching from "Frequency: Auto" to "Frequency: 5180"
chuky0
Fri Jul 26, 2019 3:38 am
abysmal wlan download with this f/w. went from 54/16 to 1.3/16 Mbps (have 150/15 from my isp)
i have 750gr3 an 2 wapac capsman configured
worked great until i tried 6.45.2 bad enough that i downgraded to 6.44.5 long term and its fine, back to where it was
ie. maxed out my wlan on that device
first time this has happened to me with upgrading mikrotik I've had them a couple of years now, I may lean towards long term from now on
smuslim
Fri Jul 26, 2019 4:03 am
OpenVPN is not working anymore for us after upgrading to 6.45.1 and 6.45.2. OpenVPN clients are unable to get traffic from the OpenVPN-Net (10.10.10.x/24) to the Management Network (10.80.80.x/24). The IP Firewall in Winbox shows the following message on the rules which include the ovpn-instance:
in/out-interface matcher not possible when interface (ovpn-instance) is slave - use master instead (bridge-mgmt)
Our OpenVPN setup worked perfectly fine BEFORE upgrading to 6.45.1/6.45.2. Any ideas?
Mine also stop working after Upgrade and CPU usage was high about (25-30%). But restoring old backup(configs) fix the problem.
agpsolutions
Fri Jul 26, 2019 12:56 pm
I have upgraded hAP lite RB941 and hotspot doesn't work correctly. No internet connections is shown when you select the wireless. With 6.44.3 is working but with 6.45.1 and 6.45.2 and 6.46beta give this issue.
It works only if you go to 192.168.88.1
No problem instead with RB951ui-2hnd
Any one else discovered this issue?
schadom
Fri Jul 26, 2019 2:31 pm
This is so fucked up. Every single ROS update introduces new bugs...
pe1chl
Fri Jul 26, 2019 2:55 pm
And new features too!! The horror.
The "bug" that is being quoted in red all the time (although it is not clear why people include it with their own unrelated bug) probably is not a bug at all anyway, just an existing incorrect configuration that now is detected and indicated, and previously it just did not work.
aizhihuxiao
Sat Jul 27, 2019 9:28 am
Not yet, I don't have externel log server for now.
I have three CCR -1009, only this one has crash issue.
But the most service running on this router: OPENVPN, OSPF, IPSEC, EOIP, DHCP, NAT, L2TP, UPNP, SFP, FIREWALL, DNS
vitaly2016
Sat Jul 27, 2019 11:30 am
I made mistake - I did not read "v6.45.2 [stable] is released!" topic before upgrading my hEX
I successfully upgraded ROS of remote hEX from 6.45.1 to 6.45.2
After rebooting I tried to upgrade FIRMWARE from 6.45.1 to 6.45.2.
The red line in the bottom of firmware upgrade window was as usually: "successful upgrade, please reboot"
But now I can't connect to hEX after reboot.
Winbox after trying to connect within ~20 seconds reports:
"ERROR: could not connect to..."
This is remote location without any personnel. So I should go there to see what happened.
Another my RB2011 successfully upgraded its ROS to 6.45.2 but there was strange thing when I rebooted it after
FIRMWARE upgrade:
Winbox lost connection as expected, but RB2011 did not reboot. I looked at device, it kept on working and nothing happened.
In a few minutes I connected via Winbox again, reboot router and this time process finished good, firmware is 6.45.2
It's seems like with every new Mikrotik upgrade, the process is getting closer to Discovery Channels' "I Shouldn't Be Alive" series.
Only lucky ones will be able to upgrade.
P.S. Another my Mikrotik device - hEX POE is the lucky one. It was successfully upgraded from 6.44.3 to 6.45.2 (both ROS and FIRMWARE)
HighTech
Sat Jul 27, 2019 12:12 pm
Warning for all RB4011 users do not install FW6.45.2 if you are using the SFP+ port, Installing the firmware makes the SFP+ adapter not seeing by the routerOS and no traffic throu SFP, downgrade to FW6.45.1 makes it work again.
I have no problem with FW6.45.2 on CHR and CCR1036
/Carsten
CZFan
Sat Jul 27, 2019 10:51 pm
Did you do the "Wireless Reset" as mentioned in previous version (6.45.1) change log?
*) rb4011 - fixed MAC address duplication between sfp-sfpplus1 and wlan1 interfaces (wlan1 configuration reset required);
MTCNA, MTCTCE, MTCRE & MTCINE
kiler129
Sun Jul 28, 2019 12:09 am
This has nothing to do with the MAC duplication fixed in 6.45.1 - the SFP is broken in 6.45.2 and they acknowledged that in some of the previous posts.
eddieb
Sun Jul 28, 2019 12:34 pm
updating to 6.45.2 went smooth ... from 6.45.1 to 6.45.2 with some help from the dude ;-)
No problems so far
Running 6.45.6 (stable) on :
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, ipsec/l2tp roadwarrior, dhcpd, dns), CRS125-24G-1S, RB1100, RB962UiGS-5HacT2HnT (10pc), RB931-2nD, RB951, RB750GL ,RB2011UAS-RM, CHR running dude (CHR running in VirtualBox on OSX)
ruwi000
Sun Jul 28, 2019 6:33 pm
When I upgraded an LtAP mini (luckily a test machine) to 6.45.1, I lost the LTE interface! When I upgraded to 6.45.2, the LTE interface is back again.
There is nothing in the release/change notes. Anybody else experiencing the same issue?
Paternot
Long time Member
Long time Member
Mon Jul 29, 2019 3:31 am
Not really.
Step1: Download ALL necessary packages. Use RAM if needed.
Step2: Verify ALL downloaded packages.
Step3: If everything is ok, install packages.
Done. This is how Linux Distros work: they download updates, verify integrity and then install.
XTX
Mon Jul 29, 2019 8:51 am
at 6.45.1, gre tunnels stopped working. Redid all 15 routers on ip tunnels. 3 weeks after the release of 6.45.2, the ip tunnels stopped working ....
Exactly the same here !
Upgraded from 6.42.7 to 6.45.2 on a CCR1036 and all the GRE tunnels stopped working.
Ok I know that the Mikrotik guys can't test everything ...but GRE ? seriously ?? c'mon guys....FIX IT !!!
petern
Mon Jul 29, 2019 11:12 am
Did you check your firewalls allow inbound GRE? If you check the notes there was a fix for a bug that allowed it when it shouldn't've been allowed.
sindy
Mon Jul 29, 2019 12:08 pm
...and while fixing that one, another one has been introduced which incorrectly labels the initial packet of a GRE connection with connection-state=invalid so you need to workaround this in your firewall if you drop "invalid" packets before all selective accept rules. This has also been discussed earlier in this topic.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
XTX
Mon Jul 29, 2019 1:14 pm
Hi
Thanks guys
Yeah...the problem was that i have in the FW a drop invalid input and a drop invalid output rule in place, so after disabling those two rules it started working again.
gotsprings
Forum Veteran
Forum Veteran
Mon Jul 29, 2019 8:29 pm
Upgraded a cAP AC to 6.45.2
Reset Configuration Like I normally do... but this site was not a CAP install.
/system reset-configuration
UNIT CAME UP AS A ROUTER.
wAP AC has always done this. This was the first time I have seen a cAP AC do this.
Had to have tech on site connect to the local SSID to get around the firewall and configure it.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
aqualx
Mon Jul 29, 2019 9:00 pm
From release notes 6.45.1:
*) ipsec - renamed "remote-peers" to "active-peers";
Can someone change remote-peers to active-peers in script listed on this wiki page: Securing L2TP Server for IPSec
PS: It would be great if in future such changes would apply to user scripts automatically. It is not very obvious why after upgrade to new version VPN stopped working...
ascentnetworks
Tue Jul 30, 2019 8:23 am
You guys right shit the bed with 6.45.2 It's not even close to stable. It's total trash and bricks EVERYTHING!! Note to EVERYONE DO NOT USE THIS CRAP VERSION!! YOU WILL SCREW YOUR ROUTERS!!!
Kampfwurst
Tue Jul 30, 2019 9:51 am
After upgrading to 6.45.2 the pptp connection to the core router with 6.44.1 is not possible, It stops at link established. Downgroade to 6.44.5 and it works again.
pe1chl
Tue Jul 30, 2019 1:38 pm
Problems with PPTP are solved the same way as GRE issues mentioned before.
Chupaka
Tue Jul 30, 2019 1:51 pm
Not really.
Okay, let's then imagine "out of disk space" issue in the middle of installation of Nth package. Linux distros can work with "different" versions of packages, RouterOS can't.
pe1chl
Tue Jul 30, 2019 3:27 pm
This should only happen when something is corrupted. Normally, Linux distributions know beforehand how much extra diskspace is required when installing or updating a package.
So RouterOS can calculate if the new install will theoretically fit, and not start the upgrade when it does not fit.
3xHelix
Tue Jul 30, 2019 4:41 pm
You can only imagine the look on my face as an enterprise network tech when a software upgrade royally killed everything in my house... This is cause router to everything in my house is over SFP !!! ...
When can we expect a fix for the botched 6.45.2 update ? ... Thank god for partitions!
P.S. - Please renamed update to "v6.45.2 [stable if you dont use sfp]"
raevsk
Tue Jul 30, 2019 5:52 pm
Hello to everyone
I have a problem with this version of RouterOS
I download manually package (routeros-mmips-6.45.2) from the web site and put it to my RB750Gr3 with 6.41.5 version. After reboot it must be upgraded. But after that he did not start correctly, i can not seen him in winbox or in another way (for exaple to connect him to another router and i can not find him in "neighbors").
I repeat installation on another Mikrotik RB750Gr3 with 6.41.5 version - and i again have the same proplem. Now i have 2 dead routers.
Why i have this problem? Can you help me? What i can do with it and why this problem begin?
Chupaka
Tue Jul 30, 2019 6:03 pm
"Theoretically" is not always what will happen IRL. Like, gitlab-ce does PostgreSQL backup on package upgrade. Are you sure it calculates backup size before doing it? Are you sure it's even possible?
mac86
Tue Jul 30, 2019 7:10 pm
I want to inform that we should also downgrade CCR1072.
With 6.45.1 we have an unexpected restart every day. :(
Simply lower CCR to 6.44.5 and no more bad reboots. :D
http://www.netpro-ar.com
MTINE - MTCWE - MTCRE - MTCTCE - MTCNA
Patagonia Argentina IT Consultant
Mikrotik user from V2.7.7 - Aug/2003
pe1chl
Tue Jul 30, 2019 7:15 pm
I don't think there is such an issue with RouterOS updates. Maybe there is some need of temporary space (e.g. to generate a new config from the old one) but MikroTik engineers should be well aware of it.
When I tried to update devices with limited space I have seen "not enough space" errors several times and never has it corrupted the device.
(other than already existing corruption like a couple of versions ago when the old version of a big file was not deleted and took like 12MB of diskspace)
TheSirStumfy
Tue Jul 30, 2019 7:20 pm
Funny enough this upgrade caused a loop for me, until i also upgraded the firmware, now resolved.
Also as mentioned HAp lite is on the ragged edge of space, i had a backup on it and it could not upgrade until removed.
ViniciusMariano
Tue Jul 30, 2019 7:42 pm
Estou mesmo problema . nao achei soluçao ainda
ViniciusMariano
Tue Jul 30, 2019 8:26 pm
I'm hotspot problem in version 6.45.2 social login does not work it does not open page
Paternot
Long time Member
Long time Member
Tue Jul 30, 2019 8:44 pm
Not really.
Download to RAM. Do the job from there, and keep a flash copy of the disk on it, or on a external storage (SD card, USB disk, pendrive...). If you run into problems, just do an automatic rollback.
pe1chl
Tue Jul 30, 2019 9:25 pm
In the older and the more powerful routers you can partition the flash, and keep the previous version.
Unfortunately that is no longer possible with many recent models because they have only 16M flash (earlier 128M flash was usual).
jamienz
Wed Jul 31, 2019 1:43 am
IP Sec Scripting update
For those using scripting rules on IPSEC-L2TP the ip ipsec remote-peers has changed in ip ipsec active-peers
Any scripts using L2PT security on that might need to be updated.
Indeed. Mikrotik you need to update this:
https://wiki.mikrotik.com/wiki/Securing ... _for_IPSec
freezer
Wed Jul 31, 2019 3:11 pm
6.45.2 on my cAP AC is total crap. I'm loosing MGMT access few minutes after power cycling the unit. I did downgrade to 6.44.5 but it was still working as badly as before - I had to downgrade the firmware too to finally have a stable device.
-Greg
Skype: freezer_szczecin
posh4529
Wed Jul 31, 2019 11:20 pm
Hi everybody!
Today I had an issue after updating the RouterOS on my 2 Mikrotik routers from ver.6.45.1 to ver.6.45.2. My RB4011 lost it's ability to obtain the ip-address from ISP via DHCP. I do strongly advise you not to update to RoterOS version 6.45.2 as it's stable but faulty. For details: SL4529@GMAIL.COM.
Paternot
Long time Member
Long time Member
Wed Jul 31, 2019 11:36 pm
We are reaching the point where 6.45.2 should be considered "unfit for purpose". Even the vulnerabilities it mitigates seem "less worse" than the problems it caused.
Waiting 6.45.3 (6.46?).
DummyPLUG
Thu Aug 01, 2019 4:22 pm
What's new in 6.45.3 (2019-Jul-29 12:11):
Important note!!!
Due to removal of compatibility with old version passwords in this version, downgrading to any version prior to v6.43 (v6.42.12 and older) will clear all user passwords and allow password-less authentication. Please secure your router after downgrading.
Old API authentication method will also no longer work, see documentation for new login procedure:
https://wiki.mikrotik.com/wiki/Manual:API#Initial_login
*) certificate - renew certificates via SCEP when 3/4 of lifetime reached;
*) crs317 - fixed multicast packet receiving (introduced in v6.45);
*) hotspot - fixed default profile values not being used (introduced in v6.45);
*) rb4011 - fixed SFP+ interface linking (introduced in v6.45.2);
*) supout - fixed SIM slot printing (introduced in v6.45);
*) wireless - improved U-APSD (WMM Power Save) support for 802.11e;
CrimzinZA
Thu Aug 01, 2019 4:27 pm
I recently purchased 4 LtAP mini's I have upgraded each one to 6.45.2 ( original factory type was 6.42.1 )
The LTE connection is VERY unreliable.
I am using Vodacom sim both contract and Pay as you go.
I had to remove both sims pin as the software can't handle it.
It has internet for a few minutes then just stops. although it states registered and up. you can’t ping 8.8.8.8.
You have to restart the router. plus it sometimes connects and sometimes not. then you restart then it works.
I have tried setting it to LTE only.
I have tried putting roaming on and off.
still stops working.
These units soul goal is to have something in the field connected to the internet. but it is not working.
One guy mentioned the LTE interface disappearing. try rebooting the unit 4 times. then it comes back.
Also after upgrading you have to reset the whole unit just to get stuff to work again.
I have tried it in different locations. 2 different units and with external and internal antennas.
Kindis
Thu Aug 01, 2019 5:17 pm
What version of ROS are you running? Also have you updated the modem firmware. I had big issues getting 4G to run on my unit until I upgraded modem firmware.
Amm0
Thu Aug 01, 2019 5:20 pm
@CrimzinZA As noted above, make sure the firmware matches (in Winbox, System > Routerboard > Upgrade, then reboot the box). If that doesn't help, you might want to try downgrading to the "long term" release...under System > Packages, you can select the older package. Don't know if it will help, but something to try.
HZsolt
Thu Aug 01, 2019 7:35 pm
/system package update check-for-updates
channel: stable
installed-version: 6.45.2
latest-version: 6.45.2
status: System is already up to date
The 6.45.3 is not available yet!
Kindis
Thu Aug 01, 2019 8:43 pm
@CrimzinZA You have 3 things to check 😁
ROS version, MT firmware and modem firmware.
Upgrading modem firmware solved my 4G issues.
Here is how to update modem firmware https://wiki.mikrotik.com/wiki/Manual:I ... re_upgrade
Kindis
Thu Aug 01, 2019 8:45 pm
channel: stable
You can download via the download page.
https://mikrotik.com/download
HZsolt
Thu Aug 01, 2019 9:02 pm
channel: stable
I know it, but I would like download via the command line.
sindy
Thu Aug 01, 2019 9:38 pm
No problem:
/tool fetch url=("https://download.mikrotik.com/routeros/6.45.3/routeros-".[/system resource get architecture-name]."-6.45.3.npk")
HZsolt
Thu Aug 01, 2019 9:44 pm
No problem:
Thank You!!! You are GENIUS!!!!
eworm
Thu Aug 01, 2019 9:56 pm
Or you use my script, just copy and paste to your terminal:
unattended-lte-firmware-upgrade
Even works for devices in remote location.
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
xtrans
Fri Aug 02, 2019 7:09 am
from v6.45.1 to v6.45.2 still not automatically showing captive portal on hotspot in http. only v6.44.3 below work perfectly
update.. even v6.45.3 not automatically show captive portal.
CrimzinZA
Fri Aug 02, 2019 9:16 am
Thank you for the feedback.
I made sure it was done. routerboard and firmware is the same.
If I downgrade what would be the safest reliable version?
Best Regards.
CrimzinZA
Fri Aug 02, 2019 9:21 am
I had this randomly happen. After restarting a few times it sees it again. one issue is that I can see the LTE and the traffic but the unit itself cant connect to the internet although it states its registered and connected. When connected and there is internet it only last for a short while. ( from a few minutes to a day )
CrimzinZA
Fri Aug 02, 2019 9:35 am
I have picked up a new problem on LtAP mini.
if you remove GSM and 3G an leave LTE it states under Interface >> LTE1 >> Status >> Registration status >> unknown or denied.
If you dd 3G back it registers
LeftyTs
Fri Aug 02, 2019 10:33 am
No problem:
This will work if you have the main package installed but if you have packages (like devices with limited flash space for example) then this is a big problem and you have to get the full package and then extract and install the packages. This is OK and not such a big issue if you have one or maybe a few mikrotik devices to manage but it is a big problem if you mange a lot of them and each one may be different than the other in architecture as well as packages installed, so please Mikrotik, can you fix this problem?
Jotne
Fri Aug 02, 2019 12:20 pm
One day since 6.45.3 released on download, nothing here on the forum.
Can't remember seeing this behavior before.
MikroTik->Splunk
sindy
Fri Aug 02, 2019 12:50 pm
@emils has explained that in the 6.45.3 topic you've spawned yourself - problems with the release system.
bda
Fri Aug 02, 2019 1:31 pm
6.45.3 has no GRE miss-marking fix. Very Bad...
God bless UNIX!
sindy
Fri Aug 02, 2019 2:10 pm
I agree it is bad, but on the other hand what is so complicated about adding protocol=!gre to the action=drop connection-state=invalid rule?
rzirzi
Fri Aug 02, 2019 2:58 pm
But... why it isn't any official info about ROS 6.45.3 ?
sindy
Fri Aug 02, 2019 3:07 pm
See post #202 above.
karlisi
Fri Aug 02, 2019 3:28 pm
Check Winbox version, it must be at least 3.19
Karlis
Users browsing this forum: No registered users and 4 guests
