minnynkss15
Easy way to mass upgrade firmware?
Sun Jul 21, 2019 7:28 am
We have used the dude to mass upgrade RouterOS software.
Is there a way to use it to mass update the firmware and trigger a reboot?
jondavy
Re: Easy way to mass upgrade firmware?
Thu Sep 12, 2019 12:10 am
really,
With the recent security holes mikrotik should implement a native way to do a massive update
this would even help the brand promote itself and avoid forum threads because of outdated software,
as many do not upgrade as it is impossible to update hundreds of CPEs manually
normis
Thu Sep 12, 2019 10:29 am
You can do it with TR-069 ACS
HaQs
Thu Sep 12, 2019 5:33 pm
upgrade via ROS AP connected all ROS clients will be nice option.
Users browsing this forum: No registered users and 0 guests
