Zoolander06
How to set priority code on vlan (for pppoe)
Tue Jul 30, 2019 12:08 pm
Hello folks,
I have a SDSL access, and my ISP ask me to set a pppoe session over the vlan2900, with the priority code 2.
Before I was working with Zyxel, and I just had to specify priority code in vlan settings.
Now I work with Mikrotik (and I love the freedom they offer), and I don't know how to do that.
I tried a mangle rule :
/ip firewall mangle add action=set-priority chain=output new-priority=2 out-interface=vlan2900 passthrough=yes
But I don't see any traffic going through, so I don't think it works.
I think that's because firewall works on layer 3 when pppoe is layer 2, right ?
So, could anybody explain to me how to do what I want to do (if possible) ?
Zoolander06
Re: How to set priority code on vlan (for pppoe)
Tue Jul 30, 2019 12:16 pm
I reply myself :)
What if I do that ?
/interface ethernet switch rule
add new-vlan-priority=2 ports=ether1 switch=switch1
add independent-learning=no ports=ether1 switch=switch1 vlan-id=2900
Is that correct ? I'm not sure how vlan works on switch level...
msatter
Tue Jul 30, 2019 2:14 pm
I can only set the vlan and I do it in /interface vlan
Then PPPoE uses the VLAN interface as exit and the VLAN uses WAN as exit (eth1 in your case)
You have to state which router you use because some like mine can do only software VLAN.
One RB4011 (cooled) and a RB760iGS (hEX S) in series. The 4011 Does PPPoE/IKEv2.
The cooler: viewtopic.php?f=3&t=138613&start=300#p799879
Running:
RouterOS 6.48beta35 / Winbox 3.27 64bits / MikroTik APP 1.3.15
Zoolander06
Tue Jul 30, 2019 3:07 pm
Yes you're right, but my problem is that I have to set a priority code on the VLAN, and I want to be sure I do it the right way.
sindy
Tue Jul 30, 2019 3:21 pm
You're right that PPPoE is L2 so /ip firewall rules do not handle PPPoE frames.
But as /interface ethernet switch rules act on ingress frames, you have to set your rule to match the CPU port of the switch. As there is an issue with matching VLAN ID, you'll have to match on the MAC address instead, see this post.
Instead of writing novels, post /export hide-sensitive. Use find&replace in your favourite text editor to systematically replace all occurrences of each public IP address potentially identifying you by a distinctive pattern such as my.public.ip.1.
Zoolander06
Tue Jul 30, 2019 5:59 pm
Thank you Sindy for this explanation :)
I don't understand how the MAC address matching work.
Do I have to match on the MAC address of the SDSL modem ?
Joris
sindy
Tue Jul 30, 2019 6:44 pm
Hm, it should be the MAC address of the remote PPPoE server, but as I think of it, it seems we have a deadlock problem here, as you don't know its MAC address until it answers and it doesn't answer until you set the VLAN priority.
So try to match on src-mac-address first:
/interface ethernet switch rule add switch=switch2 ports=switch2-cpu src-mac-address=mac:add:ress:of:eth:er1/ff:ff:ff:ff:ff:ff new-vlan-priority=2
If it doesn't help, just set the vlan priority of all packets from CPU to 2:
/interface ethernet switch rule add switch=switch2 ports=switch2-cpu new-vlan-priority=2
And if even that doesn't help, post your configuration according to the hint in my automatic signature below.
Zoolander06
Tue Jul 30, 2019 7:00 pm
I will try with src mac address.
If I tag everything with priority code 2, I think it will break my local network too...
sindy
Tue Jul 30, 2019 7:14 pm
It should not as normally only advanced L2 equipment cares about that field, and it only uses it to choose which frame to send next out a given egress port if several have arrived while the previous one was being sent. So unless there is a constant overbooking on a link, the frames with lower priority are just delayed, not dropped.
I don't understand what makes some ISPs misuse 802.1Q as a kind of sub-address of the VID, except that they want to prevent people from using their own gear, but when this is the intention, it makes no sense to tell the customer how to set the gear.
Zoolander06
Wed Aug 07, 2019 1:25 pm
Yes but some equipements won't process Ethernet frames with 802.1q added bytes, I think...
I managed to get it working by matching mac address. Actually, I know mac address cause even without the priority code set, PPPoE works, the only thing is that upstream bandwith is quite limited.
So, I have to match the mac adresse 06:47:01:00:00:00 in my switch rule, and everything is fine.
I don't really understand what is this mac address, but I found it by capturing frames on the ethernet port...
Thanks for your help :)
Joris
Filament
Tue Feb 11, 2020 8:14 pm
Guys,
What would be the correct way to insert QoS priority in this situation?
I'm trying to configure a Mikrotik Hap Ac2, which is connected to a Nokia ONT (this ONT is supplied by the ISP)
I'm currently using this config:
/interface vlan
add interface=ether1 name=vlan24voda vlan-id=24
/interface pppoe-client
add add-default-route=yes allow=pap,chap disabled=no interface=vlan24voda keepalive-timeout=60 max-mru=1492 max-mtu=1492 name=pppoe-voda password=BLABLA user=LWN1234567890@lowi
But I'd like to insert the correct QoS tag. Should I configure the mangling in the VLAN interface?
/ip firewall mangle add chain=postrouting action=set-priority new-priority=3 out-interface=vlan24voda
Or should I mangle it in the PPPoE interface?
/ip firewall mangle add chain=postrouting action=set-priority new-priority=3 out-interface=pppoe-voda
Which of the two options is correct?
Kind regards.
Zoolander06
Mon Feb 17, 2020 6:51 pm
Sorry for the late answer.
Actually, you can't do that with a mangle, you have to do that with a switch rule :
add new-vlan-priority=3 ports=switch1-cpu src-mac-address=[interface_mac_address]/FF:FF:FF:FF:FF:FF switch=switch1
The mac address is the one of the interface on which your ONT is connected.
The port and the switch could vary depending of your hardware, I don't know the hAP AC2, but I use this rule on a RB2011, which use the same switch chip.
I hope this will help you.
Joris
Users browsing this forum: carlosdaff, Google [Bot], ingdaka, xvo and 45 guests
