MUM Europe 2020
Jotne
Bug or limitation on main body size of syslog message
Fri Aug 02, 2019 11:19 pm
After some investigation I found out that RouterOS cuts Syslog message at 256 characters. Then add info of what module and prefix.
So the total message may be longer than 256 characters, but not the body of the message.
If I do send message to terminal using :put they are inn full length.
Here are some log message
Len 278 bytes (body 256)
script,info MikroTik: .id=*7;address=10.10.10.121;address4=10.10.10.121;age=00:00:57;board=RB941-2nD;identity=hAP_lite;interface=ether2;Bridge1;interface-name=bridge1/ether4;ipv6=false;mac-address=64:D1:54:05:82:38;platform=MikroTik;script=neighbor;software-id=76GC-9ZT5;system-
Len 284 characters (body 256)
dhcp,debug,packet MikroTik: Vendor-Specific = 00-FF-01-02-03-04-05-06-07-08-09-0A-0B-0C-0D-0E-0F-10-11-12-13-14-15-16-17-18-19-1A-1B-1C-1D-1E-1F-20-21-22-23-24-25-26-27-28-29-2A-2B-2C-2D-2E-2F-30-31-32-33-34-35-36-37-38-39-3A-3B-3C-3D-3E-3F-40-41-42-43-44-45-46-47-48-49-4A-4B-4C-
Len 258 characters (body 230)
dhcp,debug,packet MikroTik: Parameter-List = Subnet-Mask,Router,Domain-Server,Domain-Name,Router-Discovery,Static-Route,Vendor-Specific,NETBIOS-Name-Server,NETBIOS-Node-Type,NETBIOS-Scope,Domain-Search,Classless-Route,MS-Classless-Route,Auto-Proxy-Config
The two first message in green are not complete and being cut at 256 characters.
Since total messaes are longer than 256 bytes, Router OS have no problem sending longer messages.
This needs to be fixed, since it gives incomplete external logs.
This info has been posted to MT, response will be posted here.
Ticket#2019080222005241
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
sebastia
Re: Bug or limitation on main body size of syslog message
Tue Aug 06, 2019 1:15 am
Thx for info
Users browsing this forum: No registered users and 77 guests
