MUM Europe 2020
nmc
Getting trouble while creating VLANs and bonding interface between an RB3011 and CRS328
Sun Aug 04, 2019 12:38 am
I'm trying to build a new network with VLAN and bonding and i'm having a lot of trouble getting it up and running.
I have a RB3011 as the main router, which has been working fine for the last 3 years. The current network setuped on this router is 10.50.0.1/24
I just bought a new CRS328-24P-4S+RM to use as my main switch.
I want to create 2 new VLAN where i will move all my machines to eventually. VLAN 100 (10.80.0.0/22) and VLAN 200 (10.80.4.0/22)
Also want a bonding interface between both the switch and router.
Here is a diagram of how i would like things plugued.
I have tried this. Here is my current config:
RB3011
Code: Select all
# jul/28/2019 18:16:05 by RouterOS 6.45.1
# software id = LM13-4QY3
# model = RouterBOARD 3011UiAS
add admin-mac=xx arp=proxy-arp auto-mac=no fast-forward=no \
name=bridge-local vlan-filtering=yes
/interface bonding
add mode=802.3ad name=router-switch slaves=\
ether4-slave-local,ether5-slave-local
/interface vlan
add interface=router-switch name=vlan-srv-100 vlan-id=100
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=ether3-slave-local
add bridge=bridge-local ingress-filtering=yes interface=router-switch
/interface bridge settings
set use-ip-firewall-for-vlan=yes
/interface bridge vlan
add bridge=bridge-local tagged=router-switch vlan-ids=100
add address=10.13.37.1/16 comment="default configuration" interface=\
ether2-master-local network=10.13.0.0
add address=69.70.215.78/30 interface=ether1-internet network=69.70.215.76
add address=10.80.0.1/22 interface=vlan-srv-100 network=10.80.0.0
CRS328
Code: Select all
# jan/02/1970 00:30:35 by RouterOS 6.45.1
# software id = R141-ZR7S
# model = CRS328-24P-4S+
add admin-mac=xx auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
set [ find default-name=ether2 ] mac-address=xx
/interface vlan
add interface=bridge name=vlan-srv-100 vlan-id=100
/interface bonding
add mode=802.3ad name=router-switch slaves=ether1,ether2
add bridge=bridge frame-types=admit-only-vlan-tagged ingress-filtering=yes \
add bridge=bridge tagged=bridge,router-switch vlan-ids=100
add address=10.80.0.2/22 interface=vlan-srv-100 network=10.80.0.0
add distance=1 dst-address=0.0.0.0/32 gateway=10.80.0.1
The bonding seems to work fine and i'm able to ping to 10.80.0.1 which is the adress of the router VLAN 100. However i cannot ping the switch or anything else on this network.
Anything i'm missing ? Let me know if you need more information.
Thank you.
sebastia
Re: Getting trouble while creating VLANs and bonding interface between an RB3011 and CRS328
Sun Aug 04, 2019 1:08 am
Hey
There is an extensive vlan how-to on this forum, have a look. (viewtopic.php?f=13&t=143620&hilit=vlan)
Some remarks:
* why need for proxy-arp on bridge?
* vlan-filtering=yes (on non-CRS3xx hardware) is in software, if you want it hardware, you'll need to do it through "switch" functions
* if only vlan should pass over bond, why make it part of bridge and then filter everything away? just keep it independent interface
* do you plan on using that "use-ip-firewall-for-vlan=yes"?
* in "/interface bridge vlan" bridge-local should also be in the tagged list of interfaces (like you did for crs config)
Added info: vlan howto + vlan-filtering clarification
nmc
Sun Aug 04, 2019 1:36 am
Thanks for the reply,
I forgot to mention that I tried to follow this guide : https://wiki.mikrotik.com/wiki/Manual:C ... with_Bonds
Can you link to the VLAN howto you mentioned ? Thanks.
* proxy-arp, I don't remember when and why I activated this, could it be because of VPN or mDNS ? should I remove it ?
* Ok that's what I tough, but that weren't mentioned in the how-to linked above. But i think the RB3011 cannot do VLAN over the bonding interface.
* I followed the how-to above, and it adds bond to the bridge if I understand it correctly.
* I plan on using rules in firewall to block some traffic between subnets, isn't it what this does ?
* OK I will try to add this in bridge vlan.
sebastia
Sun Aug 04, 2019 2:07 am
* Ok that's what I tough, but that weren't mentioned in the how-to linked above. Will try a different config with this.
* proxy-arp will result in transmission of every packet through bridge. Could be useful for vpn, but for bridge??? I would remove / disable for time being, until specific usecase arrises.
* clarified that its in software for all non-CRS3xx hardware: you're fine on the switch, but not on router
* there is no bridging of bond on the router in the how-to. anyway you always have to evaluate such examples on what YOU need
* between subnets -> routing firewall, what you have now is bridge firewall = filtering of traffic within same subnet
nmc
Sun Aug 04, 2019 3:51 am
Hey, i was able to make it work ! thank you. I'll do more testing tonight but at least i'm able to use vlan between a bonding interface with the switch and router.
However i kept software vlan on the router because i don't think the rb3011 support this feature on a bonding interface. See: https://wiki.mikrotik.com/wiki/Manual:I ... Offloading
Thanks again for your help !
Users browsing this forum: kivimart, operatortt and 59 guests
