rilliam
LtAP SIM not inserted
Sun Aug 04, 2019 3:30 am
routerboard: LtAP
module: mc7455 (inserted in bottom slot, because it wasn't detected in top slot, even after setting at!usbspeed=0)
module fw: SWI9X30C_02.30.03.00 r7804 CARMD-EV-FRMWR2 2018/07/25 01:10:04
carrier: AT&T
Problem:
ERROR: SIM not inserted in PPP info
at+cpin? results in +CME ERROR: SIM not inserted
No matter what sim slot I use, it will not see the SIM slot inserted. I have tried changing the active interface using AT!UIMS command.
at!custom?
!CUSTOM:
             GPSENABLE          0x01
             GPSLPM             0x01
             IPV6ENABLE         0x01
             UIM2ENABLE         0x01
             SIMLPM             0x01
             USBSERIALENABLE    0x01
             SINGLEAPNSWITCH    0x01
rilliam
Re: LtAP SIM not inserted [SOLVED]  [SOLVED]
Sun Aug 04, 2019 9:38 am
I read the manual and found that when using the bottom slot, it is necessary to put the sim card into the 2nd or 3rd sim slot and also disable UIMS2 using the following command:
AT!ENTERCND="A710"
AT!CUSTOM="UIMS2ENABLE"=0
Users browsing this forum: mveselic, server8, tdw and 67 guests
